Question about Electrical Supplies
After a local power outage when power was restored the Jenn-Air double oven model W256W display appears dead also lights off in oven (acts like no power to the oven) circuit breakers fine. Any ideas?
Also power restored to rest of house. I tried resetting circuit breaker with no change.
  • 3,368 Answers
Power it down and measure the voltage, you should have at least 220V. It sounds like you may have lost a phase. If you have the voltage connect it and see if the problem clears up, if not call a service person.
Posted on Dec 31, 2016
After electical outage my Jenn air JJW9230dds is dead?
Check the Main electrical Box for a fuse or circuit breaker that turned off.
Jan 07, 2014 | Jenn-Air JJW9230DDS Stainless Steel...
Jenn-Air JGR8855 oven light stays on
F9 is for the door lock relay fault. Does the lock work OK? Is anything else acting funny on the unit?
Nov 22, 2012 | Jenn-Air JGS8750 Gas Kitchen Range
I have a problem with my jenn-air oven model w256w. On the touch appear F8 alarm. What can I do?
Hello- The code described- F8 indicates a failure in the clock, or control that operates oven. There is no simple 'fix' to this problem. "Self- clean" is the usual cause of board failure. Find a good tech to check it out on site Get an estimate before repair, and remember- Avoid "self-destruct" feature in the future. --Please reply if this info helps- have more if needed.  Thanks- Ed
Mar 18, 2010 | Jenn-Air Ovens
The control panel display light is completely dark but the oven still seems to function ok. Jenn Air Model WW30430P double wall oven.
A lot of ovens use a gas-filled vacuum flourescent display module that takes a higher voltage to drive it. The modules can get damaged or the power supply for the higher voltage (usually around 50 volts) may have failed.
Chances are the thing is only sold as an assembly...While the displays are common in auto speedometers that have digital display, those for these ovens are special with wpecial characters and background.
Jan 31, 2010 | Jenn-Air WW30430P Stainless Steel Electric...
I have a jenn air oven and stove top. the
Just a suggestion, turn the breaker off to the range and leave off for 30 secs. This may reset the board. That's the easy way. If that doesn't help I'll try to find more on it.
Jul 24, 2009 | Jenn-Air JES9800A Electric Kitchen Range
Jenn air oven
More then likely your electronic clock control board is going bad. After turning the power off, you can also try cleaning the connectors on the clock board and make sure the connectors are tight.
Mar 23, 2009 | Jenn-Air JJW8230D Electric Double Oven
Jenn Air JMW8530CAB time/temperature light don't work
We own a Jenn-Aire model W27400W oven. The display module has gradually gone dim over a period of several months prior to the end of the warranty, and the display is no longer visible. It is apparent that several Jenn-Aire oven models use the same display. Does Anyone else have the same problem, and If so, are they willing to join a class-action suit against Jenn-Aire with us?
Steve Patterson
303-256-8494
stevieb4019@comcast.net
Nov 18, 2008 | Jenn-Air JMW8530C Electric Double Oven
Replace doors on jenn air oven with stainless
It is possible but usually costs more than the oven is worth. Call Marcone appliance parts in St. Louis for pricing.
Jun 19, 2008 | Ovens
Jenn- Air Model W256W
hi Randy
first try to unplug the unit, let it sit for a while then plug it back in, if you still get the code look on the back of the unit there should be an envelope that has a paper inside it, that paper should list what the code means.
Apr 01, 2008 | Ovens
Jenn-air Oven Model W256W
just scroll down on this e mail and in the comment box you can answer my question
Feb 14, 2008 | Jenn-Air JGW8130A Electric Single Oven
Electrical Supplies Logo
302 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
