Singer natural gas forced air furnace model no.g-u 312080-12m need pictures of furnace
  • 1420 Answers
SOURCE: Coleman forced air furnace blower
Rmove the two screws holding the blower in place and slide it out. With the power off, rotate the wheel and inspect for debris or an impingement. If everything turns easy, you have a bad motor or start capacitor. If you have rubbing, adjust the wheel. If the motor will not turn, replace it.
Posted on May 30, 2008
  • 52 Answers
SOURCE: Manual for a Coleman Forced Air Furnace manual
If you haven't already tried Coleman customer support, try Google. You can find owner's manuals for all kinds of things. good luck, John
Posted on Nov 07, 2008
  • 2692 Answers
SOURCE: furnace filter is black and sooty wall seem to be sooty
   By sealed unit you mean that the burner air comes from outside of the house?      You have checked the heat exchanger for cracks by removing the burners and looking with a mirror and flashlight, correct, or had a service tech so?
The furnace burners have enough air and are burning clean (blue) with just a tip of orange at the end? You bought the house new and the fireplace has never been used?  If it has been used to clean smoke for the house for whatwever reason I woudl start by havign the ducts cleaned.   Another possibility I have seen is insolation inside of ductwork breaking down.
Posted on Jan 28, 2009
  • 80 Answers
SOURCE: I have an old Magic chef furnace and need to
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Posted on Oct 07, 2009
  • 118 Answers
SOURCE: Gas furnace is constantly blowing cold air
An indoor blower running when it is not supposed to usually indicates an overheat condition. I would guess that it has been cycling on and off for some time and finally caused the high limit to stick and not auto reset. if you tap it sometimes they reset. the real problem is that it has been overheating from lack of airflow, over sized unit, not enough return air, too many closed registers, dirty filter, dirty squirrel cage blower and or air conditioner a-coil. If you get it started again sit and watch the unit run the flames should come on and stay on for the entire heating cycle, not going on and off.
I wish I could help you more but it is difficult without seeing the problem myself. Good luck! this should get you started!
Posted on Nov 03, 2009
Can I convert from natural gas to propane
Yes... you just need a retrofit kit.
Jan 26, 2016 | Heating & Cooling
I had a natural gas furnace installed in place of a propane gas furnace. will this cause my rollout switch to trip constantly. my fuel source is propane. gas valve on furnace wasn't change to propane
If it has a position for natural gas/propane then it needs to be changed to the position that the gas source is either propane or natural gas..
Nov 22, 2015 | Heating & Cooling
Steve realize plenum needs to cool before shut down but even after cold still does not stop.
Ok - let's back up a little bit.. Do you have a forced hot air furnace? Does it run either oil or natural gas (or liquid propane)? Do you have a chimney or power vent?
Sep 28, 2015 | Heating & Cooling
Furnace running but cold air coming out of vent!
There may be a dirty flame sensor, post the model number
Dec 20, 2017 | Goodman Heating & Cooling
Part number is Z6-58RAV050-14CW
230 USD.
Your gas supplier would have the valves. I would not do this if you dont have the expertise. There are too many things that can go wrong and it could cost you in terms of life lost. You need to be able to measure gas pressure etc
Feb 05, 2013 | Heating & Cooling
Heater will fire but wont stay lit.
I assume that you are referring to a natural gas forced air furnace. If so you just described the symptoms of a dirty flame sensor. Remove the sensor with a 1/4" nutdriver. clean the flame sensor with a small piece of fine grit sandpaper or emery cloth. replace the sensor and turn the furnace back on.
Good luck.....
Apr 11, 2009 | Heating & Cooling
Coleman presidential II furnace blower on and off
Sounds like the flame sensor. But it could be the thermostat. Is the furnace standing pilot or electronic spark or hot surface ignition. I would start by checking thermostat. Turn power off to furnace take thermostat off wall and take wires marked r & w and connect them together. Turn power back on if furnace works then change out thermostat.Most eclectronic ignition Furnaces have a flam sensor, You could take flame sensor out and clean it up with steel wool or wire brush. If you need anymore help just reply back .
Jan 17, 2009 | Coleman Propane Forced Air Heater...
Williams 400dvx-r nat forced air natural gas furnace
Power should be shut off at the breaker. Check with a meter before disassembling wires. The gas line gas valve will be at 90 degrees of the gas line when off, however to make sure, try and start the unit with the gas valve at 90 degrees. Remove the front cover of the unit and look for mounting bolts. From the outside, remove the vent screws. The unit should lift off its mounting bracket and slide toward you.
Sep 13, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
