Question about Garden
Brann new Husqvarna snowblower will not go forward or backwards
  • 70 Answers
SOURCE: Ariens 926LE snowblower won't engage
First thing I would check is to make sure the traction drive belt didn't fall off or break. To do this remove the plastic shroud between the engine and the snow chute. The traction belt is the one closest to the engine.If it isn't broke Make sure it is on the upper and lower pulleys.
Posted on Dec 22, 2008
  • 95 Answers
SOURCE: our 20 hp 46" cut
Check to make sure the belt that runs from the engine pulley back to the transaxle is on all the pulleys.If it is a hydrostatic transaxle make sure the free wheel control lever at the back of the tractor is in correct position, or the brake plate may be stuck on but that would make a loud grinding sound.If it is a gear drive make sure the transaxle pulley is turning and make sure you didn't lose a rear wheel key from the axle,(if you had the tire off for a repair it is easy to lose the key when you go to put the tire back on.
Posted on Aug 09, 2009
stmc97
  • 41 Answers
SOURCE: Was mowing when it just stopped going forward. It
Under the mower below the seat of the rider, at the rear of the tractor, look up and you will find the transmission there. There is a belt that runs on the pulley under there, and this belt can slip off when it gets worn or stretched. Sort of a tough spot to get to but, that is most probably cause.
Let me know,
Chip
Posted on Apr 11, 2010
RichSew
  • 194 Answers
SOURCE: my husqvarna classica 90 sews backward .
Make sure the stitch selector is not set on buttonhole. If the machine has set up for a long time not being used it may be that the stitch length is stuck in reverse.
Posted on May 07, 2010
Testimonial: "THANK YOU FOR THE IDEA. I CHECKED THE STITCH LENGTH AND IT IS NOW WORKING CORRECTLY. THANKS SO MUCH."
  • 144 Answers
SOURCE: My Husqvarna 10527 snowblower will
Hi, hope I can help. This sounds like the friction drive disk might be at fault. To check this out you have to stand your blower up on the auger housing. You will see a removable plate at the bottom of the motor housing with 4 bolts on it. Remove the plate and all will be revealed to you. I think you will see a disk that has rubber around it that it worn out. It is at 90 degrees to the drive disk that turns by the drive pulley. If I am right, you probably have to replace this disk. Hope that is the problem. All the best and good luck. I will happily answer any other questions.
Posted on Feb 03, 2011
Noma snowblower transmission is backwards, put in forward it goes backwards and so on
Dear Richard,
Your direction with the gears appears to be 180 degrees out. You may also consider flipping the entire shaft assembly. You. Knowing this assembly is put together correctly.
At this you tube link you will find information to watch for your Norma. The side bar with a catolgue has your answers.
Here is a forum and a blog that may help when the order is corrected
Small Engines Lawn Mowers etc Noma Murray Snowblower question
Craftsman Murray Snow Blower Belt and Friction Wheel Replacement
Dec 09, 2014 | Garden
Snowblower wont engage forward or reverse
Howdie ther is Clutch under the bottom of it that needs to be replaced take the cover off and you will see it
Jan 30, 2014 | Craftsman Snow Blower / Snowblower Bottom...
Husqvarna snowblower does not go forward. The spring is broken on the belt. How can I fix this?
my husq. snow blower when I put in gear it takes off like a rocket ship how do I get to slow down
Jan 03, 2014 | Sewing Machines
My husqvarna classica 90 sews backward instead of forward. Can you help with an answer why?
Apr 19, 2010 | Sewing Machines
Need manual
my ariens mower won't go forwards or backwards
Feb 04, 2009 | Ariens Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
