Question about Lowrance Boating
On Lowrance 7ti chart plotter, how do i change from USA charts to Australia charts.
Maanita
  • 1142 Answers
SOURCE: Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Posted on Sep 02, 2008
SOURCE: How to draw 3D bar chart in Flash?
nbmhmnjmn,n,mm
Posted on Jun 18, 2009
  • 9 Answers
SOURCE: lowrance not reading navionic
Make sure that the 5200c is set to read the Navionic card. You can set that under Map Data.
Posted on Jun 24, 2009
  • 43 Answers
SOURCE: The chart plotter worked perfect for 5 yeas,
I think you have a C- Map card (black colour)clean the contacts with a contactcleaner if it not works try the card somewhere else
The C-Map card have problems that they work for a while and than stops inside the card a some memorychips and they losing contact
Posted on Oct 22, 2009
SOURCE: My Raymarine C80 CHart plotter won't load.
Check to see if this is a power issue by connecting to shore power and fully charging your batteries overnight with instruments off. While still connected to shore power, with batteries fully charged, turn on C80 navigation system. If the loading screen comes on and does not reset, then try holding down the button immediately to the right of the red power button for at least 3 seconds to see if the system re-boots.
Posted on Apr 28, 2010
Testimonial: "Factory reset solved the problem. Soft key next to power button worked a treat!"
How do I get my lake map chip to come on
With your card in your unit follow these steps it should accomplish letting you view your map data.
push MENU twice
Highlight CHART push ENTER
Highlight CHART DATA push ENTER
Highlight LOWRANCE push ENTER.
You will note there is an option for Lowrance and Navionics, if you select Navionics you will see a distinct difference in the way the base map displays on your unit.
Hope this helps.
Feb 11, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Where do I get a manual for lowrance elite 5 fish finder chart plotter gps
Just type this into your browser's searchbox. manualslib.com/manual/292954/Lowrance-Elite-5-Dsi.html
You should be able to pull up the manual there.I just did. Garcuda
Nov 23, 2014 | Lowrance Elite5x Color Fish Finder 102001
Charting a route on water
Hi, a waypoint is used to mark a point of interest for location purposes only whether it be for fish, hazards or a boat ramp etc. it is not intended to replace common sense. Your navionics card if purchased will show land masses, shallow waters, channel markers and known hazards. Regards Phil.
Jul 18, 2012 | Lowrance Hds 5 Hds5 Fishfinder gps Chart...
Just updated to the last version 4 of firmware. Depth reading are wrong, say 48 meters when it's only 2 meters.
Check for depth offset, there may have been an unintended change that altered this setting. This setting compensates for draft....
Jun 21, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
How can I learn more about using my debth finder. Its new to me . Any video tutorials or materials I can read or watch?
look under support
http://www.lowrance.com/Products/Marine/HDS-High-Definition-System/HDS-5-FishfinderGPS-Chartplotter/
Feb 08, 2011 | Lowrance HDS 5 Fishfinder GPS Chart...
Navionics Gold charts will not display on a Lowrance Endura
i have lost my maps on the gold card Australia e&n i have not taken the card out of my lowrance gps sounder lms 339c since new some three & a half years can they be restored i have had no luck trying to contact navionics australia
Jun 07, 2010 | Navionics Gold United States East...
Boating Logo
95 people viewed this question
Top Lowrance Boating Experts
dduncan54
dduncan54
Level 1 Expert
Phil Walker
Phil Walker
Are you a Lowrance Boating Expert? Answer questions, earn points and help others
