Question about Sangean Audio Players & Recorders
I have sangean digital small radio works while the headphones are on but does not work when the are removed no sound
2 Suggested Answers
Grubhead
  • 5349 Answers
SOURCE: Sangean Digital Radio DAB+, no output via speaker
Have a look at the soldering to the headphone jack, it might have come lose or the jack is faulty, thus cutting off the sound to the speaker.
Posted on Jun 20, 2010
When the alarm activates on my Sangean WFR-28, I can see the preset station showing up on the screen but there is no sound, although the volume is set to 20.
I have the same issue with my Sangean WFR-28c. I just contacted support (through Sangean Europe site) but im still wating for an answer. If this carries on, i cannot use this radio. :(
Nov 16, 2016 | Sangean Audio Players & Recorders
Jun 20, 2010 | Audio Players & Recorders
Sangean ATS-803A - no audio
If its not a micro-p glitch, sounds like the radio was subject to a spike or surge wile plugged into the AC adapter. If the "power" light stays on all the time, thats what happened. Believe me, I was Sangean America's tech from 1990-1995.
Rob
The fix is to replace a transistor, or fet in the main pwr supply. (Close to where the adaptor plugs in.)
I wish I could give more details, but its been 14 long, long years.
Jun 03, 2009 | Sangean ATS 808A AM/FM/SW Radio
Sangean ATS 803A
Don't be mis-led by the working display. I had the "no power" problem with a working display too. I measured the voltage of the two AA batteries. One was 1.33 volts and the other was only 0.76 volts. Replaced the weak AA and everything worked. I suspect the 'enable' circuitry fails around/below 2.1v.
Sep 27, 2008 | Sangean ATS 808A AM/FM/SW Radio
No Sound
try plugging it the headphones in and out a few times,problem could be bad connection it that connector
Jul 10, 2008 | C. Crane FRS AM/FM/SW Radio
Sangean ATS 808A-replacement aerial antenna
The antenna should be available from Sangean, or C.Crane.
To replace the entire antenna, about 6 screws from the back must be removed, and the back also removed.
Or you could replace it at the antenna's "elbow". However, this is almost impossible to do without loosing the 2 tiny washers. If you do loose the washers, the antenna will work, but will be loose, and not stand up and support itself.
May 10, 2008 | Sangean ATS 808A AM/FM/SW Radio
Bad adapter?
Dear Kerman,
Sounds like AC hum on your adapter; please find out the adpter voltage and polarity, on the adapter tips, maybe you user manual might have the information. Also the current rating of your adapter.
Try a replacement of the same rating and tip polarity.
That might solve the problem.
sidlahora
Jan 31, 2008 | Sangean ATS 818 AM/FM/SW Radio
No sound
Is there a headphone jack? If so, try a pair of headphones. If you hear sound in the headphones, the main speaker may have gone bad. If you don't hear sound in the headphones, the audio output stage may have have gone bad.
Good Luck,
- Jim
Jan 20, 2008 | Grundig G4000A FM/AM Radio
Sangean ATS 606 A Portable Radio
Remove the battery compartment door and the batteries. There should be a small hole marked "reset" under the upper battery cradle. Press (gently...until it clicks) and hold for 5 seconds. Replace batteries and try again.
Aug 15, 2007 | Sangean ATS 606 AM/FM/SW Radio
SANGEAN ATS505
try the power switch a few times and more force than usual.
Sep 16, 2006 | Sangean ATS 505 AM/FM/SW Radio
70 people viewed this question
Top Sangean Audio Players & Recorders Experts
Oloyede Monsuru
Are you a Sangean Audio Player and Recorder Expert? Answer questions, earn points and help others
