Question about GE Dishwashers
Ge pdw 7880 profile no power at buttons or screen just beeps twice when you turn on main breaker
5 Suggested Answers
SOURCE: Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
Posted on May 03, 2008
  • 9 Answers
SOURCE: ge pdw 7880 does not drain, even into a bucket
clogged strainer, clogged or kinked drain hose ,clogged pump, faulity motor,faulity drain valve. all can be disassembled and cleaned except motor & valve they need to be tested if u have a valve it can be repaired
Posted on Nov 28, 2009
SOURCE: GE Profile Dishwasher beeping
Mine was doing the same thing. It was eligible for a recall.
Free repair or rebate toward new purchase. 1-877-275-6840 or go to website geappliances.com
Posted on Jan 30, 2011
SOURCE: ge profile dishwasher wont start pdw
light comes on but the start button wont come on. dead? i have un plugged it and plugged it back on still the same things. any iedas.
john
Posted on Jul 15, 2011
I have a ge profile dishwasher model pdw9280j00ss. After a storm event, house lost power. Since that time, dishwasher constantly beeps; however has no power to it. shut off circuit, beeping stops; but...
http://www.geappliances.com/search/fast/infobase/10000380.htm
According to this link, it should reset after the power is shut off for awhile. Maybe try holding the start/reset button too. Also check the circuit breaker or any fuses
Aug 28, 2011 | GE 24 in. Profile PDW9880JSS Built-in...
GE Profile 30" slided in range/oven. Ran standard
shut down the power to the machine,disconnect the touchpad ribbon,turn the power back on and let it sit for a day,if the code comes back you have a bad board,if it doesn't come back you have a bad touchpad
Apr 02, 2011 | GE Profile 30" Self-Cleaning Slide-In...
Pdw 9800 jooww When power came on after outage, touch panel doesn't work and there is a constant beeping noise.
Try pressing two control buttons side by side in the center of the panel. The result will light all the buttons on the panel. A test mode will follow before it resets itself.
Sep 24, 2010 | GE 24 in. Profile PDW9800J Built-in...
Ge pdw 7880 does not drain, even into a bucket straight from the outlet pipe
Nov 20, 2009 | GE 24 in. Profile PDW7800 Built-in...
Buttons not working, beeping sound
HI. This is a control fault beep. Kindly unplug, or shut off the appropriate circuit breaker for five minutes. This will drain the main control, and reset the logic chip. Once the five minutes has passed, re-introduce power to the unit, and try to operate the dishwasher normally. If the error continues, replace the control sector asap.
Oct 11, 2009 | GE 24 in. Profile PDW7800 Built-in...
GE profile performance dishwasher- not starting after child pushed buttons.
The only way we have been able to fix this is to turn off the breaker to the dishwasher for 5 minutes and then turn the power back on. The dishwasher should reset.
May 31, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Jul 01, 2008 | GE 24 in. Profile PDW9200J Built-in...
Continuous beep after power went off and on
I'm the one who posted on May 23. I tried turning off the breakers and it was still beeped when powered back on. I ordered a new touchpad and control module. When I replaced the touchpad, the beeping was gone, but not all the buttons worked, so I changed out the control module, too, and it works:) I'm going to put clear caulk along the top to prevent spills from leaking through the front panel.
May 15, 2008 | GE 24 in. Profile PDW9880JSS Built-in...
Will not drain
May 03, 2008 | GE 24 in. Profile PDW7800 Built-in...
Dishwashers Logo
32 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
