Question about Exercise & Fitness
Diagram on how to connect my wb27t10065 control board
    Top Expert:
  • Exercise & F... Master
  • 45,115 Answers
Request the diagram from the manufacturer/distributor.
Posted on Dec 17, 2016
I need a wiring diagram to help install a Honeywell st9120c-4057 control board
SHOULD BE A WIRING DIAGRAM WITH THE NEW CONTROL THAT HAS CONVERSION CHART TELLING YOU EXACTLY HOW TO CONVERT OLD CONTROL TO NEW ONE . MUST BE LISTED ON PAPER EXACT CONTROL NUMBER IF IT DONT LIST IT YOU HAVE WRONG REPLACEMENT CONTROL BOARD.
Jan 11, 2014 | Honeywell Heating & Cooling
Coleman Furnace DGAA077BDTB fuse blows when hot is connected
This can be caused be either a short in the wiring, loose connection on the board,or a low voltage connection not secure on the board. Check all connections to make sure they are tight and secure. Let me know what you find.
Jan 10, 2013 | Heating & Cooling
Control Board burned out...how to install new one? Is it a DIY or does a professional need to do it?
Hello, you can replace it yourself if you are comfortable reading a wiring diagram and connecting wires. The best way to replace it is to sketch the old board on a piece of paper with all tne terminals and wires connevted to it, or just refer to the wiring diagram on the unit if it has one. Tjen take out old board and replace with new board and connect the wires.
Jul 07, 2011 | Heating & Cooling
Maytag oven model mew5530ddb touchpad keys 1,2,8 and clock buttons do not work.
HI. I recommend to inspect the connecting wires at the control sector for loose, or cut connections. If the connecting cables are connected well, and are not loose, simply have the touch pad, or control board replaced, asap. I have posted a link to an exploded diagram of the control sector. Use this diagram to help disassemble the control sector for the inspection.
Click Here To Access Diagram.
Mar 01, 2010 | Ovens
The "cancel" button for the upper oven on my Maytag mer6751aaw gemini electric range just stopped working. To turn off the heat I had to unplug the whole thing! Is this something I can fix myself, or must...
Hi. due to the fact that the control is one whole piece, this will require you to replace the entire main control board. The cancel key is integrated into the control board. There is an overlay that protects the circuit, but it is a separate part, and is not connected to the main board. This repair will require you to disassemble the entire control panel. The board is located just behind the control panel piece.
Click here to view a diagram of the control sector, and panel.
The control board is labeld number three on the diagram, and the control panel is labeled number 1. There are four screws on the back side of the rear cover. Once these screws are released, you can access the board, from the rear of the control panel. The part number for your replacemnt board will be W10166967
  • NOTE_ If you are not comfortable with totally disassembling your control panel, and replacing this main control board, i would suggest to call for service. this job is not easy.
Nov 30, 2009 | Maytag MER6751A Electric Kitchen Range
Do you have a diagram that would show me step by step how to install the new power suply I bought for my computer.
Their is really no diagram to show you how to hook up your supply.
You only have a hand full of plugin connections.
Your 24 pin connection to the mother board, you may or may not have a 4 pin 12 volt video connector, which has to be connected if on the board., and your fan connections.
Everything else is controled thru the motherboard.
Nov 25, 2009 | MGE 400W Power Supply (QG) Power Supply
I need help connecting black wire ( hot line wire) from safty switch. It fell off and I can't figuar out where to put it back on the control board.
On the reverse side of the door panel is a wiring diagram. It is in very small print so get a magnifying glass. Find "L1" on the Schematic side of the wiring diagram (the picture more like a road map). Follow the wire thru the door switch and then down to the control board. It will connect to a terminal possibly marked D1, T1, L1 or what ever the diagram says. Please make sure power is off to the heater prior to doing this.
Nov 06, 2009 | Goodman GMS80903BNA Heater
Replacing ERC on GE oven
I ran into the same problem replacing my new part. The instructions indicated that the GROUND wasn't used. The Nuetral was located in near the same position. The L1B went to the little black box near the vacant L1B location on the board
Aug 19, 2009 | GE JRP15 Electric Single Oven
Exercise & Fitness Logo
54 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
