Question about Refrigerators
Model GI7FVCXWO2 What does the snowflake in the upper left corner of the control panel mean? The fridge will keep the fridge @34 and frezzer for a couple of weeks then fridge temp will go to 47 to 50.
dididsaythat
  • 291 Answers
SOURCE: freezer too cold, fridge to warm
so what is the problem or question? talk to th company u bought the refrigerator from and deman and refund or replacement
Posted on Sep 08, 2007
  • 87 Answers
SOURCE: Samsung Fridge side by side
It sounds like you have a defrost problem. This will either be the defrost heaters the defrost thermostat or defrost timer. In order to check the heater if you are competent enough you can check that you have resistance across the heater. Alternatively you can rotate the timer (normally in the fridge section abov the thermostat control) around to a defrost cycle (you will normally hear a click) and check to see if the defrost heater kicks in. Please note the cabinet has to be cold in order for the heaters to work. The defrost sensor should also have zero resistance across the terminals when the coil is cold. Please do no attempt the above unless you are practically skilled. A good fridge guy should be able to quickly identify the problem and remedy it. Defrost heaters are generally the first part to fail. Hope this is of some help.
Posted on Sep 11, 2007
bobotfel
  • 236 Answers
SOURCE: fridge is in lock mode
Please press the white wine key and interior lamp button together for 3 seconds.
Posted on Jan 09, 2008
relaga58
  • 158 Answers
SOURCE: FRIDGE FREEZES EVERYTHING...DIGITAL PANEL DOES NOT CHANGE THE TEMP.
try off and on power
Posted on May 05, 2009
  • 36 Answers
SOURCE: Sub Zero 680 freezer temperature problem
check the condencer on top .open the doors look up you should see three screws take them out and pull down the panel and clean the condencer if its clean CALL repair guy!
Posted on Jul 24, 2009
How do I access the diagnostic menu on my Samsung fridge?
On the RF4289HARS, press the upper left (A) and upper right (B) corners alternately about 3 times (sequence A-B-A-B-A-B). You should then see "Engineering Mode Enabled." From there, just use the menu and press the "Self Diagnostics" button. Then, it'll show you the errors on the left side of the panel.
Good luck
Nov 14, 2014 | Samsung RF4289HARS
Issue with Kenmore Refrigerator/Freezer
ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
Jan 23, 2013 | Refrigerators
I have a model MTB1956GE Maytag Fridge, Frezzer
Can you feel air moving or hear the fan running in the freezer section? You said the freezer section is freezing well, but is it freezing really hard?
Regards,Richard
Dec 12, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
The refrigerator side will not stay cool. temp goes from 34-57 and back. Frezzer side ok and makes ice.. Its 4 years old with no problems before
Open the fridge and look at the top right corner. Hold down the little switch that turns the light off for about 10 -15 sec you should here a light humming sound like a little fan. If the sound is loud or there's no sound at all. It's the condenser fan motor. Which will just keep breaking down over and over again. for more info read my review.
FIT FiNallee
Dec 26, 2009 | Samsung RS2630SH Side by Side Refrigerator
Where can I find the model number on my kenmore elite washer?
TOP LOADERS
Look at following areas for the model number:
* Rear Center Of Lid Well
* Left Upper Back On Base Cabinet
* Back Top Control Panel
* Right Rear Corner Of Washer Top Lid
* Open Lower Left Front Base
FRONT LOADERS
* Rear Center Of Door Well
* Right Rear Corner Of Washer Door
Oct 26, 2009 | Kenmore Washing Machines
My fridge freezer defrosted n now wont wrk
what you are hearing is the overload kicking in and out. which means bad start relay /bad capacitor/low voltage/bad overload/bad compressor.you can buy a 3in1 to eliminate all but the compressor. and the voltage check them first.
Dec 14, 2008 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Sep 01, 2008 | Sub-Zero 680 / F
Not cooling properly
first the freezer does all the colling for both sides the fridge control just opens a damper door to allow air flow from the fridge if your frezzer is set to high turn it down some and put the fridge on the mid point setting also in the fridge side on the left about halfway down is a vent make sure nothing is blocking it reply with your model number so i can see who made it as kenmore don't make their own appliances and we will go from there
Mar 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Everything freezes in the refrigerator
Your damper that controls the air to the fridge side is stuck open. It can be caused by moisture getting on it and freezing it so it wont close or by a failure in the electrical circuit that controls it. There was a service bulletin from about 3-4 years ago about defective control assemblys. I have replaced several and as far as I know Frigidaire is still replacing some of them for free if they fall under the model and serial numbers that were affected.
You can tell if it is frozen by turning the controls off and thawing the damper at the upper left rear of the fridge section with a hair dryer.. After you have it thawed out, turn the controls back on and you should hear the damper door motor running. Keep your thermometer in it and check it after a while and see if it shuts off before it freezes.
Post back with the complete model and serial numbers and I will try to locate the service bulletin at my shop computer tomorrow.
Oct 26, 2007 | Frigidaire FRS26R4C Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
