Question about Tablets & eReaders
How do i factory reset a ematic android tablet egq337-sl
sumitshiv420
SOURCE: need to factory rest my mid m9000 android tablet
i am frget my password peeeeeeeeeee halp my
Posted on Mar 25, 2013
66chevymalab
  • 13 Answers
SOURCE: i did a factory reset on my A1CS fusion 5 tablet now when i switch on ijust get a flashing ANDROID screen, when i press menu it reverts back to the flashing screen
Charge it overnight and try again give it 24hrsif it don't work drain the battery until it resets it self then charge it 24+rs
Posted on Jan 09, 2015
chriseg1981
  • 38 Answers
SOURCE: I am trying to fix a friend's digital2 tablet the s/n is m961gpl1312 and every time it starts up it goes to the Android recovery page and I've tried to factory reset it and then restart it but it stil
you probably will need to update the firmware
D2_961 Firmware Update Instruction:
1. Download the D2_Firmware in the link below
2. Use an archiving software (Winzip, WinRar, 7 zip etc.) to extract the Firmware Update package and export it to your computer's local disk (ex. C:\)
3. Open up the zip file and there will be 3 folders as shown in image
4. Open "Pad Product Tool 1.05_02" folder and click on "setup.exe" to install update tool.3-284x233.png4-284x233.png5-284x177.png
Click "Next" all the way until the program starts installing. Click "Close" when the software has done installing.
6. Click the 7.png icon and choose the firmware file "jellybean_atm7029_m2909_131216.fw" from the "FW_m2909_961_1115_1216" folder.
7. When the firmware file loads, it will show up on the PAD Product tool.
8. Now, click and hold down the "Volume - "key on the tablet.
9. While holding down "Volume - " key, connect the tablet to a PC using the USB cable.
10. Still holding down "Volume - "key, use a paper clip (or a small pin) and press the "Reset" button on the back of the tablet ONCE (and let go)
11. The 9.png icon will turn into 10.png . Click it to start the firmware update.
12. After the update is complete, remove the USB cable first, then turn on the tablet.11.png
13. The initial start up time may take up to 50+ seconds.
14. After initial start up, tablet will require a reset. Please press and hold the reset button for 10-15 seconds to reset the unit.
http://cloud.d3reaction.com/public.php?service=files&t=2ff2083703cca9cfa4050bd47a793864&download
Posted on Jan 19, 2015
ving911
  • 6 Answers
SOURCE: I brought a ematic 7" Quad-Core tablet with Android 4.2 Jelly Bean. When I turned the tablet on and it go thru it cycle it show on the screen unfortunately, rstech_teni has stopped.
rstech_teni is in your tablet as a core system app even though it may be no such thing. I believe it was put there by the tablet
manufacturer in some contractual agreement with some advertising entity. The Lookout malware scanner may sometimes detect it as malware you should just ignore it and not try to delete it, as it will result in your problem again.
You will not be able restore the tablet from the hardware restore menu (hold power & up vol) because it will not allow you to answer "yes" to the prompt to proceed.
Two ways to fix, (Later, on how to actually select something)
1. (preferred)
Go to >Settings >Apps >All
scroll down to rstech_teni, select it, and then select "Clear data"
If you don't see retech_teni you may find "rs_9104_v30". This may be a clone of rstech_teni, do the same to it.
Your done.
2. (last resort, you will lose installed apps and data)
Go to >Settings >Backup & reset >Factory data reset,
Follow instructions, and your done.
And now the hard part, to deal with the message that will not let you navigate.
The easy way to get to "Settings" is to short tap power button to put tablet to display off/locked.
Then again short tap to turn on screen. You will see the rstecc_teni MSG hit OK in MSG. The MSG should be gone and not come back, do nothing else other than pull down the right upper drop down menu where the settings button is then select settings. At this point the evil MSG will come back.
From here on the frustration will start.
You will need to use two hands. Tap the rstech_teni OK with one finger on one hand and then quickly tap the Apps option with a finger on your other hand. This is kind of time consuming but it works after multiple attemps.
If you have a stylus pen, use it for the second tap to the option you want. It will seriously reduce the time it takes by making the second tap very accurate.
Within a half hour you should be able to get through this.
I know because I had the same problem.
Posted on Jan 26, 2015
kura_setia
SOURCE: How do i reset my android dragon touch tablet
Just thought I'd share ...... My problem was, I brought a brand new Chrome Tablet from Amazon that was stuck on a password page I never made it through the steps to set up my tablet. I didn't have a password & the vendor couldn't help. To hard reset my Chrome Inc Tablet, I held the power button & volume UP button at the same time until the recovery screen came on. The recovery screen shows a robot laying down with an ! mark. Then, while still on the robot screen, I pressed & held the volume UP button again until a list of recovery options came up. You use the volume up & down buttons to high light the option you want & then press the power button to select. I selected the wipe/out - erase data option and it worked. It took the tablet to the factory settings the way a brand new table should be.
Posted on Feb 06, 2015
Ematic funtab pro will not boot
Do a factory reset. Ematic should have the instructions on their site
Jul 20, 2014 | Ematic FunTab Pro 8GB 7" Kids Tablet with...
Why won't my Ematic tablet load?
This needs a factory servicing as the main borad has been compromised.
Jun 28, 2014 | Ematic EM63BL - 7-Inch 4GB HD Tablet...
How do I fix my ematic egs004-pr
Go in to settings and reset back to factory original setting
Jun 02, 2014 | Ematic EGS004 Genesis Prime 7" Touchscreen...
How to change passwrod on ematic emb003bl
I would try a hard reset. Hold the volume down button when you boot it up, and release it when you see the Android guy. Then use the volume buttons to highlight factory reset, and use the power button to select it. Let it do it's thing, then let it sit, awake, for about 20 minutes so the apps can reinstall themselves. Let me know if that works for you.
Jan 24, 2014 | Ematic 7" Tablet Computer
Forgot password
So all you have to do is power it down.
Press and hold + volume button and start the tablet.
It will give you 3 option . Select errase all data and factory reset.
Jan 08, 2014 | Ematic Tablets & eReaders
I forgot my passcode for my ematic tablet. how can i get around it
Hold volume down while you power on the device, and release it when you see the Android guy. *** You have to hold it down while you are powering it up, and don`t let go until you see the Android Guy. *** Then use the volume buttons to highlight factory reset (or something similar) and hit the power button to select it. Make sure you are plugged in while this is going on. Running out of juice during this process can really mess things up. After it is done let it sit, awake, for about 15 min at least while all of the apps reinstall themselves. Let me know if this fixes it for you.
Nov 21, 2013 | XO Vision Ematic eGlide 7Inch Touch Screen...
Tablets & eReaders Logo
71 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
