Question about Kenmore Humidifiers
I have a Kenmore humidifier model 758.144533. It will not shut off completely. The fan goes from a fast speed to a slower speed when it reaches the correct humidity level.
  • 38 Answers
SOURCE: Noise when fan runs.
try cleaning the fan blades
dust/debris build up unbalances the fan and wears the bearings out
oil will only cure the problem for a short while - best option is to relace the fan
Posted on Nov 18, 2008
  • 17 Answers
SOURCE: aprilaire 600 humidity level too low
you may try running your blower 100% of the time.this should allow the humidifier to stay on even when your not heating. once the humidity level gets to where you want it, you may be able to put the fan selector back to auto. also you mentioned you have a variable blower. this is great if it is set up to run at approx. 20% fan speed when it is not heating or cooling. at 20% you can circulate enough air through the house to humidify without being able to hear the noise of the blower. it will really increase the comfort level of the house if you tend to have hot and cool spots. if it was not set up this way, contact the installer and ask if they can do this for you.
Posted on Jan 27, 2009
  • 4 Answers
SOURCE: Humidity too low
But by putting it in manual mose, you have to shut it sdown every season. With it in auto mode, and an outdoor sensor hooked up, you won't have to mess with it.
Posted on Feb 09, 2009
  • 3 Answers
SOURCE: Vicks humidifier v3850 isn't working
does anyone have a problem with a Venta humidifier not working proberly
Posted on Feb 27, 2009
SOURCE: Vicks v4500 humidifier stopped working.
i know why. clean the small long tubular thing that is sucking the water. put a q tip in there and get the gunk out. thats what you need to do -- try it and let me know if it worked. it worked for me!
Posted on Feb 06, 2010
I need a fan motor for the 758 144140 Sears Kenmore Humidifier
I have a Kenmore Quiet Comfort Electronic humidifier, model 758.144140. Is missing filter holders, and float switch, so is inoperable. Motor works fine. Contact me if you want the motor - No charge if you pay for shipping. I will include 2 filters, can include any other parts you want. Why the offer? Space in my house worth more than an inoperative appliance.
Dec 16, 2015 | Kenmore Humidifiers
How do I fix my blower problem on my humidifier?
Free Sears Humidifier User Manuals ' > ... > Household Appliance Sears
Products 1 - 11 of 11 - Sears Humidifier 758.144120. Sears Kenmore Evaporative Console Humidifier Owner's Manual. Pages: 0 Saves: 0. See Prices
Oct 29, 2015 | Kenmore Quiet Comfort 12 Humidifier Filter...
I can't find a replacement filter for Sears Kenmore humidifier model 758743303
Find someone with internet capabilities, and type in the words "Sears Parts" into your search engine. "Sears parts" has pictures and parts for most appliances. Be really sure you have your complete model number. They should show you a picture of your humidifier, and give you a part number. They can ship you the part, or you can go to "e-bay" and try to buy it.
Be blessed.
Jan 30, 2014 | Kenmore Humidifiers
Model 60 controller sometimes clicks when humidifier is running, also furnace fan continues to run after humidity setting is reached.
The clicking is just the water valve opening. Normal. The other issue could be wiring. Some of these were easy to miswire.
Nov 14, 2013 | Aprilaire 700 Humidifier
Power light is on, water is up to fill line, dials are set to max humidity and fan speed, but fans do not spin. Tried to spin fans manually but they will not spin on their own. Left fan stopped spinning...
Do the motors feel warm-- maybe even HOT?-- Like they have electric current, but the bearings might be seizing up?
You mentioned one stopped spinning awhile ago--- and the other one was OK-
It sounds like the bearings are dry and worn on the fans-- (How old is the humidifier?)
The bearings CAN be cleaned up and lubricated, if you are into tearing a motor apart, and servicing the bearings-- Are you ready for that? You will have to remove the motors from their mounting, remove the fans, split the end bells, and clean and lubricate the bearings deep inside.
Let us know how much further you want to go-
Mack B
Jan 19, 2011 | Kenmore 14416 Humidifier
Kenmore Humidifier 14114 - the fan suddenly stopped running. Changed fliter and water, unplugged the unit, changed dial to highest humidity level - the unit will not run.
Please turn off the power to the unit and unplug it. Now check the fuse inside the unit, make sure its fine and not burnt If fuse seems OK then inspect the connections to the fan and make sure the wires are not cut. Also, inspect the control for any burnt components, use a multimeter to confirm. Hope this helps... Please post back with complete model# if you need more information.
Jan 04, 2011 | Kenmore Humidifiers
Kenmore Humidifier not operating?
Turn the unit off, lift the fan assembly off the base, and push the connector together that goes to the float switch on the bottom of the fan motor. If you hold the switch in with your finger (careful not to get into the fan blades) and turn the unit on, the F indication should go away. F (as in Fill), apparently, means the base has no water. The plastic tube that sticks up out of the base floats on the water and pushes the switch. Put it back together, it should work!
Dec 08, 2009 | Kenmore Humidifiers
Hampton Ceiling Fan only goes fast when the Light is on
let's look at the neutral wires. motor neutral may be loose in the wire nut and you are getting a connection to neutral when the light is on.
Aug 05, 2009 | Honeywell HE365 Humidifier
Thermostat Will NOT Turn OFF
Most of these have a flag switch which starts then when the duct air goes through. If that fan switch is stuck it wil not turn off.
Dec 28, 2008 | Honeywell Power Humidifier: Furnace...
Humidifiers Logo
59 people viewed this question
Top Kenmore Humidifiers Experts
Mack Baxter
Are you a Kenmore Humidifier Expert? Answer questions, earn points and help others
