Question about Garden
My hand held control turns on but when i raise the plow it shuts off wait afew min its starts to work then off again
TampaNative
  • 778 Answers
SOURCE: Crash!!
Could be Heat, sounds like the system is shutting down to protect the processor. Let it sit shut down over night and see if it runs longer when it's cooled down. Is the fan running?
Posted on Sep 05, 2008
  • 172 Answers
SOURCE: Power Working fine but keeps shutting off
Hi jenniferlahm,
This type problem usually shows it mean head when your motor is going bad. The motor will run for just a moment then it gets really hot and shuts off till cool. I bet when you start the dryer you hear a unusuall humm as the motor starts. If you are not hearing a hestating humm as it starts then the problem may be elsewhere. Other possible problems that casue this would be. the tub rollers. To check the rollers reach inside and try to turn the tub with your hand. you should be able to turn the tub. if not you may need new rollers, or pads. Good luck and I hope its not a bad motor, but if it is let me know and I can have you one there in no time.
Mike Anderson (Owner)
Anderson Appliance
(865)945-3808
Posted on Sep 30, 2008
luv2tango
  • 36 Answers
SOURCE: 1990 vette runs fine after 15-20 min won't start then wait 20 -min runs fine again until i shut it off
I had the same problem. Turns out,( and I didn't believe it when I was told) but, my problem turned out to be cheap (inferiour) plugs and wired. I was reccomended to use NKG plugs and Borg-Warner wires.
Posted on Jul 12, 2009
  • 14 Answers
SOURCE: Fuel pressure intermittently drops causing sputter and die.
check for 12v constant at your fuel pump if you are not getting that replace your relay.
if you are getting 12 volts at your fuel pump the fuel pump is possible to run tuel it gets warm then shut down to a lower rpm I would then replace the fuel pump
Posted on Oct 10, 2009
  • 101 Answers
SOURCE: my alienwars m8700 starts and shuts down after
try to fromat the system and see if the problem is solved otherwise it might be a hardware problem go to dell care
Posted on May 23, 2010
Hand control red lite blinks and plow dont work;; this seems to be a intermitten problem usually when i first start vehicle to do plowing
Sadly FIXYA does not know every make , model of plow controller made in the world . try a local dealer of your make .I would suspect it might be a dirty connecter between vehicle and plow
Dec 25, 2017 | Cars & Trucks
Why does hand held lose power then come back on during plowing, and raising and lowering the plow ?
Sounds like wiring, check and clean all connections, check for pinched, bare or broken wires
Jan 25, 2016 | Garden
Why won't plow go up?
What is important here is if the blade is trying to lift or not. Try assisting by hand the blow blade to lift. If the blade stays up than it is likely not the cylinder or the valving. Of course as you are tryng to assist the blade to go up by hand the control needs to be held in the blade up position. You should hear the pump motor and feel the action trying to raise the blade.
If the blade stays up I assume that the valving and cylinder are OK.
Of course make sure there is no air in the system and that the reservoir is full. You made need to purge the air.
No lift most likely bad pump. Look for metal particles in the reserve tank. A small magnetic works best.
Possible pressure relief vale is bad.
Dec 30, 2015 | Cars & Trucks
Voltage gauge drops alternator squeals. When using plow
INSPECT BATTERY ELECTROLYTE LEVEL
INSPECT BATTERY CABLES/TERMINALS
LOAD TEST BATTERY,_______VOLTS @ 150 AMPS (Min SPEC 10.2 VOLTS @ 150 AMPS.)
INSPECT BELT(s),
TEST ALTERNATOR OUTPUT (ON THE VEHICLE,'NOT' BENCH TESTED),
1 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW not ENGAGED
2 _____AMPS @ 12 VOLTS @ 2500 RPM w/PLOW ENGAGED ALT OUTPUT SPEC ????
Feb 04, 2014 | GMC Sierra Cars & Trucks
I have a 2003 f-250 with a curtis sno-pro 3000 hitch n run plow system. when i go to lift plow or go left or right it kills the truck. the light shut off and every thing else as soon as i hit any of the...
I think you have a problem with the plow motor grounding out. when you raise or turn plow in either direction you have to run the plow motor which is grounded out. ( as in hooking the ground and positive together directly ) the plow is on a gravity drop when you let it down by the weight itself and does not require the motor for the plow to operate. It's your plow motor or the positive feed to selonoids.
Feb 05, 2011 | 2003 Ford F250 Super Duty Crew Cab
Oct 10, 2009 | 1994 Dodge Ram
1999 Pontiac Sunfire ignition lock cylinder changed but car has anti theft and car wont start. How can I get it to start?
try turning the ignition on try to start then without shutting key off wait 10 mins then shut key off then back on but do not try starting leave on for ten mins then back off turn key back on to run but do not try starting it wait ten mins then if it reset it should crank over and start if not repeat all steps again
Sep 19, 2009 | 1999 Pontiac Sunfire
May 31, 2009 | 1990 Chevrolet Corvette
Hi jenniferlahm,
Anderson Appliance
(865)945-3808
Sep 24, 2008 | GE DBSR453EBWW Electric Dryer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
