Question about Coffee Makers & Espresso Machines
Oggi lustre carafe how to open top - Coffee Makers & Espresso Machines
New cuisinart Che-12 just unpacked it cannot get top of coffee carafe it has papers I it how do I get it open
Good evening Margaret
I hope you have managed to open the carafe. Do take a look in troubleshooting section of the user manual,
all the best
kolbrun
Jan 24, 2015 | Cuisinart Coffee Makers & Espresso...
The water isnt going through
Make sure the top is closed and you have the top on the carafe. The lid on the carafe lifts open the valve that lets the water flow.
Oct 05, 2014 | Starbucks Verismo 585 Brewer in Piano...
Is the GE 12 cup glass replacement carafe dishwasher safe?
According to the manuals, all GE carafe's are dishwasher safe. If you are concerned, place the carafe on the top shelf for extra protection.
Jan 23, 2010 | GE 106591 Coffee Maker
Coffee over flowing. It is not emptying into carafe.Just a little coffee goes into the thermal carafe through the lid. Majority goes onto the counter top.
That unit has to be replaced, or you need a new part for it. There is nothing you can do on your own to fix that problem. Call the manufacturer right away, because they may consider that a quality issue since you could be burned by the overflowing water/coffee.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please post a comment if you need additional assistance so that I can help you further.
Jul 11, 2009 | Cuisinart Programmable 12-cup Thermal...
Cuisinart DGB-600BC - water inside the carafe shell
First off, do not submerge the carafe in cold water when it is hot. The water will rush past the seals. This solution involves heating the carafe. Be careful to avoid steam burns
1. Place the carafe on a stove top. 2. Slowly heat the carafe. (make sure you are wearing oven mitts -- avoid steam burns) 3. As the carafe heats the water inside steam will escape the area where the seal allowed the water to get in there in the first place. Steam should appear very quickly, If it does not stop the process right away! Pressure can build up and cause the Carafe to explode! 4. Check the carafe from time to time taking care to avoid steam burns. 5. Once the water has been steamed away, remove the carafe from the stove and allow it to cool slowly. DO NOT place the carafe in water or on a very cold surface until it has cooled. The rapid cooling of the left over steam will cause the carafe to collapse on itself if it is placed in cold water while it is still hot from this procedure.
Apr 04, 2009 | Cuisinart DGB-600BC 10-Cup Coffee Maker
Coffee overflowing and spilling out of the basket
Your coffee maker likely has the option where you can remove the carafe while it is brewing so that you can serve yourself in the middle of the brew. When you pull out the carafe in the middle of the brew, a small lever closes off the drip at the end of the basket (to keep the coffee from flowing onto the empty space where the carafe was on onto the burner).
Then when you replace the carafe, the lip of the carafe pushes against that lever and re-opens the valve so that the brew can now drip into the replaced carafe. Simple.
In your case, it appears that when you place the carafe onto the burner plate, it is not engaging that lever and opening up the valve; hence the valve stays closed and the brew fills over the basket and makes a mess, right?
So do this, pull out the carafe and look up where the pointed end of the basket drips into the carafe. You should see a lever, or plate that the carafe top lip hits when the carafe is placed into the burner plate. Once you find that lever, or plate, give it a push (like the carafe would) and see if it moves. if it does not, then that's your problem. It is stuck closed and won't allow the brew to exit the basket into the carafe. Clean it thoroughly if it is stuck and then see if works.
Mar 29, 2009 | Coffee Makers & Espresso Machines
Thermal carafe clogged
I was once able to disassemble the top of the carafe and clean it thoroughly. I've had these clogging problems before, and it has not been the filter chamber that is the problem, but the vent in the carafe being clogged. When the air from the inside of the carafe can't be displaced faster than the coffee is draining in, the coffee stops draining into the carafe, fills the top, and spills over the side.
Will probably end up buying a replacement lid, as I can't figure out how to open the top without destroying it. I must have gotten lucky the time I was able to take it apart.
Jan 03, 2009 | Cuisinart Thermal DGB-600 Grinder
I just received my cuisinart coffe maker DCC1200 and I wanted to brew a pot of coffe but I am unable to open the glass carafe to obtain my coffe filters. Is there a specific way to open this? Your...
Hmm. Better late than never. Just got home with ours. Same problem. Called Cuisinart 800 number. Catch is on top of handle. There is a slight lip on each side there. Pop it up with pressure on both sides simultaneously. To replace, line up lid carefully with top of carafe and press firmly until it pops back on.
Jun 23, 2008 | Cuisinart DCC-1200 Coffee Maker
Coffee not going into carafe
doesnt matter what filters we use this coffee maker is dumping coffee and grounds everywhere
Dec 27, 2007 | KitchenAid KCM511 Coffee Maker
Carafe top
go to nelson appliance dot com. In the site click on coffee makers. search for DeLonghi DC76GC. The carafe & lid go for $21.99
Sep 03, 2007 | DeLonghi Caffe Elite DC76T Coffee Maker
Coffee Makers & Espresso Machines Logo
27 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
