Question about Garden
Where is the starter housing unit on toro 418zr snowblower
SOURCE: i have a toro ccr 3650 snowblower the electric start just grinds
This problem has been solved! I took the covers off the machine, removed the starter and eventually replaced the drive. Apparently the drive parts were put on back ordered and took about 4 weeks to get the drive set. One thing I suggest if anyone does this is to look at the fly wheel to insure it's in good working order. The dealer I worked with said often that is chewed up (the teeth on the fly wheel) and leads to a bigger headache. Fortunately mine was just fine. The machine now works likes like new as I put in a new spark plug as well!
Posted on Mar 24, 2009
  • 47 Answers
SOURCE: Can't get fire on old snowblower TORO 8HP / 32"
te fly wheel is rusted over the magnets remove cover and sand the wheel at the magnets space should be about busnes card thick between the coil and magnets
Posted on Nov 03, 2009
Testimonial: "thanks for the quick answer !"
  • 81 Answers
SOURCE: How do I attatch the heavy spring that helps lift
lift the snow blower up as far as it will go and block it there, attach one end of the heavy spring to the place it attaches on the tractor now attach a come-a-long to the free end of the spring and using the come-a-long stretch out the spring until it is longer then you need it to attach to the other spot it fits on the tractor, pry it over to the spot on the tractor that it goes and slowly let off the tension on the come-a-long until the spring is firmly in its correct position on the tractor. One tip when you attach the spring to the come-a-long use a piece of rope or wire between the come-a-long hook and the end of the spring, so that you have room to attach the spring to the tractor and just remove the rope or wire when in place and you are done. Hope This Helps Don
Posted on Dec 09, 2009
  • 577 Answers
SOURCE: My toro snowblower keeps stalling. It starts up fine, but won't run continuously.
If you haven't already, dump out gas and put fresh in it and try this, if it doesn't work you will have to clean the carb, take it apart and clean all jets ports etc and put back together and you should be Good to Blow Snow, pretty common problem with Small Engines that set half the season.
Posted on Dec 04, 2011
I started this snowblower in the summer and it worked fine...both winters I've tried to use it it won't start. The first year I had it it worked very well.
So you are saying it wont run in the cold. Will it run if you left it in the house until you wanted to use it?
Are you going thru the procedure of Choking the engine ? Is there a Primer Bulb that you have to push on this machine?
I'm just saying that engines don't like the cold to begin with, just make sure you are going thru the 'Cold Start' procedure properly.
Jan 20, 2016 | Toro Power Clear Snowblower 418ZR - 38272
Toro 418ZR runs uneven with choke off
ethanol gas has gummed up your carburetor. take it off and clean it.
Dec 01, 2015 | Toro Power Clear Snowblower 418ZR - 38272
How do I clean carburetor
check out this YouTube video for cleaning a single stage snowblower carb.
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
Won't start
The carburetor on your Toro 418ZR snow blower is located on the right side of the unit above the rear wheel (if standing behind the snow blower). You will have to remove the top main cover and the starter housing to access the carburetor cover and assembly. Here's a part diagram that may help out:
I think the float is stuck on My Toro snowthrower 38272
It's possible. Is it all green and sticky inside the bowl?
Nov 04, 2013 | Toro Power Clear Snowblower 418ZR - 38272
Will not throw snow
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Jan 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
