Honeywell RTH8500 thermostat for home, how to adjust temp read by thermostat.now indicating 6 degrees high.
  • 12 Answers
SOURCE: Inaccurate current room temperature reading
It is not adjustable, sounds like the LED is going bad. Tstat has battery back up for power outages. If you slide the fan switch from auto to on does the blower motor start? If not control problem with unit.
Posted on Jan 22, 2009
kingbrizzle
  • 407 Answers
SOURCE: I bought a Honeywell RTH8500 thermostat and I can't get the temperature to go down past 75 degrees
You will need the installation book that came with the thermostat. There is a way to enter into the programming of the thermostat from the home screen. From there, you will need to find what code is the temperature settings in the manual, they are usually all 3 digit numbers. Once you find the code for the setting your looking for which is the lowest temp for the thermostat, it will have a 75 to the right of it which you can set a lower number. Sorry I do not have the manual right now to just tell you exactly how, but hope this still helps!
Posted on Jun 10, 2012
  • 5423 Answers
SOURCE: need to find out why my honeywell rht4650d thermostat is reading "in recovery"
The problem is likely with the cooling system, not the thermostat itself. Either the message from the thermostat is not being received by the AC unit, the solenoid isn't turning on the unit or it can't cool properly.
First check that none of the wires to the thermostat are loose or broken. You'll have to take the face plate off to check. The conductors are very small wires and can break easily. Depending on the unit,there are 4-5 wires usually for a HVAC system. If a wire is loose, reconnect it (push it in or screw it down gently). If a wire is broken, strip (for screw terminals) a new section and reconnect it. Check for ice build up on the condenser coils. (That is often a sign of a refrigerant leak. You'll need a professional to fix it and recharge the unit.)
Do you hear the fan running? If you do, then the condenser is a likely culprit. If the fan isn't running, then the control board for the system may be bad. You may want a professional to check the system. If you tell them the make and model, the technician can bring the parts if it is a problem with the control board.
I hope this helps.
(We had the broken wires to our thermostat in the winter. A few years ago, a nearby lightning strike had the AC off in the summer due to the control board damage. The house reached 90 degrees while we waited for the repair.)
Posted on May 31, 2013
  • 90 Answers
SOURCE: I install 2 new honeywell non programmable thermostats. The temp never reaches the setting temp. Always 5 to 8 degrees off. I can not get the furnace to heat the home over 70 degrees. Even set at 80.
If the furnace is cycling on and off and not reaching temp there is a problem in the control circuit. If the thermostat is not satisfied the furnace should be running without shutting off in which case the capacity of the furnace is inadequate because of size or problems reducing the capacity. This could be caused by an increase in home size, poor air flow (dirty filter, loose fan belts, fan running slow, obstructions in the duct), dirty heat exchanger or burner, reduced gas flow, over temperature switch bad causing the burner to shut off early, or a few more technical reasons. You may do well to call a technician to troubleshoot this problem.
Posted on Feb 09, 2015
kingbrizzle
  • 407 Answers
SOURCE: Why does my Honeywell thermostat state temporarily set at 68 degrees? A few days later, it will be set at 62 degrees without anyone touching the thermostat?
It's a programmable thermostat. When you change the temperature, it will say temporary until the next programmed schedule starts or a set amount of time. You will have to program the thermostat to the correct temp settings you wish to have, or you can push "HOLD" after changing the temp to make it stay at that set point. Hope this helps!
Posted on Nov 20, 2016
Honeywell emm-3 goes to high heat when thermostat does not call for heat
Replace it (thermostat), but first make sure its in a good location to read the space temperature.
Nov 29, 2013 | Heating & Cooling
May 28, 2012 | Honeywell Rth8500d 7-day Touchscreen...
How can I unlock this th
Remove the thermostat from its base and replace the batteries. To remove the thermostat, grasp it at the edges and pull toward you. The batteries are on the back of the thermostat housing.
Read more: How do I Unlock the Digital Display on a Honeywell RTH8500 Thermostat? ' eHow.com http://www.ehow.com/how_7267447_do-display-honeywell-rth8500-thermostat_.html#ixzz17KTxLwBU
Dec 05, 2010 | Honeywell Heating & Cooling
Temp is ten degrees lower than temp called for
HONEYWELL WEBSITE:
Go to honeywell.com
Under red welcome sign
Bottom red highlighted box literature/image search
Type in thermostat model number
Click on arrow to right
Then click on the PDF files owners manual / installation instructions
If you can’t find what you want, the bottom left and bottom of web
Page, they have homeowners assistance and Home products to get the help you need.
Feb 20, 2010 | Honeywell Programmable Thermostat Heater
I have a honeywell ct3200 with a trane xl 80 furnace. it will cycle on to the right temp, go off and cycle the furnace back on 30 seconds later. Is that normal? It is 32 degrees outside, set at 68
Hi, check page 22 in your manual, it says "Adjust the screws on the back of the thermostat as instructed on page 7." Your furnace is a 80% efficiency but is also a high efficiency 2 stage heating system so try adjusting screws A and B both ways and see which gives you the correct cycling.
Your manual is here:
http://customer.honeywell.com/techlit/pdf/69-0000s/69-0653.pdf
Jan 18, 2010 | Honeywell Programmable Thermostat Heater
Problem with Honeywell HCW80
The thermostat is mounted in front of a hole and a void in the wall. A draft of air may be coming in from this void, where the wires are in the wall. It should be sealed so the thermostat keeps accurate temperature.
Thermostats temperature reading can be calibrated if the reading is off, as indicated by the thermostat's installation manual
Jan 11, 2018 | Honeywell Heating & Cooling
My round Honeywell T-87 on the main floor(middle) of the house has no ON/OFF switch. It controls the temp of that level of the house and even though it is set at 60, the temp is way too high and reads 74....
What you are describing is the Heat Anticipator. It is a small resistor that helps the thermostat from overshooting the set temperature by heating up and shutting off the thermostat just before your set temperature. I don't think that is related to your over heat. 14 degrees is a lot and the Heat Anticipator will only effect it 4 or 5 degrees. I would remove the thermostat and check if there is a call for heat. If so, you have a shorted wire. If not, replace the thermostat.
Dec 30, 2009 | Honeywell Programmable Thermostat Heater
Indoor temp doesnt go to my punched in setting of 68 on therm
if it is around 93-97 degrees outside,thats all the cool your going to get
Jun 23, 2009 | Honeywell Programmable Thermostat Heater
Honeywell Digital Thermostat won't click on if temp is below 59
do you live there? if so here are the rules for setting back temperature: do not lower the temperature more than 8 degrees F from the temperature you want it when your there, setting it back for periods of less than eight hours is also somewhat futile. Due to laws of thermo-dynamics the heat required to recover from more extreme setbacks or shorter periods of time exceeds the savings acquired by taking said action. As to your question directly there are no reasons why your thermostat should not function at any setpoint temperature that it is allowed to set to (45 normally being the lowest) if it does not function below 58 degrees it has a failure and should be replaced before it fails completely. Suggest a Robertshaw or Braeburn brand thermostat, Honeywell quality has slipped over the past decade to unacceptable levels. Unless your considering a Hunter in which case buy another Honeywell.
Dec 17, 2008 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
