Question about Plumbing
I have cold water coming from my faucets however when i try and turn on the hot water NO WATER comes out
    Top Expert:
  • 51,255 Answers
The hot water tap washer has problem swollen with age and is blocking of the water flow
have a plumber check ti out
Posted on Dec 17, 2016
Just removed an old Moen one handle pullout kitchen faucet and installed a brand new updated version. Unable to get hot water line to work properly.
some new faucets come with there on supply lines when you tighten one will twist at the top near the faucet look under the sink to see if this has happened. i've had it happen not long ago
Apr 04, 2016 | Moen Plumbing
Getting hot water when shower valve is first opened.
If I understand correctly, you have single handled shower faucet.
Normally there is a wait for hot water to arrive at faucet.
But now hot water is already at shower faucet.
Single handled faucets have a mixing area inside valve where hot and cold come together before going into sink.
This mixing valve can have crossover where the hot and cold can pass through to each other even when faucet handle is off. When single handle faucets get old, this can happen.
How it happens:
For example another faucet is turned on inside house, and pressure differential between hot and cold causes hot water at shower handle to pass through mixing area and into cold water line.
So if another faucet has been run, then that lets hot flow to faulty single handled shower faucet.
To confirm this is the problem: turn on other faucet and put ear against shower faucet to listen for moving water.
This condition may also signal there is a water leak.
The problem is not harmful, but will draw cold water into water heater each time, and is energy wasteful.
Replace faucet or have plumber repair problem.
Feb 19, 2011 | Price Pfister Single Lever Handle Faucet...
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
& One Handle Tub & Shower Faucet : i have a moen shower faucet and i get not hot wate...
these valves can be adjusted by removing the handle and adjusting the white gear that regulates the hot and cold that come out, try going more to one way if it gets colder then go the other way.
May 16, 2010 | Moen & One Handle Tub & Shower Faucet
Moen Single Handle Shower Faucet-turn on get cold, little hot
You can try to rotate the first plastic ring to the left of center a few teeth, this will let the handle advance alittle more to the hot side.
Oct 09, 2009 | Moen 3175 Legend One Handle Shower Faucet...
The faucet I am having trouble with is a single lever, kithen faucet. It is a Moen PureTouch faucet with water filter in wand. The cold water works fine no matter what on either cold side or hot when the...
This needs a new cartridge and may only cost you a couple of bucks at your local plumbing store. If you do this yourself, just make sure you turn off the water to both the cold and the hot and you will probably just need a allen wrench, screw driver and maybe a cresent wrench.
Aug 03, 2009 | Moen Plumbing
The hot water stops coming out of faucet
if this is the faucet in picture, turn off water, pull out cartridge and inspect for any debris in cartridge or valve body, if not, turn on hot water to see if water is getting through valve body. May have kinked line or debris from or in angle stop line.
Apr 12, 2009 | American Standard Kitchen Faucet 6310 020...
All of a sudden can not get hot water from my Grohe Ladylux plus
I aasume this is single handle
You will need to remove the handle(usually hex screw under lever or bak side covered with small erasure size button
turn water (hot and cold) off under sink
remove the handle
take an adjustible wrench and remove the cartridge it is keyed
so ou can put it back roperly inspect the cartridge for any obstructions
go under sink and slowly turn hot water on and observe if water is coming out of faucet manifold
if water is coming out ok you may have a bad cartridge or had a blockage reinstall cartridge(after youturned water off
turn hot and cold water on under sink and try again
if it works great if not I suggest you take artridge out and replace
Dec 29, 2008 | Plumbing
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Plumbing Logo
99 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
