Question about Microwave Ovens
My microwave shuts down, nothing works and when I hold the lock key. After 20 or ? minutes I'm messaged to set clock. After resetting the clock &try to cook dinner it shuts off when i close the door
MicrowaveSvc
  • 9047 Answers
SOURCE: microwave door
It sounds like the mount which holds tension on your door latch heads (door hooks) is broken. You can confirm that by pushing up on the door hook. If it goes up with no real resistance, the spring is unhooked. Fixing that would require disassembly of the door (by separating the panels) and repairing or replacing either the door hook assembly or the door panel inside.
Posted on Nov 01, 2006
MicrowaveSvc
  • 9047 Answers
SOURCE: Daewoo MT1510B problem
Chances are your magnetron is overheating, activating the magnetron thermostat, which resets and restores power when it cools.
Your manual may call for you to put a paper plate under the popcorn bag to heat better and to protect the turntable. (And always place the food slightly off-center on the turntable, for the same reasons!)
You should first confirm that the outlet reads about 110-120 volts AC and that the microwave is on its own breaker. If a microwave shares a breaker with another high current device (or even lights) it can affect operation.
Then be sure the microwave's internal cooling fan is running.
If this is an over the range model, it will also have a exhaust hood vent fan which you can turn on and off at will, but this is not the fan I'm talking about.
The internal cooling fan should be on whenever the oven is cooking. If not, the magnetron can overheat and eventually be destroyed.
The next issue is how long you've had the oven.
If it's within the 30-day dealer exchange period, I'd take it back for a new one pronto.
If it's within the full warrranty period (usually 1 year) Daewoo's service center should fix it free.
You can visit Daewoo online or call them at 1-800-323-9668 or 1-800-553-4355 to find parts or find your nearest authorized service center to have them do the work.
Posted on Oct 08, 2008
  • 107 Answers
SOURCE: oven shuts down after a few seconds into cycle time for cooking
The magnatron (heating element) is located in the cavity behind the control. If it's leaking microwaves onto the electronics, this will occur. This means the Mag should be replaced and a radiation test run on unit.
Posted on Mar 15, 2009
nikeananth
  • 267 Answers
SOURCE: Microwave beeping and F2 error code
hi,
The F2 code is a keyboard failure. Since it's intermittent I would check for a loose wire/connection. open the control panel and reset the ribbon cable on the circuit board....
thank you,
vijay (vote for me)
Posted on Sep 23, 2009
  • 251 Answers
SOURCE: During cooking, the microwave will work for about
sounds like the cooling fan has came adrift or stopped working , this will cause the magnatron ( the microwave generator ) to overheat tripping the over temperature stat ,so fix the cooling , but be sooooooooooooo carefull in there , microwaves + really high voltages , not really a job for a non electrician/microwave tech
Posted on Oct 20, 2009
Ge microwave m# pvm2070sm1ss. Control panel nonresponsive, attempting to check if creen lock is engaged but cant get past "change the filter"message.
I have never seen a home microwave that shuts down the unit to have you clean the air filter. Mostly they are reminders that stay up for a preprogrammed time. Have you tried to unplug the unit,let it set for a couple of minutes, Plug back in, set the time of day (clock ) and try it again?? If you get NO action from the touch panel, the touch panel may be bad.
Aug 24, 2017 | GE Microwave Ovens
Frigidaire microwave key shows a lock and no keys work
Here is a previous answer that might be of help.......
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If it is still locked or goes into lock mode by itself, the "clear" key on your keypad may be shorting.
Here's how the child lock works on model FMV145:
Child Lock-Out
You may lock the control panel to prevent
the microwave from being accidentally
started or used by children.
To lock or unlock the controls, press and
hold CLEAR/OFF for about three
seconds. When the control panel is
locked, an "L" will be displayed to the
extreme right.
Jun 07, 2016 | Frigidaire Microwave Ovens
Galanz microwave Code 310
This how i fixed with mi open hand i hit the number pad , 3 times hard like i dont care anymore and yeaaaaa it work like new again
Jul 03, 2013 | Microwave Ovens
Sharp microwave 8888 is flashing and I cannot remove
see this steps and fix it. God bless you
Reset the clock. Press "Clock" and the correct time, using the number pads. Press "AM/PM" if applicable, and press "Start" or "Clock" to confirm.
  • 2 Press "Timer On/Off" to reset the timer if nothing on the touch pad will operate. Use the number pads to select a new timed amount, if desired, and press "Timer On/Off" to start. Press again to cancel.
  • 3 Press and hold "Clear/Off" for three seconds if the timer will not function or is blinking when you touch the pads. This will release the "Child Lock" feature. Make a new touch pad selection.
  • 4 Disconnect power to the microwave if following Steps 1 through 3 does not resolve the blinking timer. Wait a few minutes, and then restore power to reset the microwave.
  • However if the problem persist the display board
    main control board is faulty
    Oct 02, 2012 | Sharp Microwave Ovens
    Lock function reset for model JMV8208BAS
    If that doesn't work, leave it unplugged for about 5 minutes. Then let us know if the hard reset does not fix it.
    The owner's manual is online here and it covers the child lock:
    To set the child lock.
    Touch and hold
    ENTER/START
    pad more than 3
    seconds. CHILD
    LOCK ON will
    appear in the display
    window with two
    beeps.
    To cancel the child
    lock.
    Touch and hold
    ENTER/START
    pad more than 3
    seconds. LOCKED
    will disappear and
    you hear two beeps.
    Aug 18, 2010 | Jenn-Air JMV8208BAS Microwave Oven
    Display says "Locked" and clock is on. Key pad wi...
    Otherwise, you may have a shorted membrane keypad.
    Feel free to contact me directly (and please remind me of your full model number from the tag on the unit) for more free information & help.
    William E. Miller, AS-EET
    prototech@usa.net
    http://www.microwavedisplay.com
    Microwave Oven Control Panel Repair Nationwide
    May 19, 2010 | Jenn-Air JMC8130DD Microwave Oven
    Reset
    Depends on the model and the type of reset you are trying to perform.
    For most, disconnect the mains for 5 minutes then reconnect the mains.
    Some microwave ovens with a battery backed up clock require you to turn them off at the mains and reconnect them while holding down one of the control panel keys. This is usually either the CLEAR and START key or the + and - key.
    Mar 21, 2010 | Microwave Ovens
    Control panel locked
    A "hard reset" may work. Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    Let us know if the hard reset doesn't fix it.
    We're happy to help and we appreciate your thoughtful rating of our answer.
    Mar 18, 2008 | GE Advantium 120 Convection/Microwave Oven
    Child lock on and don't know how to turn it off
    The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
    The manual says to turn it on or off, hold the Cancel button for 5 seconds until you hear the tones.
    If you still have trouble after that, the surge may have done some damage, even though the unit has built-in surge protection.
    Mar 08, 2008 | Whirlpool MH3184XP Microwave Oven
    Goldstar microwave
    The control panel has the child lock turned on.
    If that doesn't work, try holding down the "0" pad for about 5 seconds.
    Different models use different keys, so try "Stop/Clear" and other keys.
    If all that fails, contact LG customer support at 1-800-243-0000 or http://us.lgservice.com
    Dec 22, 2007 | Microwave Ovens
    Microwave Ovens Logo
    Top Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Microwave Oven Expert? Answer questions, earn points and help others
