Question about Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave
I was given a Whirlpool microwave. I think it's 6
I was given a Whirlpool microwave. I think it's 6 or 7 years old. I does not have the bottom filters. Is it unwise to use the microwave without those filters?
    President:
  • 1,273 Answers
Not really over the short term, if the vent discharges back into the room. If it is of the type that discharges through the ceiling, you could have grease build up in the vent over time. I found replacement generic filters the other day at Lowe's. But, I wasn't looking for filters at the time. Check there or a similar store.
Good luck,
--W/D--
Posted on Jul 21, 2009
Replacement or fix
just replaced our 6 year old Thermador MBBS ($750) with a GE JES2051SNSS from Home Depot ($179). The bottom guide piece from the Thermador bolted right on the bottom of the GE and positioned the new unit so the front trim piece fit perfectly.
Jun 06, 2013 | Thermador MBBS Microwave Oven
Whirlpool GH5184XPS-7 microwave oven dead, no power.
The problem is in the magnetron or the inverter board.
May 27, 2012 | Whirlpool Microwave Ovens
I have a Whirlpool Gold top-mount fridge (GR2SH/GR2SHM). It's about 6 years old. About a year ago the freezer started to have ice build up and water would over flow into the fridge. I defrost the...
The defrost cycle is not working. After a predetermined number of hours of compressor running time, a timer actuates the defrost cycle, which stops the compressor and turns on a heating element to melt the ice. Either the timer or heating element is not working. Also, make sure the melted ice water is actually draining and not re-freezing.
Aug 31, 2017 | Whirlpool Microwave Ovens
My 15 year-old RHEEM Warrior Model 71-40S forty gallon electric water heater is leaking, and the element also needs replaced. I am thinking it is likely time to get a new, energy-efficient model versus...
Rheem makes great products. Lowe's sells whirlpool brand and they are not all that bad for the money. I would buy something better than the budget 7 year warranty model though. My preferred choice is AO Smith. I would definitely replace your water heater if it is 15 years old- most don't go much longer than that, although mine is 27 years old and going strong! Please remember to make sure and extend your pressure relief valve down to within 6 inches of the floor when replacing the water heater as Code requires. A water heater blanket will also earn its keep in a short amount of time.
Jan 02, 2010 | Microwave Ovens
Microwave is 21 years old. It is above the range
Um, no. You can get a new microwave that is much, much more efficient for a fraction of the repair cost.
Nov 09, 2009 | Whirlpool MH7135XE Microwave Oven
Turntable has suddenly stopped working.
The turntable motor may be bad, if you've confirmed the switch is working. The motor is located under the bottom of the microwave and has the shaft penetrating through the bottom of the oven cavity with a drive coupler attached. The coupler is what drives the glass carousel tray. The motor can be accessed by unplugging the microwave and removing the bottom panel screws. The motor is held in by a couple of screws and two connecting wires. The coupler will lift up and pull off the motor shaft from inside the oven.
You can view this part and exploded view diagrams of your microwave at appliancepartspros.com. Just type in your model number and look under the "Magnetron and Air Flow" heading for item 6 (part number AP 3119645).
If you have any questions, please let me know. I hope this helps you.
Jul 12, 2009 | Whirlpool MH7130XE Microwave Oven
Recommended clearance from bottom of microwave to range top
Your installation manual should have given specific height limitations. I'm not sure for your model, but I beleive it's no less than 22". If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 29, 2009 | Microwave Ovens
Whirlpool microwave mh6150xls makes noise while running
The oven may not be seated properly. check the bushes at the bottom.
Apr 07, 2008 | Whirlpool MH6150XMS Microwave Oven
Whirlpool 1.6 Cu. Ft. Over-the-Range Microwave Logo
124 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
