Question about Insignia Televison & Video
Replaced circuit boards in insignia NS-39E480A13. Now picture is upside dowm
  • 61 Answers
SOURCE: Same Insignia problem but still not working
Check if there is back light on or not?
If back light is on means this unit is having problem with panel (deffective.).
If there is no back light change main baord.
Good luck
Dals123
Posted on Oct 10, 2008
  • 2335 Answers
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Posted on Jan 08, 2009
  • 161 Answers
SOURCE: Insignia lcd tv model ns-ltdvd26 has sound but no picture
the pic attached is an electrolytic capacitor, they come in different sizes and are usually blue, black and sometimes yellow. depending on manufacture.
most of the problems I have heard of tvs having problems with the electrolytic capacitors going bad. if you open the tv and see one of those swollen or leaking you need to replace them.
Posted on Feb 13, 2010
futurework
  • 70 Answers
SOURCE: insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
Posted on May 04, 2010
budmrtn
  • 11361 Answers
SOURCE: I just bought a 32" insignia tv ns-32l430a11 and I
You do not need to buy anything, just look at the owner manual, or look at yor remote control for the button with 'DISPLAY', 'ASPECT', 'ZOOM' for adjusting the aspect ratio.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Nov 30, 2010
I have an insignia NS-39E480A13 TV. I have great picture but no sound. Although I can get sound from an external source. What board will I need to replace to fix this issue?
I don't have service literature for Insignia so I can only help is kind of limited, see if there is a separate rail for the sound section of the TV, some have it most don't, if there is measure that voltage and see if its correct, generally they are 12 or 13 volts..if not correct replace the main board if correct then its the main board...Below is a link for a main board as I think that is where the issue is at, its not cheap.
http://www.shopjimmy.com/insignia-161816-main-board-for-ns-39e480a13.htm
Mar 05, 2018 | Insignia Televison & Video
My Insignia NS-50D550NA15 LCD has no picture but sound what might be the problem
Any one of the TV's circuit boards may be at fault here, a repair manual and testing are needed to figure out which circuit board is at fault.
Jul 06, 2017 | Insignia Televison & Video
Insignia TV picture not working but sound is. Flashlight test picture so assumed backlights. Replaced the board for the lights but is still not working. Model ns-50d550na15 part numbers 170452 172770.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Aug 06, 2016 | Insignia Televison & Video
I have insignia ns-l42q-10a, I have backlight but no picture and no sound. Wall outlet is good. I was watching football game when the picture was lost and about 10 seconds later the sound went dead
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 08, 2015 | Insignia NS-L42Q-10A LCD TV
I have an insignia ns-l37q-10a. Red light works, turns blue when powered up. Picture seems to light up, but no picture. Menu button nor the input buttons do anything.
May 24, 2015 | Insignia Televison & Video
Looking to fix Insignia ns-32e570a11 no picture, only sound problem.
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 03, 2015 | Insignia Ns-32e570a11 32" Led Lcd...
I have an insignia 46" tv I replaced the main board, the tv works except the picture is upside down, what will correct this problem
Flip the TV over! Just kidding!! When you installed the main board was it identical to the old main board? If so, you might want to look at the old board and ensure there are no jumpers that needed to be set on the new board. Some companies make generic control boards for tvs but have different jumper settings for different models. The jumpers are just little black blocks that connect different pins to each other on top of the circuit board.
Dec 03, 2014 | Insignia Televison & Video
NS-LCD42HD-09 Insignia. The power light is on, but no sound, no picture. TV is 13mths old. Best Buy junk I'm guessing, but as a electrical engineer, I'm determined to fix it myself. I think it's the power...
At least the 5VDC stand by power supply is working, there will be a control signal pin from the mainboard to the power supply board to turn on the rest of the power supplies (24vdc for the back light inverter boards, 12vdc for other circuits). Any bulging caps in the power supply?
Nov 24, 2009 | Insignia NS-LCD42HD-09 42 in. HD-Ready LCD...
Televison & Video Logo
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
