Question about Dryers
Model medc200xw will not start. - Dryers
How do i get my electric dryer to work
In the Dryer doesn't Start up your Thermal Fuse it most likely Bad
you can do a continuity Test on the Thermal Fuse
Feb 16, 2015 | Maytag Centennial Series MEDC200XW
My centennial dryer MEDC200XW1 wont start.
Hello;
My name is Peter. I am a retired field service appliance technician.
There are several reasons your dryer will not start.
1.) Bad door switch?
2.) Plugged up with lint?
3.) Thermal fuse?
a.) On the back of your dryer is a hot air distribution manifold. It is easily un-bolted to remove. In the bottom of this manifold dryers get plugged up with lint. If you have a air flow problem your unit will shut down.
Your unit will also not run if you have a bad door switch.
But, here is where I am going to put my money on as your problem.
High limit thermostat on your heater element in the back of your unit.
  • The thermostat is functional to 221 degrees (Fahrenheit).
  • Install the thermostat in your dryer's heater element housing box. Be sure your dryer is unplugged during installation.
This High-Limit Thermostat part #3977767 Cost: $15.00
You can replace this part yourself.
Get back to me if this does not solve you problem. You cab jump the door switch.
Why does my dryer turn off in 10 minutes
Could be overheating. It just may need a good cleaning. and make sure the dryer vent is clear with no obstructions. You may need to take some panels off.
Jul 21, 2014 | Maytag MEDC200XW 7.0 cu. ft. Centennial...
Why does my fryer cutt off in 10 minutes
Could be overheating. It just may need a good cleaning. and make sure the dryer vent is clear with no obstructions. You may need to take some panels off. Also may be the gas valve solenoid.
Why does my maytag dryer medc200xw turn off in 10 minutes and has no heat
Jul 21, 2014 | Maytag MEDC300XW - 29", 7.0 Cu Ft, He...
Want to see a manuel on my new Maytag Dryer Mod: MEDC200XW3
The Maytag should have come with a manual. If not, you can go to the Maytag.com website or Google for it to find the manual for it.
Jul 20, 2014 | Maytag MEDC200XW Centennial Electric Dryer...
Maytag dryer wont heat
Probably the timer. Remove the quick connect from the timer where the big red wire is that comes off the heating element. Check that leg with the leg next to it. moving the timer knob . You should get a meter reading. If you cannot get a read then that timer is fried inside. I did a video which shows one exactly like yours.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Nov 21, 2013 | Maytag MEDC200XW Dryer
The timed cycle does not stop.
Hi Melba Mitchell
Sounds like the timer unit is faulty...
I would recommend that you replace the faulty unit with a new one, they are not rebuildable.
Make sure that you buy the same timer and replace one wire at a time as not to get confused with where all the wires go.
Please rate me
Bud
Oct 01, 2012 | Maytag Centennial Series MEDC200XW
Dryers Logo
42 people viewed this question
Top Dryers Experts
