Question about Car Audio & Video
Is there a car audio amplifier with built in fans?
DUB2502 550w 2-channel a/b mosfet amplifier 1000 watts maual
not 550 watt,,250 x 2 ,,
  • 2-Channel Class-A/B Amplifier
  • RMS Power (4 ohms): 250 watts x 2 chan.
  • RMS Power (2 ohms): 375 watts x 2 chan.
  • Bridged RMS Power: 500 watts x 1 chan.
  • Min. Impedance Unbridged: 2 ohms
  • Min. Impedance Bridged: 4 ohms
  • Brushed Aluminum Chassis
  • Top Mount Controls with Blue Illumination
  • Cooling Fan
  • Chrome DUB Fan Grille
  • Glass Epoxy Circuit Board
  • PWM MOSFET Power Supply
  • THD: 0.02%
  • S/N Ratio: 95 dB
  • Input Sensitivity: 200mV - 4V
  • Frequency Response: 10 Hz - 40 kHz
  • Variable 18 dB/Oct. Hi-Pass / Low-Pass Crossover: 50 - 250 Hz
  • Bass Boost: On/Off 12 dB
  • 4-Way Protecion: Thermal, Short Circuit, Overload, and DC Offset
  • Dimensions: 8-1/4" W x 2-1/8" H x 10-3/4" L
  • Authorized Internet Dealer
Audiobahn DUB2502 2 Channel 250W 2 Class Amplifier at Onlinecarstereo com
Feb 26, 2014 | AudioBahn DUB Mag Audio DUB2502 Car Audio...
How do I put my car stero in auxiliary mode
how to put your amp in aux mode is that the question? I would think that your head unit should be taking care of the aux modes. Your amp is only going to amplify the sound sent to it it's not like a home stereo that has a preamp built in that's what the head unit does on car audio.
Mar 30, 2013 | Rockford Fosgate Punch P5002 Car Audio...
Have a jl audio 500/1 the red light blinks and no other light turns on. whats the problem with it?
I think you might have your remote turn on from your deck to amp hooked up wrong check that out!! I not are you familliar with the mr. butterworth crossover JL developed for that series of amp? Just like its big nrother the 1000x1 class D the built in smart crossover has many built in pretect modes. If your subs are drawing to much power it shuts down if they draw to little of ohms or to many but that 500 is 1 ohm stable so download the crossover settings from JL and go from there
Apr 28, 2012 | Jl Audio 500/1 Car Audio Amplifier
How do i tern the fan off and on or is it automatic
automatic. aftermarket radios have small built in amplifiers and the fans are there to keep them cool
Sep 24, 2011 | Alpine CDA-9825 CD Player
Volfenhag zx 8200 amplifier cooling fan not working
open the back of your amp and see if the leads from the fan are burnt anywhere. trace them from the fan to where they are soldered into the board. if the wires appear to be fine, then test them using a volt meter. if the positive is not recieveing power you may want to solder the lead to your remote turn on.
Aug 24, 2010 | Volfenhag ZX-8200 Car Audio Amplifier
I got power and it hits but then after a bit it stops and red offset light comes on? whats that mean
The amp is overheating it doesn't have a built in fan. This will be more occasional in the summer months. The best solution is to build a box and buy a few computer fans, install a fuse link run the positive of the fans to a remote wire and ground the fans to the chassis of your vehicle. You need a way to recirculate the air inside your amp. I've decided to remove the bottom plate of the amp, mount the amp on a board. Cut holes out of the board and have one fan flipped to pull hot air from the amp and two fans to push the air away from the amp.
You can buy the Antec and Rocket Fish fans for under $15 from Best Buy.
Jul 29, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Is this a good amp
I classify this as a sleeper of the car audio industry. it is powerful, well built, cheap, feature laden, sounds great! very comparible to the big names such as kicker, alpine, fosgate an all the rest. i would prefer this amp over any of them any day of the week! here are the specs for it incase u didn't have them.
  • Max. Power Output: 800W x2Ch.= 1600W @2 Ohms
  • Power Output:
    • 330W x 2Ch.(@2 Ohms) Less Than 0.5% THD
    • 220W x 2Ch.(@4 Ohms) Less Than 0.3%THD
    • Bridge: 660W x 1 Ch.(@4 Ohms) Less Than 0.5% THD
  • All Measurements Done @ 14.4V DC, 1 KHz Input Signal.
  • Dual VU-Meter
  • Dual Fan Cooling System.
  • LPF (Low Pass Filter) Variable 30Hz-250Hz
  • HPF(High Pass Filter) Variable 50Hz-l KHz.
  • Slope Adjustable 12-24dB.
  • Variable Bass Frequency(30Hz-120Hz).
  • Variable 0-18db Bass Boost.
  • High & Low Adjustable Level Input.
  • Dual LED Indicated Power Status (Protect/Power).
  • Mosfet DC-DC Switching Power Supply.
  • Built-in Protection Against Short Circuit, High Temperature & Overload.
  • Auto Power On/Oft By Remote (+12V).
  • Dimensions(mm) : 300(W) x 57(H) x 697(L)
Apr 04, 2010 | Rockwood 4224RTX Car Audio Amplifier
KENWOOD KAC-7201 Light flickers ..and fan turns on -nothing works
I had a kenwood amp that did almost the same thing. Try checking you zener diodes. I found 2 bad ones and replaced them and amp works fine ever since. If your not to good at diagnosing, I have my own business installing car audio/video products as well as amp repairs. I gaet amps from all ove the place. If interested send me a message, I'll be glad to help. One more thing, I'm the cheapest person in amp repair. Good luck
Apr 20, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Do you have instructions for wiring install on volfenhag GX8200??
Amplifier Class AB
Number of Channels 2
RMS Power (4 ohms) 120 watts x 2 channels
RMS Power (2 ohms) 200 watts x 2 channels
RMS Power (1 ohm) Not Stable
Bridged RMS Power 400 watts x 1 channel
Total RMS Power Output 400 watts
Peak Power Output 1000 watts watts x 1 channel
Minimum Impedance Unbridged 2 ohms
Minimum Impedance Bridged 4 ohms
THD at Rated RMS Power 0.1%
Speaker Level Inputs No
Preamp Outputs 1 pair
Built-in Crossover High-pass (HP), Low-pass (LP), Full (AP)
High-Pass Crossover Frequency 40 - 250 Hz
Low-Pass Crossover Frequency 40 - 250 Hz
Subsonic Filter N/A
Signal-to-Noise Ratio N/A
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 20A x 2
Dec 24, 2008 | Volfenhag ZX-8200 Car Audio Amplifier
Earthquake mobile amplifier- fan overruns
As far as I know, no amplifier runs the fan after the remote turn-on voltage is switched off. If the protection light it lit, the amplifier is probably damaged. If it's brand new, you should return it for repair or replacement.
Jan 06, 2008 | Car Audio & Video
Car Audio & Video Logo
50 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
