Question about Saws
I NEED A NEED A PART FOR THE FENCE ON MY TABLE SAW
ANGLE SUPPORT
SOURCE: Can I mount a Delta 36-T30 T2 30-Inch Fence and Rail System on my
I just installed a Delta T2 fence on my 10" Craftsman Table Saw. It's 27" deep. The bushing either could be relocated or you could use spacers on the front, back, or both on the saw to get the required distance. Also, you'll have to drill new holes, however, I used one of the existing holes in the front and back of my saw as well.
Posted on May 15, 2009
rowdy45176
  • 2176 Answers
SOURCE: I have a craftsman table saw 113.27520. Probably a
I checked Searspartsdirect.com and most of the parts for this saw are obsolete no replacement. You might want to go to the site and double check for the part that you need,
Posted on Dec 13, 2009
  • 251 Answers
SOURCE: i can't get the rip fence on my bosch 4000 table
hi ,
this is the link to the bosch manual for your table saw , it has the assembly instructions ( just reverse them ) and full details of the alignment proceadures required to true the blade/guides and fences up .
http://mdm.boschwebservices.com/MDMCache/English%20%5BUS%5D/t10/0000000/r00160v-1.pdf
hope this helps
Posted on Jan 17, 2010
  • 5 Answers
SOURCE: table saw king
Does the blade go to the right if you place the fence on the opposite side of the blade? If so, then the teeth on one side of the blade are dull. The dull teeth beat into the wood, and the sharp teeth cut when the blade is deflected by the dull teeth, leading the cut further and further from the straight line of cutting. This happens when something dulls the blade, like a nail, a foreign object embedded in the wood like stone, or if you use the wrong blade for the work being done, i.e. using a crosscut blade for consistent rip sawing.
First, get a spare blade or two for the saw, don't depend only on one blade. Use a combination blade to get the best balance from ripping and crosscutting. Then for the dull blade: If it is a steel blade, replace it with a carbide blade - a few dollars more, but well worth the upgrade. If it is a carbide blade, get it sharpened, as they will also get dull, though you can't always see it. If it is a carbide blade, and teeth are broken on it, ask your sawyer (saw sharpener) to determine if it is worth replacing the teeth, or if it is less expensive to replace the blade.
A quality blade will last longer than the least expensive ones, as the materials are better machined, balanced, and finished. Hope this helps.
Posted on Jan 26, 2010
tbshaw
SOURCE: Have a Skil #3305-01 table saw. Need to set blade
The jam nut is on the end of the bolt you are adjusting, directly underneath the table. The easiest way to get to it is to place the saw on it's left side, and move the saw blade to the maximum bevel position (45 degrees). You can then reach up -directly underneath the location of the bolt on top - and access the jam nut.
To be clear - the bolt you are tightening is about 2 inches long with the jam nut on the end with the purpose of tightening the bolt into place once you have established the correct adjusted position.
And yes, the directions for this step were terrible.
Posted on Aug 17, 2012
I need a fence for a Yuan Huey (Sakura) table saw, model YHS-258AO. Any idea where I could get one?
I don't know of a source.
Table saw fences/rails are often interchangeable between table saw brands. Usually the rails that the fence rides on must go with the fence. The simpler the connection, the more likely a transfer is compatible.
Sep 30, 2014 | Saws
If your blade is square to the saw table, why would the accu-fence still be off?
if its cutting in the angle. maybe the teeth on your blade are dull on one side and the blade is pulling material to the side. maybe the fence is ok.
Aug 03, 2014 | Powermatic 1792010k 2000 Tablesaw
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
The blade is not sqare to the front of the table, with the fence next to the blade there is a 1/8 inch differance. how do i adjust the blade or the motor/shaft
you don't adjust anything but the fence if I understand the question correctly. You are using the fence for a straight cut and there is a gap, if so on the back of the saw UNPLUG SAW FIRST you will find a schematic about hhow to adjust the fence but all you have to do is loosen the 2 bolts where the arrows are I believe they are 10MM and lift the guard out of the way then gently run the fence next to the blade and "push" the fence square to the blade and tighten the bolts, usually it takes a couple times (I always recheck it). Now if the blade set at 0 degrees is not square you reset the angle from the front. Let me know if you need more help
Feb 25, 2011 | Dewalt DW744X 10" Portable Table Saw
Unable to make a straight cut with saw. Tried adjusting tension, lowered blade, made sure blade aligned properly and did not feed too quickly. HEEEEEELLLLLLLLLLLPPPPPP! Thanks in advance.
Hello, I think that the problem you are having is called "drift" . each blade will cut different than the last. The way I was taught to cure this goes as follows.
-take fence off off table(or just move over)
-get a good square piece of material appx. 1x3 and mark a straight line about 1/2" from edge the full length of the board.
-with out the fence cut the board along the line appx. 1/2 the length.
-shut off saw WITH board in it.
-use a angle finder along the edge of the board, set angle finder
-remove board and put the fence back on.
-now slide the angle finder up to the fence, you should see that the angle is different than the fence (this is the DRIFT ), adjust the fence to the angle finder( I know that the smaller saws usalley don't have this adjustment ) you will have to find a way i.e. shim etc.
This is a very common problem but once you get the idea it is a easy fix
Remember: A guy taught me and I taught you, pass it along thats what we do.LOL
Hope it helped.
The Shop Dog
Oct 23, 2010 | Ryobi 9 in. Benchtop Band Saw
I have an old Craftsman 9 inch table saw that will not cut straight. When you set the fence and get evrything ready it cuts at an angle. A 1x4 will not cut straight it always cuts at an angle. Is there a...
unplug the saw then:
turn the saw over or, get under it; there is a long bolt that sets the
saw motor tilt two nuts jam lock it; release the nuts and adjust the saw using a t-square for 90 degrees.
Jul 31, 2010 | Craftsman Saws
Adjust angle of band saw blade to align with fence
Typically the fence is attached to the table and the table can be angled to create a bevel.
Using a square, align the table so it's square to the blade. Assuming your fence is square to the table vertically, you're good.
With most bandsaws I have worked with, there is a positive stop (typically just a bolt - the head acts as the stop) underneath the table so when you tilt the table, you can return it to flat without having to re-square everything up every time. Once you've got things square, make sure to adjust the positive stop too.
Be aware you may still have to compensate for drift with your fence, though.
If this answer was useful, please vote. Thanks!
May 23, 2010 | Black & Decker 14" Hd Multi Cutter Saw
Dw703 beval adjustment
User manual for adjusting your saw here.
When you set it up, make sure you check for square to the table, square to the fence, and check square for toe-in or at a 45 deg. angle across the blade from the corner where fence meets table, like you would check a radial arm saw. (hold a framing square with one leg against line of fence/table and other leg against blade and inclined 45 to both table and fence. Make sure all three are dead square.
I never found any way to compensate for the play in the blade itself. It seems like the manufacturing tolerances are a little too loose.
You may need a heavier plated blade. You may simply need a different saw. Those Dewalts are great workhorses, and I love the design, but it's my experience that when you're trying to miter hardwoods of any substantial size there's a little bit of drift in the cut as the blade comes through the wood.
You can try cutting at a slower rate.
I've found that makitas are a little more solid through the cut, though I don't like the general ergonomics as much...
Kind of a pain, isn't it?
Well, good luck.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Sep 04, 2009 | Saws
Older Delta 10'' Miter Saw Zero setting is out by 1/2 degree.
Undid the RH fence-bolt in the table behind the fence and tapped the end of the fence forward to make it perpendicular to the blade. Tighten bolt. When you look down on the two fence bolt heads, one is easy to rotate with a socket wrench, the LH bolt head would be very, very difficult to move. Undo the RH bolt to swing the fence angle WRT the blade.
Apr 08, 2009 | Delta Saws
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
