Question about Car Audio & Video
Is there a car audio amp out there with a built in fan?
Volume decreases drasticly after playing loud 15-20minutes
Shes overheating and thus goes into emergency mode and shuts down the volume to help cool down the built in amp . Dont know if it has a built in fan (likely not) but its overheating which can be a number of reasons why...from a failed heatsink componet, inadequet venting, shorted circuit. Can you take it out and inspect it?
Dec 03, 2013 | Kenwood Kdc-x994 Car CD/ MP3 Player
I need to conect both electric fans on my chevy 2006 silverado 8 cilinder
This is just a social web site,no experts & data
base of info to E- mail you
If your missing or have cut off & destroyed wiring,
you will obviously need a wiring diagram to repair
that part & restore things as the vehicle was built,
so you just mount the new fans & plug in
Jan 26, 2013 | 2007 Chevrolet Silverado 1500 2WD
Have a jl audio 500/1 the red light blinks and no other light turns on. whats the problem with it?
I think you might have your remote turn on from your deck to amp hooked up wrong check that out!! I not are you familliar with the mr. butterworth crossover JL developed for that series of amp? Just like its big nrother the 1000x1 class D the built in smart crossover has many built in pretect modes. If your subs are drawing to much power it shuts down if they draw to little of ohms or to many but that 500 is 1 ohm stable so download the crossover settings from JL and go from there
Apr 28, 2012 | Jl Audio 500/1 Car Audio Amplifier
I got power and it hits but then after a bit it stops and red offset light comes on? whats that mean
The amp is overheating it doesn't have a built in fan. This will be more occasional in the summer months. The best solution is to build a box and buy a few computer fans, install a fuse link run the positive of the fans to a remote wire and ground the fans to the chassis of your vehicle. You need a way to recirculate the air inside your amp. I've decided to remove the bottom plate of the amp, mount the amp on a board. Cut holes out of the board and have one fan flipped to pull hot air from the amp and two fans to push the air away from the amp.
You can buy the Antec and Rocket Fish fans for under $15 from Best Buy.
Jul 29, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
Is this a good amp
I classify this as a sleeper of the car audio industry. it is powerful, well built, cheap, feature laden, sounds great! very comparible to the big names such as kicker, alpine, fosgate an all the rest. i would prefer this amp over any of them any day of the week! here are the specs for it incase u didn't have them.
  • Max. Power Output: 800W x2Ch.= 1600W @2 Ohms
  • Power Output:
    • 330W x 2Ch.(@2 Ohms) Less Than 0.5% THD
    • 220W x 2Ch.(@4 Ohms) Less Than 0.3%THD
    • Bridge: 660W x 1 Ch.(@4 Ohms) Less Than 0.5% THD
  • All Measurements Done @ 14.4V DC, 1 KHz Input Signal.
  • Dual VU-Meter
  • Dual Fan Cooling System.
  • LPF (Low Pass Filter) Variable 30Hz-250Hz
  • HPF(High Pass Filter) Variable 50Hz-l KHz.
  • Slope Adjustable 12-24dB.
  • Variable Bass Frequency(30Hz-120Hz).
  • Variable 0-18db Bass Boost.
  • High & Low Adjustable Level Input.
  • Dual LED Indicated Power Status (Protect/Power).
  • Mosfet DC-DC Switching Power Supply.
  • Built-in Protection Against Short Circuit, High Temperature & Overload.
  • Auto Power On/Oft By Remote (+12V).
  • Dimensions(mm) : 300(W) x 57(H) x 697(L)
Apr 04, 2010 | Rockwood 4224RTX Car Audio Amplifier
Does the Alpine CDA-7894 have a fan built in the rear of radio? Would it be visible? I see the opening but no fan. I am curious if this is normal for the CDA-7894. Every Alpine i have ever owned had a fan...
Hi my names Josh i was reading some info on your unit. Thats a very nice unit was made in 03 and had alot of really nice features on it however if your looking for fan that unit was not equiped with one that slot in the back is not actually a fan but part of back plate design of the unit.
Mar 06, 2010 | Alpine CDA-7894 CD Player
Need replacement fan for A4002T Amp
Just go with the lowest amp draw fan, 12 volt that they make, and that should work.
Jul 06, 2009 | AudioBahn A2002T Car Audio Amplifier
I have a rockford fosgate x7 amp and the fan stop working and a little while after playing it shut off what do you think
replace the fan in the amp, sounds like the amp is overheating and the cut off is kicking in... you can try the amp while not driving and the car parked, put a fan, like a desk fan where the amp is so it flows over the amp fins, and run the amp turn it up and let it work, see if it still shuts off after that, if so then it could be something internal nut sounds like it is the fan to me... and i have worked with many an amp and system in cars and trucks... hope this helps you
Jun 25, 2009 | Rockford Fosgate Punch P5002 Car Audio...
KENWOOD KAC-7201 Light flickers ..and fan turns on -nothing works
I had a kenwood amp that did almost the same thing. Try checking you zener diodes. I found 2 bad ones and replaced them and amp works fine ever since. If your not to good at diagnosing, I have my own business installing car audio/video products as well as amp repairs. I gaet amps from all ove the place. If interested send me a message, I'll be glad to help. One more thing, I'm the cheapest person in amp repair. Good luck
Apr 20, 2009 | Kenwood KAC-9152D Car Audio Amplifier
Amp heats up and goes into protect mode
Hi Saint108. You're describing it well, and i know what the problem is already. The MA audio amp, can't hold with a 2 ohm load. It's too low for that amp, that's for sure. Those are budget amps and they are not well built enough to handle low ohm setups like that. It's overheating and there's no ways around it.. Other than wiring your subs differently ! Just wire your sub directly (not in parallel) in a 4 ohm load, you will notice it will stop overheating that much. Do it quick, you'll most likely fry your amp giving it such hard work !! The HUM you're hearing could be related to it also. Try that, and keep me posted on the status. Thanks ! Cheebster.
Jul 02, 2007 | MA Audio Hard Kore HK-898 Car Audio...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
