Question about Water Water Heaters
Bradford White 40 gal water heater,works fine, but has started whining when not in "low" setting. Seems to only do it during showers, or when temps drop outside etc. Only lasts a few minutes
    Top Expert:
  • Water Master
  • 47,827 Answers
It is possibly a high frequence '"water hammer" from a failing tap washer
call a plumber to replace all the tap washers especially the shower hot water tap washer
water hammer is when the water flow is intermittently interrupted ( (normally as banging pipes) but when it is fast it appears as a whistle or squeal
Posted on Dec 18, 2016
Reduced Hot Water
Water heater 14 years old, probably has never been flushed, Flush recommended at least every 6 months, Build up inside tank may be to late to flush, but you can try or replace heater.
press the helpful button
Feb 11, 2016 | Element Water Heaters
I have a 640dors reliance capacity40 water won't stay hot long(electric)
remove the two covers one high and one low and set the temp higher. This time of year with colder water comming in the house the water heater has to work harder to raise the temp of the incomming water. In the summer the incommong water is much warmer. 40 gal is a small water heater and you will only get about 15 gal of hot water with the ice cold water entering the water heater as you use the hot water. You can get a bigger water heater. even better is to go tankless and a have never ending hot water and save money at the same time.
Jan 10, 2013 | Reliance & 40 Gal Electric Mobile Home...
BRADFORD WHITE 40 GALLON ELECTRIC WATER HEATER MODEL M240S6DS-1NCWW.. PROBLEM : I WAS ONLY GETTING A FEW GALLONS OF HOT WATER FROM HEATER. FIGURED ONLY TOP ELEMENT WAS HEATING SO BOUGHT TUNE UP KIT AT
Doesn't sound like its the dip tube, its a element problem, I would contact bw directly to see if heater is stil in warranty and they will send you new parts free.
Dec 18, 2012 | Bradford White M240s6ds-1ncww 40 Gallon...
My plumber refers to the gas hot water heater that he wants to install as a "Standard" water heater. Do you think he means "American Standard"? Mac
i think since "tankless" water htrs entered the market...your plumber referring to a standard w/h means a storage tank wtr htr(stores 40 or more gals) ..most popular brands are a o smith rheem bradford white
Nov 28, 2010 | American Standard 40 G Natural Gas Water...
I have a bradford white 40 gal gaswater heater.the pilot will not stay lit.after i light it it fires right up and runs untill it reaches the set temp.then needs to be relit
just the week i repaired a b/w w/ same problem need to replace the temperature control (part where all the lil tubes connect and button where pilot is...shud be on 800 number on w/h or go online www.bradfordwhite.com and enter serial no. might still be under warrnty if not probably cheapr to get new water heater
Nov 18, 2010 | Water Heaters
Water will not stay hot long enough to shower...not familiar with any of these thermal expansion tanks and can't find any info on vacuum relief valve---40 gal water heater is 18 months old....any...
Turn the gas knob up. There's a dial on the front (probably red) and it will have settings on it. A B and C. Turn up to desired temp, but be careful of faucets if there are children in the house. Good luck
Dec 30, 2009 | Rheem 40 Gallon FVR NATGAS Low WATER...
Warm water only
You can eliminate the shower control knob possibility by turning on your hot water anywhere else in the house. If you get hot water in other places, then it could be the knob causing it. A substantial lime buildup in the tank can also cause poor heat transfer from the elements to the water.
Sep 16, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Whirlpool Energy Smart water heater not hot
I think some one mis informed you, the normal temp on any water heater from the factory is 120, it should not go above that for reasons of sevear burns, as far as it't smart part it's just a name, you will lose a couple of degrees just comming torm the tank to the faucets, the water heater will allways keep the temp in the tank at what ever it is set at, it doesn't have the brains or computer to know what time of day it is but when the cold water comes in to the tank it comes thru a dip tube that goes to aprox 1 inch from the bottom of the tank, if you take a long shower and do not have a energy efficant shower head you can use up to 5 gals, per min of hot water where an energy efficant one only uses 2.5 or less and still has the same pressure at the shower head, the temp in your water heater tries to stay at the setting it is at depending on how much is used at one time meaning washing machine, filling tub or dishwasher at the same time, it lets more cold in as the hot goes out and as you know it can only heat up so much at a time and the cold water is just going across the bottom of the tank, so the name is just that no diffrent then any other water heater unless you went to a tankless water heater.
May 29, 2009 | Water Heaters
Water Heaters Logo
42 people viewed this question
Top Water Heaters Experts
vince
80stech
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
