What in the heck is spose to plug into this pilot light(i think its called) mounted on the front rack on my 87 moto4 350
    Habit-Forming:
    New Friend:
  • 52 Answers
Its just a 12volt accesory plug you can use it for a winch extra lights or charge your phone i changed mine to a cigerete lighter
Posted on Dec 17, 2016
Why does the flame shoot out after the pilots already on when coming on. It makes a wolf noise I have propane gas heater. I think it may be the thermocouple
The pilot light may mount too far from the main burner. When call for heat, gas valve open to let gas flow but pilot mount too far so a delay to fire may take place. when Burner actually fires, a in -rush will blow out the pilot flame.
Jan 02, 2018 | Heating & Cooling
Where is the pilot light on a Goodman LP furnace CAPF1824B6CA
I could not find that exact model but I don't think it has a pilot. I think what you have is a faulty igniter.(its a glow plug)
You need to find it-should be on rt side just in front of a burner venturi. Unplug it and check for continuity.
Dec 24, 2014 | Goodman Heating & Cooling
Where is my pilot light for kenmore 317B6442P001
it shouldnt have a pilot light
there is a hot surface igniter under the pan below the racks
two screws in the back then lift from back (tabs in front)
is the oven not working or lighting?
you cant light with match or lighter
if you are having problems lighting change the igniter
simple to do 15 min get part un piug old plug in new
Nov 18, 2013 | Kenmore Ovens
Trying to install Sunlite HD tourer rear carrier #45772. on a Rand 18 speed. There are no holes for front brackets in frame. Do you just drill the holes?
Never drill holes in a bike frame unless you have a death wish. "Rand 18-speed" doesn't tell us much. Most cheapo bike frames have a 'brake bridge' with a hole on the center for mounting accessories like fenders. Many racks can mount with a single rather than double front supports.. Lacking that, call a bike shop or web search for "bicycle seatstay rack clamps" to adapt the rack to attach to the seat stays.
Sunlite also makes a seatpost rack mount http://www.bikebagshop.com/sunlite-rack-mount-seat-post-clamp-p-1146.html?gdftrk=gdfV22203_a_7c1316_a_7c5544_a_7c11461678151 which looks like a more elegant way to solve the problem.
Sep 13, 2011 | Cycling
When turning on my deLonghi wh16lp wall heater the pilot light wil not hold no matter how long I hold itpressed in. I was advise to have a delonghi repair fix the switch. Where can I find a repair shop.
If you cannot keep pilot light lit after you release pilot button it's probably a bad thermocouple.If you feel capable of attempting repairs your self you can follow thermocouple line from gas valve to mounting postion in front of pilot light burner. both will be located inside burner compartment. The line for thermocouple will usually be mounted on bottom of gas valve on left side Standard thermocouple will be solid copper line that will screw into gas valve. Usually they will be held in position in front of pilot burner by friction fit. Carefully unscrew from gas valve and remove from pilot burner. Measure length of thermocouple and purchase one of same lenght from hardware store such as True Value. Follow instructions for reinstallation being careful not to cross thread fitting to gas valve.As always when working with gas appliances turn thermostat to lowest setting or shut off gas valve if available.If you don't feel comfortable trying this yourself you should call service company. Be careful and I hope this helps you. Thanks.
Nov 05, 2010 | Heating & Cooling
Williams 3003622 Wall Mounted 30,000 BTU The pilot light goes out when the main flame shuts down. The pilot light will stay lit for days when heat is not called for but when heat is called for the furnace...
I'm having the same exact problem... At first we thought was the vent... but the way the flames goes out... it seems that there is "not enough oxygen" more than "blown out by the wind"... right after both main & pilot goes out, I can't even light any external flame inside the chamber... and it doesn't feel like the outside cold air coming in... it just feel like there is some sort of gas in the chamber that's so strong, it prevents flame... and the only thing I can think of is that it doesn't have enough oxygen, but too much natural gas, and flame can't sustain.
Nov 02, 2010 | Williams 3003622 Ceramic Wall Mounted...
I don't think my pilot is lite. I need to know How to light the pilot
Hi, open the front panel of the furnace, At the bottom of the furnace you will see a gas valve with a red button, or nob of some kind. Place the nob on pilot, then push in and light the gas coming out of the pilot don't let go of the button for at least 30 seconds because the sensor will not detect flame. If this dose not work you make have a bad gas valve or a bad pilot generator.
Oct 07, 2010 | Williams (5009622) Ceramic Gas Wall...
Wall mounted CBN30T, pilot goes out
IF its balance flue it could be blocked . Burner or orifice blocked lack of air to pilot slightly blocked thermocouple defective .
Mar 03, 2017 | Desa International CBN20T Heater
Clunking noise in front end on 02 Prius
check ball joints and tire rod first the clunking is a tati tale thet your ball joints are shot
May 26, 2009 | 2002 Toyota Prius
Cannot clear red status light on Compaq rack mount UPS
According to the manual I have, that is a site wiring fault. It means that there is no ground on your AC line coming into the unit.
If you e-mail me, I will send you the pdf of the manual.
Dave
daved07_jd@yahoo.com
Jan 23, 2009 | Compaq R1500 ( 295459-001 ) UPS...
Heating & Cooling Logo
22 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
