Question about Garden
How to replace belts on Snow King snowblower - Garden
  • 10865 Answers
SOURCE: My Tecumseh Snow King 8HP
In order to start it with an electric cord you must have a feature called an electric starter. If you dont have the electric starter on your machine now, one can be added at a dealership
Posted on Mar 29, 2009
  • 61 Answers
SOURCE: I need parts manual for MTD Snow King Snowblower
on the internet try
mtd.com/manuals
Posted on May 29, 2010
  • 150 Answers
SOURCE: Ariens SnowBlower I recently blew a
Hi dwva, I think you have the belt on properly seeing the other gears work fine. The difference between 1st and reverse can be as little as 1 half in on the drive wheel. It depends on which side of center is the friction wheel riding. Remove bottom pan with the machine in 2nd or 3rd gear notice which side of center is the friction wheel riding. (the friction wheel is the one with a rubber outer ring). Now put it in 1st, is it on the same side of center? There is an adjustment on that linkage, adjust so in 1st is on the same side of center. Happy New Year, hope that helps.
Posted on Dec 29, 2010
Testimonial: "Thank you for the advice worked perfect"
kel1guy2002
  • 3740 Answers
SOURCE: Cannot start Husqvarna HSK 70 Snow King snowblower
Hi and welcome to FixYa, I am Kelly.
I am assuming that you have alred checked the ignition spark. If not please do so by removing the spark plug and re-connecting the plug to the high tension lead then pull the recoil through with the ignition on. You should see spark across the electrode AND to ground.
I suspect that there is debris in the carb float bowl and jet orifice. This requires that you remove the float bowl nut and float bowl. NOTE the gasket on the top of the float bowl and how it is installed AS you REMOVE the float bowl. Clean out the float bowl and in the threaded are of where the bowl nut screws into there is a brass orifice. These get a tiny speck of debris in them and they will not allow the engine to draw fuel into the carb passages. The orifice can be removed by using a thin bladed screwdriver and some will power to initially remove the orifice. Hold it up to the light. You should see a pin hole in the orifice. No pin hole visible = clogged orifice. Use something like a tooth pick to remove the debris and DO NOT poke anything into or through the orifice hole. Just clear the orifice hole.
Here is the manual for your engine.
http://www.cpdonline.com/692509.pdf
See figure 58 on page 25 for carb break down. Repair procedures preceed page 25.
This should get you going again. If not you have the manual but I wam willing to help you with any questions you have down the road. Just respond here and I will gladly assist you.
One last thing... make sure the fuel selector is on and that you have fuel to the carb manifld connection. Things like the fuel filter and fuel tank outlet port can be clogged.
Thanks for choosing FixYa,
Kelly
Posted on Jan 26, 2011
  • 91 Answers
SOURCE: can't get a bead on tire
Wrap heavy rope centered around the circumference of the tire and tie it securely. Place a bar or box wrench between rope and tire. Turn bar in either direction which will synch the rope and collapse the center of the tire, forcing the bead to seal with the rim. Fill with air. Works every time
Posted on Mar 19, 2015
MTD Mastercraft Snow King Snowblower (1997) electric starter stopped operating today (during a snow storm of course). Any ideas? Thanks. Checked cord - good condition. Power to the chord. David
It was running and stopped while using or it worked one day but not the next?
The Machine stopped running or just the electric starter? If just starter check to see if snow/ice built up around starter button.
Jan 06, 2017 | Garden
I have an MTD single-stage snow blower that I replace the other the cable and the belt and under a load it's still not throwing snow
There should be 2 holes on the handle that engages the auger belt, use the top hole as it will increase the belt tension.
Check the condition of the rubber auger's rubber paddles as they are subject to wear and should be replaced if any signs of excessive
wear is present.
Jan 31, 2016 | Craftsman 21" 179cc* Single Stage...
Snow keeps getting stuck & doesn't shoot out, even if the snow isn't heavy, after several
View Comment - MovingSnow.com
movingsnow.com/.../craftsman-88395-30?-277-cc-two-stage-snow-blow...
Oct 14, 2015 - 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer at $1049 (minus ... If you do get something stuck in the front end - yes it will slip the belt.
Cheap 2 stage Snow Blowers - There are a few good ones ...
movingsnow.com > ... > 24 in Craftsman 88172 179 cc
Nov 7, 2014 - Sears carries other brands besides Craftsman but they are all not as good of ... Briggs and Stratton 1696610 Dual-Stage Snow Thrower with 208cc ...Subscribe to our mailing list and get interesting stuff and updates to your email inbox...... up to the 28 inch 28 In 277cc* Dual-Stage Snowblower w/ EZ Steer.
Dec 29, 2015 | Craftsman 28 In 277cc* Dual-Stage...
MTD Snow Flite model 316230500. Where can I get belts?
I have already answered you twice with this information!
They have there own forum.
http://www.snowblowerforum.com/forum/mtd-snowblowers/1397-mtd-snow-flite-snow-blower.html
You don't need the part number, you just need to measure the length, or you can phone and say;
I have a snow flite brand snow blower model.316230500. Serial no.811262, send me a belt for it.
All the belts are here
http://www.jackssmallengines.com/equipment/mtd/snow-blower/belts
and here
http://www.mtdparts.com/equipment/mtdparts/parts/machine-types/snow-throwers
Dec 24, 2015 | Garden
My Ranch King 26 inch Snow King Snowblower suddenly started leaking gas from under the gas cup, where there is a single bolt attaching it to the bottom of the carb. Just a bad leather gasket around the...
Sounds like a gasket. Mine did that and I never had the gasket in place when I put it together. Make sure the bolt has the right washer as well and don't over tighten.
Mar 06, 2015 | Garden
Snowblower will not throw snow as far as before.
two things to do. One, get the carb service and have them check the governor.
Two, have the auger belt replaced.
Dec 27, 2012 | Garden
I have a snow king 5hp snow blower. while clearing snow, the snow only oozes out the shoot.
IT SOUNDS LIKE YOU HAVE A TWO STAGE SNOWBLOWER WITH ONLY ONE STAGE WORKING. I BET THAT YOUR PROBLEM IS THE AUGER IS TURNING BUT THE IMPELLER BLADE THAT IS BEHIND THE AUGER HAS PROBABLY JAMMED UP WITH SOMETHING AND IS SPINNING ON THE SHAFT. YOU WILL HAVE TO REACH BACK AND GRAB IT AND TRY TO TURN IT ON THE SHAFT BY HAND.MAKE SURE THE BLOWER IF OFF!!!! . IF YOU CAN TURN IT BY HAND EASILY IT HAS EITHER BROKE A SHEAR PIN OR BOLT OR SOME TIMES THEY WILL TACK WELD THEM TO THEM TO THE SHAFT. GOOD LUCK
Jan 17, 2011 | Tecumseh 5hp Engine Snow King Mtd Blowers...
Snowblower slower/no blowing force.
Electric motor may have a shorted winding, better would be the belt is slipping...... Sparks tell other wise.....
Feb 10, 2010 | Kitchen Appliances - Others
Tecumseh Snow King HS40 engine only runs on full choke, no power
i did and thanks - just picked up one that does the same thing and i plan to take your advise
Thank you Jerr
Jan 01, 2009 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
