Question about Cell Phones
Incoming text doesn't come - only to/from and storage. Gray background, blue letters
2 Suggested Answers
  • 5 Answers
SOURCE: how to change text size and colour on an Nokia E50
download font software
Posted on Dec 26, 2008
Kyocera 3035
I guess you mean you are getting background gray or letters way too dark. If you are getting background gray then the drum needs to be replaced. If the letters are too dark but no background then use the lightness setting and decreases it.
Printer Repair Service in Miami and Fort Lauderdale FL
Feb 12, 2016 | Kyocera Office Equipment & Supplies
Windows run doesn't keep my work history
you have to physically save any work
save the history to a usb drive in case you have computer failure
Plug the flash drive into your computer's rectangular-shaped USB drive.
Wait for Windows to recognize the system.
Windows operating systems use "plug and play" technology, which means that computer peripherals like USB flash drives can be recognized instantly by the system without further need for device configuration.
Open the drive on your computer.
Open the "My Computer" directory if using Windows XP or the "Computer" directory if using
Windows 7 or Vista. Locate the flash drive letter and icon under the section named "Devices with Removable Storage." Double-click the flash drive icon to open it.
Transfer files to the flash drive.
Click the "Restore" button in the top-right corner of the "Computer" or "My Computer" directory to shrink the window so that you can view your computer's desktop background.
Open the folders or locations of the files which you want to save to the flash drive.
Click and drag with your mouse each of the files and folders you want to save to the flash drive over to the empty space in the "My Computer" or "Computer" window.
Release the mouse button to let the files "drop."
Close the windows and directory locations when finished.
Save files directly onto the flash drive. From an open file (i.e. text, spreadsheet, image files. etc.), click the "File" menu and "Save as" option.
Select the "My Computer" or "Computer" directory in the drop-down menu at the top of the "Save As" box. Double-click the flash drive letter under the "Devices with Removable Storage" section.
Click the "Save" button to save the file onto the flash drive.
Close the windows and files when finished
hope this helps
Oct 17, 2012 | Microsoft Windows XP Professional Full...
Does anyone know why my mic doesn't work and my desktop background doesn't show?
If you have Windows 7 Starter then you are limited on changing the background.
Jun 09, 2012 | Computers & Internet
My hitachi 53udx10b was supposedly just serviced but the picture is extremely blue. Have tried adjusting picture to no avail. Help.
I am going to tell you a simple thing to do to know what your problem may be.
With the set on turn the color all the way to zero. Go to a channel if you can that is in black and white. What color is the screen?
If the answer is that it is blue in the background whoever serviced the set did not and could have removed front speaker grill and inspection plate behind it; there is a black plastic block with three screen controls (red,green,blue) and 3 focus controls (do not touch the focus ones.)
I suspect if the blue screen is there a slight adjustment of the blue screen down will correct this.
The picture with the color at zero should be black and white or gray. If blue is background color it will also be with color.
This is called gray scale; picture with color off has to be gray or black and white.
Before you rate this solution if you have questions make a comment right here and I will advise you.
SD TECH
Jun 29, 2011 | Hitachi 53UDX10B 53" Rear Projection...
My magicard alto prints fine except the color quality is not very great. when i use the color ribbon and print black letters with it the letters come out gray and not black and it has a problem making the...
The printer driver must be set to print text with the K resin panel.
If the text is part of a bitmap image and not a true-type font then it will print from the coloured panels and be dark grey.
To create the correct green on the card you need to change the RGB values so it prints correctly but look wrong on the badge design program. Even different printers print the same colour differently.
Jan 29, 2010 | Magicard Alto Card Printer
PSC1510 & Vista problem
The problem cannot BE solved. It's yet ANOTHER Vista screw-up.
Original Problem:
"No matter what I try - every page from Jarte prints out with an UNWANTED gray
background.
This does not always happen when I print from the web, make copies or print from
Microsoft Word. I ran diagnostics on my printer HP PSC1510 and it's fine.
Test pages print ok, too.
Please help - I had Jarte on my last laptop (Windows XP), it worked very well
and I liked it much better than MS Word."
I emailed Jarte Tech support and got the following answer:
"The problem you encountered is a bug in Windows Vista. You will see the same problem when using WordPad on Windows Vista. As you have noticed, not all programs are affected by the bug. The problem is occurring because you are using a Windows color scheme that uses a gray background color for text windows. Unfortunately, the only work around is to specify white as the background color to use for text windows. Hopefully, Microsoft will correct the problem in a future Windows Vista service pack."
Bob Flora
Carolina Road Software
Jul 14, 2008 | HP PSC 1510 All-In-One InkJet Printer
When printing a scanned object, paper is all gray
Whatever scanning utility you are using, set it to Black and white, not grayscale nor colour! regards, babb
May 05, 2007 | Umax Astra 610P Flatbed Scanner
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
