Question about LG 60 60PZ950 3D Plasma TV
I have a LG 60pz950 Plasma was working fine, now you turn it on you see the tv is on but no picture also if you select tv source etc nothing shows on the tv screen you would usually see the tv menu.
I tested the fuses and all work fine.
  • 15 Answers
SOURCE: 42 inch LG Plasma TV - Lost picture
ysus pcb that supplies voltage to the panel is faulty
Posted on Dec 15, 2007
  • 3 Answers
Our LG 50" plasma tv screen went black after a popping noise but still had sound, after great diliberations decided to take the back off and have a peek!
We unplugged the tv and tested the fuses (there were three we could see) one had blown, the one on the left as you look at the back of the tv it also has one above it. We wrote the code/seriel number down and took the fuse to the electrical wholesalers Maplin and bought a pack of 10 fuses for £1.29 replaced the fuse in the tv and everything now fine!!!!!!
Hope this might be of use to anyone whose lost the picture after a loud popping/snacking noise but still has sound.
Posted on Jan 17, 2008
Hi , I recently had the same problem which I was determined to fix . So I did a few weeks of research to find that it was the Y SUS board which burns out. I'm sure you realized that the TV gets hot. Personally I think this is why. circuit boards don't like heat and I've learned that the cooling fans are a joke. I replaced the board and got my picture back. I proved the fan theory because after the screen started to act up. I placed a cooling fan near the vent holes on top and the problem cleared right up,It also helps if you lower the brightness which helps out on the heat situation.I will soon be adding a fan with a temp. sensor. This shoud help if your screen has lines when you initially turn the cool TV on.then I have Some other costless solutions. Hope this helped these are great TV's and like our cars we maintain them not throw them away..................................Mr Wiseman
Posted on Jan 30, 2009
  • 12 Answers
Most likely what happened is one of the capacitors went bad. When a capacitors goes bad it produces a popping sound. This could be an easy and cheap fix if you find the bad capacitor or capacitors. The bad capacitor will have a bulging top most likely on the power board but could be anywhere.
Posted on Jul 07, 2009
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
Fix my plasma tv
Check out the video below and familiarize yourself.
Although it may not be exact model.
Plasma TV Repair Tutorial Common Symptoms Solutions How to Fix Plasma TVs
Then start research on symptoms, required parts.
Apr 10, 2016 | LG Infinia 60PZ950 60-Inch 1080p 600 Hz...
LG TV 60PZ550 black screen no pic or sound green lit flashing it has back lite
LG 60PZ550 Plasma - No Sound, No Picture - Badcaps Forums ... > ... > Troubleshooting TVs and Video Sources
Sep 15, 2013 - 20 posts - ‎4 authors
LG 60PZ550 Plasma - No Sound, No Picture Troubleshooting TVs and Video Sources. ... I see no change in the screen at any point (no glow). With the rear cover ... I've worked with some electronics in the past, but am new to TV's. I'm sure .... Multimeter on DC 1000V, red on (+) marked, black on (-) marked. Lg 3d plasma 60pz550 i've got sound but no picture
Jul 18, 2014
LG 60PZ550 color issue - Badcaps Forums
Jun 9, 2014
Purple/Pink Lines / Postering on plasma LG 60PZ550
May 29, 2014
LG Plasma 60pz550 has strange greenish rainbow ...
Jan 20, 2014
More results from
Jan 10, 2016 | LG 60PZ550 3D Plasma TV
My 60" 3D LG Plasma Model 60PZ950 is displaying an oval of rainbow colors, which seem to switch to different parts of the screen, i.e. top/bottom/corners etc. What causes this?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 08, 2015 | LG Televison & Video
Samsung Plasma TV has standby power but no video
Make sure your video and sound cable is working (rca, hdmi cable etc) and your source component like dvd player or settop box is working. If cable is plug into a socket AV 3 or HDMI 3 for e. g. make sure the tv is source or input is selected the same like AV 3 etc.
It is possible for the TV to switch on or off but no picture or sound. This means the input board or tv tuner is faulty in which case you need a good tv repair technician
Oct 26, 2015 | Samsung PN43E450A1FXZA PN43E450 43 720p...
Why would sound come on the TV and picture not appear on some occasions?
Good evening to you. Try going to menu> picture>brightness>
remember to push enter after each move.
Sep 12, 2014 | LG Infinia 60pz950 60-inch 1080p 3d Ready...
50 inch LG Plasma tv picture wont work
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. There are more than 1200 posts to different brand TVs now. Pull up older posts there.
Nov 14, 2012 | LG 50PX5D 50 in. Plasma HDTV
LG 42 PG2 hdmi issues
TV simultaneously for 10-15 seconds.2. Enter Tool Option 23. Turn HDMI on by selecting HDMI and pressing RIGHT buttonYou've done.
Jul 11, 2012 | LG 42PG20 42 in. Plasma HDTV
My lg 42pg20r ta was working fine and was on overnight (KIDS!!) and in the morning the tv was turned off and then an hour later turned back on and there is no picture at all.The sound works fine but no...
Hello kurzty, please use the INPUT button located on either your remote or on the TV UNIT to change the existing input station/video. Keep cycling through the input selections until you see the regular programming again. If you can at LEAST see the menu pop up on the screen, you know nothing happened to your projection device. which means your NOT going to have to pay several HUNDRED bucks for a repair if your not under warranty. Write back if you have any more problems. My username is bbl242003
Jan 09, 2011 | LG 42PX5D 42 in. Plasma HDTV
Picture will not come on.
I found this in the user manual. From what you've said I would check the second paragraph first. I hope this works for you.
On your computer check; Power, Signal Cable.
The TV is using its power management system.
Move the computer’s mouse or press any key on the
On your equipment check (STB, DVD, etc) ; Power,
Signal Cable.
Press the Source button on the panel or remote control.
Turn the TV off and on.
Sep 24, 2008 | Samsung HP-R4272 42 in. Plasma HDTV
LG 60 60PZ950 3D Plasma TV Logo
26 people viewed this question
Computer Repairing
Computer Repairing
