Question about In Microwave Ovens
Will I have ruined the microwave if I forgot to put the food in the oven and made it cut out?
I forgot to put the food in the oven. After 2 minutes on high the power failed and there was no response - as if unplugged.the exterior top panel was very hot. After 5 minutes it bleeped and was back on but I didn't use it again.
  • 2,290 Answers
Its possible you could have burnt it out. You also may have blown the fuse which should be inside the cabinet. Before you do anything get a container of water and try to heat it and see if the machine works.
The microwave may have to reset itself. If it appears to work I would use it. If it shuts itself off then you have a problem but its probably cheaper to get a new one than to repair.
Posted on Dec 17, 2016
  • Jan Anderson
    Jan Anderson Dec 17, 2016
    Operating normally again. Seemed to my layman's eye like a safety cut out but can find no report of such. Grateful for your reply, safety always a concern.. Many thanks. Jan
Why can't you run a microwave without anything in it? What happens and can you fix the problem? I forgot to put the food in and ran it for 4 minutes with nothing inside. Now it won't heat any food.
A microwave oven works on the principal of a high power high frequency radio transmitter. The device that emits the microwave energy is a tube called a magnetron . When you run the microwave empty with nothing to absorb the microwave energy it is all reflected back to the magnetron causing it to overheat and destroy itself or cause failure in the High Voltage power supply due to excessive current draw.This is caused by standing waves.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
Where is the high voltage fuse on a microwave
The thermal fuse monitors the magnetron temperature and cuts power, if it gets to hot and resets in no more than 20 to 30 minutes. Unplug microwave oven, remove top, "several screws" look over to the right, thermal fuse is mounted on top on the inner chassis, "round and thick with 2 wires clipped on"
Apr 16, 2012 | Jenn-Air JMC8127DD Microwave Oven
Microwave shut off completely
Microwaves have an inline fuse inside that fatigues over time.Take the cover off,follow the power cord after it enters the housing to locate the fuse.
Mar 14, 2012 | Amana MVH220W Microwave Oven
Food left in the oven has left a smell even after thorough cleaning.what action should i take
Have you tried putting a microwaveable bowl with a mixture of water ,vinegar and some slices of lemons or oranges in your micro for about 2 minutes. It should help eliminate the bad odors and leave your microwave smelling freah and clean.
Nov 10, 2010 | Panasonic NN-H965 Microwave Oven
A visitor to my home used the microwave as a timer for 15 minutes. She didn't use the "timer" button. She turned on the microwave as if to cook something without anything being in the oven. Now the oven...
Without a load (food or water) to absorb the microwave energy the microwaves will bounce back into the waveguide and on to the magnetron antennae causing damage. Usually there is a lot of arcing and noise when there is nothing inside the oven cavity which alerts you to the problem. I cannot say for sure if it destroyed the magnetron.
Jun 23, 2010 | Kenmore 80012 Microwave Oven
Cuts out everytime you put food in, any mode any food, then displays sensor on panel displayed. May run for a few seconds then cuts again Rob.
It could be either the magnetron thermostat or the cavity thermostat would be faulty, depending on the microwave but in most cases it would be a thermostat.
First of all you can try cutting the power to the unit for 5 minutes, then retry it.
Call 800-626-2005 GE costumer care You will probably need to provide your serial number when you call so be sure you have that ready.
Good Luck!!
Oct 16, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave oven H-4020 BM...... How to clean inside????? I am unable to get the stains off and inside looks terrible.
First, wipe out any excess crumbs. Then fill a microwave-safe bowl with about 1-2 cups of water. Add some lemon juice, or put in half a piece of fresh cut lemon (squeezing some juice out first) into the bowl... Microwave until the water is boiling. Then let it sit for a few minutes to let the steam penetrate the interior. Carefully remove the bowl and interior tray. Wipe down the interior with a damp cloth. Wash the tray in the sink with dish soap, dry, and then return to microwave. For the outside, spray with a kitchen cleaner and wipe with paper towels. The main idea is that the steam from the water will loosen food particles, and the lemon will add a fresh smell.
Jun 23, 2009 | Miele H187MBALU Convection/Microwave Oven
Does not "heat" food.
The Microwave Magnetron or power circuit break down . You need to replacement the parts .
Good luck
Sep 30, 2008 | Emerson MW8102SS 1100 Watts Microwave Oven
Bought a brand new whirlpool microwave/convection oven 2 months ago. Model GH7208XRS-1. Was using it to reheat food for 2 minutes. Food was not hot enough, so put it in for 1 more minute. When I closed the...
The first thing to try is a "hard reset". Unplug it from the power line for a minute, plug it back in, set the clock, then try again.
If it's still dead, since it's under warranty I would contact Whirlpool customer service for a free fix.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jun 12, 2008 | Whirlpool Microwave Ovens
Microwave Ovens Logo
Top In Microwave Ovens Experts
William Miller
William Miller
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
