Question about Kicker Car Audio & Video
I need box deminsion for 10" kicker cvt for 92 k1500 single cab
    Top Expert:
  • Kicker Master
  • 40,567 Answers
Estimate two cubic feet and calculate dimensions accordingly allowing for structural allowances.
Posted on Dec 17, 2016
3 Suggested Answers
  • 655 Answers
SOURCE: i have a thunderform truck 2 10' sub enclosure for
Hello hperezrod,
Measure from the top of your thunderform to the bottom at the shortest point. You need 5 5/16" to mount the CVX's.
Posted on Nov 11, 2009
  • 116 Answers
SOURCE: what is proper air amount
2.25- 2.50 cu. ft box sealed or ported.
Posted on Jan 17, 2011
Speaker blown?
disconnect the amp and do a "pop" test with a 9v battery, it should be clear and no rattle... if it rattles sub is blown
Jan 29, 2014 | Kicker Comp CVT 12 Car Subwoofer
Would a 10ZX750.1 amp be alright on a Single Solobaric L5 10" inch in a ported box???
yes, the 10ZX750.1 is capable of running two L5's at two ohms in either a ported or sealed box. Just be sure to wire it up to suit your needs correctly (if you need to know how i can help) and make sure that your box dimensions match what kicker specify. the L5 is actually one of the subs that kicker reccommend for that amp.
Hope I helped , and please dont forget to rate.
Jan 15, 2011 | Kicker Car Audio & Video
Have a 92 chevy pick up & the blinkers don't work. looking for fuse box diagram so I can check the fuse
i have a 92 s 10 ,my rado and lighter just went out i checked the fuses and they are fine .whats the problem??
Nov 23, 2010 | 1992 Chevrolet K1500
yeah if u want to use a 2 channel just connect the outside - form one to the amp then the middle + and - together then the other + to the amp
Aug 11, 2010 | DB Drive SPA1000.1 Car Audio Amplifier
How do i wire a 8 ohm kicker comp 10" sub inside the box? and what is the best way to get more bump with a 600 w mtx amp and kicker comp 10" sub?
Ok, for an 8 Ohm sub, it is advisable to get another 8 Ohm sub. wire them in parallel down to a 4 Ohm load. You would wire both + wires together, and both - wires together to yield a 4 Ohm load at the amp. Majority of the amplifiers on the market are designed to give more power at a lower impedence, or Ohm load. You just have to make sure that your amp will take a 4 Ohm load. Without knowing the model of the MTX amp, I can't give more advise. However, this should be able to give you and idea of where to start. The main problem is that you have a single 8 Ohm sub in the Kicker Comp.
Apr 30, 2010 | Kicker CompVX CVX104 Subwoofer - 10" Dual...
Wher/how do I locate the gear ratio for the rear end of a 1990 chevy sportsside single cab, short box 4 x4?
The gear ratio is stamped by code on the rear diff cover, it's actually on a little piece of metal, has numbers on it.I hope i could help.....
Jan 21, 2010 | 1990 Chevrolet K1500
I love bass but cant find a good enough place to get a sub box in, were would the best place be???
i just pugt a 10" sub in my 89 k1500 regular cab right behind the drivers seat, sony, pioneer and alpine all make a box that doesnt affect how far back your seat will travel
Apr 16, 2009 | 1990 Chevrolet K1500
Power Protection Circuit (SORT) Engaged
Umm a ohm meter would help you here. Double check the wires from the sub to the amp...make sure its not shorting out. Try starting the amp without the wires on the terminals...if the protection shows up then there is a short inside the unit and it will need to be replaced/repaired.
Feb 17, 2007 | Kicker ZX400.1 Car Audio Amplifier
Car Audio & Video Logo
61 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
