Question about Home
Sioscan atomic clock model 88909
How do I get outside tempature and should the time be blinking constantly?
SOURCE: atomic clock sky scan model 87801
Press set button repeatedly -you get timezone mode and change your wished time zone and select your zone then press set button to normal mode and adjust the current time. kindly gave your rating after you read this.
Posted on Nov 20, 2008
  • 37 Answers
SOURCE: S10Scan atomic clock model 87310 time is 4;pm should be 10:am
Hi
Time zone setting
Language Setting
The weekdays can be displayed in LCD1 with the pre-set languages: US English, French and Spanish.
1. Set the desired language for the weekday display in LCD 2 by use of the + key.
2. Press the SET key to enter the mode “Manual Time Setting”.
Manual Time Setting
In case the Skyscan Atomic Clock is not able to detect the WWVB-signal (disturbances, transmitting distance, etc.), the time can be manually set. The clock will then work as a normal Quartz clock.
Note:
In 12 hours mode the time will be displayed with an additional “PM” for the time from 12:00 noon until 11:59.
1. The hour digits will start flashing on LCD1. Set the desired hours by pressing the +key followed by pressing the SET key.
2. Now the minute digits will start flashing. Set the desired minutes by pressing the +key . If the + key is held, the units will increase by 5.
3. Press the SET key to move to the “Year Setting”.
Note:
The unit will still try and receive the signal every day despite it being manually set. When it does receive the signal, it will change the manually set time into the received time. During reception attempts the WWVB tower icon will flash. If reception has been unsuccessful, then the WWVB tower icon will not appear but reception will still be attempted the following hour.
WWVB time reception takes place from 12:00 am through 6:00 am each day (attempts WWVB reception every full hour within this time frame). When the time signal is received for example at 1:00 am, the Skyscan Atomic Clock will not attempt to receive the WWVB signal for the remaining hours until 6:00 am. Therefore, the next signal attempt will take place between 12:00 am and 6:00 am the next day. The other times WWVB reception takes place, are upon setup and after manual time set exiting mode. Reception is generally not possible during daylight hours due to the interference of the sun.
for more details see user manual...
Thank you
Posted on Dec 12, 2008
SOURCE: my clock is nort showing up the outside tempertute
Seems to be a consistent problem with Skyscan. I have the 88800 model and my outdoor transmitter isn't transmitting the temperature either. We've replaced the batteries in both the transmitter and clock and nothing for outdoor temp. It's only been used for 9 months.
Posted on Nov 23, 2009
jyackle5
  • 8197 Answers
SOURCE: need help setting the time on the clock it is a
link below will tell you how to set clock. scroll down about half way.
http://www.skyscan.info/content/manuals/15-model-28500.html
Posted on Jan 01, 2010
SOURCE: lost instructions booklet for atomic clock
how do I set the clock for PST?
Posted on May 20, 2010
How to reset time on SioScan travel alarm clock model 31420E
Google (SioScan)(31420E)(manual) without parens to get instructions.
Nov 06, 2016 | Home
La Crosse Model W86111, Setting
an atomic clock ........ no user manual ?
1 Digital Atomic Wall Clock Model: W86111 ' Quick Setup Guide
pdfstream.manualsonline.com/0/0a0678fd-f9df-4e8f-8c98-0b4794c5453c.pdf
User-Manual
content.etilize.com/User-Manual/1031159306.pd
Oct 19, 2016 | Home
How do I reset time and date on SioScan Atomic Clock? I need Arizona time zone - i.e. no daylight savings time
Put it into settings and then adjust time/date. It's not related in any way to temperature.
Apr 24, 2015 | Home
I just found a sio/scan temp transmitter in my flower bed, what is this and do i need it?
You only need it if you have a SioScan atomic clock to read the temperature it transmits.
Jun 28, 2010 | SkyScan 86709 Atomic Wall Clock
My SioScan clock is two hours behind the actual time. Instructions lost. Can I reset it? How?
I searched on "sioscan" and all I could find was "skyscan".Is this your clock?
If it is, you can copy "skyscan.info/content/quick-ref.html" into your search engine, you will arrive at the skyscan web site instructions.
Mar 11, 2010 | Watches
Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Mar 11, 2009 | SkyScan 86709 Atomic Wall Clock
Resetting the atomic clock to the correct time zone, and outside temp to work.
For the Sharp SPC374T Atomic Clock - Time Zone setting- Press the 'Time' button once, the time zone will show where 'Day' usually is, use the Up or Down buttong to adjust.
For the outdoor Thermo, credit to my neighbor for this one. Remove battery from main unit, wait 2-3 minutes. Reload batteries. Once you get a reading from the outdoor sensor, hit the reset on the main unit. You will have to reset the time zone as described above, but this worked for me after 10 months of no outside temp showing up!
Good luck,
Doc
Dec 01, 2007 | Baby Gear
Temperature Transmitter
You need new SioScan Temperature Transmitter 433 MHz. Take a look on amazon La Crosse Technology TX6U Wireless Temperature Sensor for 433 MHz units.... Hope this was helpful. cheers
Oct 16, 2007 | SkyScan 86709 Atomic Wall Clock
Home Logo
112 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
