Question about Miele Washing Machines
How do I open the. Filter on a miele w412 as it keeps flashing up saying check drain but I can't open it u
mgprice
  • 744 Answers
SOURCE: Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Posted on Jun 23, 2009
beltronic205
  • 1474 Answers
SOURCE: check drain keeps flashing and machine wont drain
You need to check fault is not upstream from the filter/ is it the pump? thats jammed due to sock or coin also check hoses leading to the filter are clear..
Posted on Nov 17, 2009
  • 91 Answers
SOURCE: The check drain light on
Hi dear.Related to your explenation: It does have faulty pump but first checked the pump harness.That's important.If every thing seems OK then you can replace the pump.I hope that helps.Thanks.
Posted on Feb 13, 2011
  • 40 Answers
SOURCE: Miele w2240 check drain and check inlet lights
There is water at the bottom of the machine. You could tilt the machine forward until the water dumps out and then the lights will go away. The cause of the problem could be the following: 1. There is a hole in the seal. 2. A hole in one of the hoses inside the machine. 3. Too much soap (the most common), the suds come out of the door and enter into the bottom.
Hope this works for you. Please leave a feedback.
Posted on Feb 28, 2011
  • 251 Answers
SOURCE: miele w435 soft-tronic check drain check inlet
Hi - Try this empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check & assemble - try & see if it will work.
Cheers
Posted on Jul 02, 2011
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele service manuals
http://www.manualslib.com/manual/456712/Miele-W-412.html
Aug 30, 2014 | Washing Machines
Miele Touchtronic w1203 , the intake and drain fault indicator lights are both flashing at the same time
Seems that the inlet valve or water flow is low , check the inlet flow or check for clogged filter.
Also check the lint filter and the cache filter. remove and clean drain pump. This must solve the issue.
Jan 17, 2013 | Miele Washing Machines
MIELE W412 PREWASH INDICATOR FLASHING
If your PreWash is flashing then you have a pressure problem. You can dry using a washer machine cleaner or doing a hot cycle with white vinegar. If that doesn't help the electronic would have to be changed.
Jan 08, 2012 | Miele W412 Front Load Washer
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Optima G2430 Miele dishwasher with intake/drain flashing light
F13 is an inlet fault.
First the unit drains and then fills with water. When the unit has intially drained open the door and manually fill the unit with water, about 5lts. This will then allow the dishwasher to go to the next step which is to circulate the water. If this works ok then the water tap is defective, water inlet valve is defective or the electronic unit is not sending the signal to activate the valve. The water inlet valve is the white square box attached to the tap. Remove this and check the filter and make sure water comes out of the tap.If ok then remove the bottom panel of the unit under the door. On the right hand side there is a 2 core cable with a male and female connector. Unplug this and check for voltage from the electronic when the unit goes to fill with water. If there is 240v then the electronic is ok. You will then need a new waterproof system from Miele.
Feb 27, 2010 | Miele 24 in. Incognito G843SCVi Built-In...
Check drain keeps flashing and machine wont drain even though drain is not blocked. I have removed and cleaned out debris in the drain filter but the problem persists.
Nov 17, 2009 | Miele W865 Front Load Washer
Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Jun 01, 2008 | Miele Novotronic W1918A Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
