Question about Magellan Maestro 4210 Car GPS Receiver
Magellan Maestro 4210 no audio or garbled sound
My 11 month old Magellan Maestro 4210 started sounding garbled early on our holiday trip a few weeks ago. The sound would stop after a few minutes. Turning it off and on would momentarily bring back the garbled sound. Now I get no sound at all. I have checked the diagnostics Audio test without success. I have turned the mute button on and off to rule it out as a problem. The rest of the GPS seems to work fine. Any ideas or suggestions?
    Brigadier General:
  • 4,090 Answers
I suggest you take it back to the seloloer before the warranty expires
Posted on Jul 22, 2009
Tip
Magellan Maestro units Reset button - look at the bottom of the unit , there...
1- Turn off unit.  2- press and hold the bottom right corner of the screen. 3-While still pressing and holding bottom right corner, press and hold power button and continue holding both until a white screen appears with a black dot. 4- follow the on screen directions and your unit will be back to the day you first got it.
on Jan 21, 2009 | Garmin StreetPilot C330 GPS Receiver
Magellan 4210 from texas wont work here in the philippines, help pls thanks
You need to have the Philippine maps installed.
Please dont forget to vote if you liked my answer
thanks
Feb 10, 2011 | Magellan Maestro 4210 Car GPS Receiver
Megellan Maestro 4210 gps slow to find current location
I recommend you to reset it . Resetting should solve this problem .
Here is how to reset your Maestro :
1:Locate the button marked "Reset" on the left, right or bottom of the unit.
2:Using a thin object, such as a paper clip, depress the button for two to three seconds. The unit should reset.
3:If the unit does not reset, immediately press the button again and hold it for up to 10 seconds.
PLEASE DON'T FORGET TO RATE !
Apr 14, 2010 | Magellan Maestro 4210 GPS Receiver
My Magellan Maestro 3210 constantly says low battery while on trip and shutoff, I have it plugged into the astray why would the battery be low, how do I get it off battery power setting, or why is it doing...
Usually when you see low battery like that it means the battery itself needs to be replaced at it can't hold a charge or enough of a charge to be usefull. If you unit is over 18-24 months old then th e battery is most likely the problem. This will happen even if you have always used external power as the battery doesn;t get properlly cycled enough.
It is possible that it is the power source you are using is too low but sounds more like the battery is the problem.
If you have warrenty the battery should be replaced by Magellan. If not a replacement battery is about $30 and is something you may be able to do. You need to remove the back cover and unplug the old battery and plug in the new one and put it all back together.
Here is one link for a battery but there are other just search for Maestro 3210 battery with google or bing and you should find a few places that offer them.
http://www.batterymart.com/c-magellan-maestro-3220-gps.html
Mar 30, 2010 | Magellan Maestro 3210 GPS Receiver
How to update the system of magellan maestro 4210?
http://www.magellangps.com/support/product.asp?prodid=1955
If you follow the link above you should find everything you need.
You may need to register your device, but all downloads and updates are available here.
Jim
Aug 04, 2009 | Magellan Maestro 4210 Car GPS Receiver
Switch from true view to map view on the magellan 3250?
You didn't state your model but on my Maestro 3210 and 4210 it's MENU USER OPTIONS MAP OPTIONS
Jan 12, 2009 | Magellan Maestro 3200 GPS
WILL NOT FIND SATELLITES
Go to the Magellan site and search the support section. Send a detailed question to their support staff, yes I know their slow but if you try Maggie it's like pulling your owne teeth with tweezers
Jan 03, 2009 | Magellan Maestro 4210 GPS Receiver
Magellan Maestro 4000 Audio Problems
the one i have is 3 month old and im having the same problem, the audio is not working (magellan model 3225)
Mar 17, 2008 | Magellan GPS
Magellan Maestro 4210 Car GPS Receiver Logo
220 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
