Question about HP Designjet T1100 Photo Printer
Hp t1100 grinding noise after print
I hear the grinding noise near paper driver roller left side and try to clean the encoder disk but still giving sound
  • HP Master
  • 1,915 Answers
I suggest you run the diagnostics for the printer which allows you to isolate and run individual components. That way you can see which item is causing the noise. If it is coming from the left side, you might have a problem with the cutter.
Posted on Dec 18, 2016
Testimonial: "Dear Mark Cutter is working fine , and printer also working good ,its printing normally and finish the print then cut the paper smoothly then carriage going to home position and paper drive roller taking paper back and that time starting this loud noise near paper drive roller left side"
HP 1315v Printer Makes grinding noise and won't feed paper anymore
It sounds as though a sheet of paper or an envelope bunched up and has jammed inside. Until that is removed from the feed roller, you will continue to hear the 'grinding' sound, and won't be able to print anything. Remove the cover from the backside of the machine, then locate and remove the obstruction. If you don't have any such obstruction then you have a mechanical defect which is not user repairable.
Oct 20, 2014 | HP PSC 1315 All-In-One InkJet Printer
I have proplem with paper jam , so I replaced motoer of model 510 with motor of model 500 . I printed one copy but it didn't complete seccessfully , what should I do ???? The motor of model 510 d
Both Disc encoder & Motor same for 500 & 510... But its not motor fault,
1. Clean Media sensor P/N:C7769-60168
2. Clean disc encoder.
3. Clean drive roller encoder PCB P/no:C7769-60172
Pl share the error message after doing this activity..
Jan 09, 2013 | HP DesignJet 500ps (42 in.) InkJet Printer
Hp officejet pro l7780 all in one printer, Cleaned the pick up roller still not picking up paper
The pick up roller may be worn and in need of replacement. The slight grinding noise is the pickup roller trying to work but slipping
Oct 30, 2012 | HP Office Equipment & Supplies
How do i clean the hp printer's in order to get a clean and darker print?
Print quality depends on cartridge health condition only, especially in inkjet printers.*Print head clogging: Usually white horizontal lines in print outs due to print head nozzles are clogged. Printer it self having self cleaning mechanism to clean the nozzles while printing & powering on..And "clean nozzles" option also designed in printer drivers for cleaning. And last option is manual cleaning. Alcohol is good solvent & best for cleaning the nozzles,use cotton or ear buds to swab on the surface of the nozzles with alcohol gently.. You will get good quality print outs if cartridges are in good condition..(see the snap shots)Other parts to clean: Encoder,disc encoder, service station & rollers needs to clean periodically to avoid malfunctions & paper jams.* Encoder's malfunctions: If any vertical or horizontal crooked print outs observed, clean both encoders needs to clean.. (see snap shot for encoders)*Service station malfunctions: If any carriage jams observed in service station, remove & clean it ..(see the snap shot)*Rollers malfunctions: If media is not picking up properly it causes jamming error,clean or replace the rollers..
Dec 31, 2011 | HP PSC 1315 All-In-One InkJet Printer
Printer cuts off print at top of page in spite of over 1" margin and every 3rd or fourth line of print in document is very weak (not much ink)
Hello
Well are you using the external ink-system? even if you are not the disk encoder and the encoder strip needs to be cleaned. Encoder Strip is the plastic strip connecting from left to right inside the printer near the belt. In the same type of plastic there is an Disk encoder on the left side of the printer you can find it if you open the printer only.
Jul 23, 2011 | HP OfficeJet Pro k550 Printer
Problem with Deskjet 895cxi
You may open the rear door to check for any paper jam in side
or if it still gives error rotate the roller in upward direction till you get one locking sound, restart printer and check printing
if you still find grinding noise from printer, its pickup roller gear may be worn-out generally and need to be replaced
contact service person for further repair
Nov 08, 2009 | HP DeskJet 895cxi InkJet Printer
Officejet 6210 noisy rollers
i believed this issue is on the mechanical side of the printer.if the grinding noise is very noisy if you still have the warranty of the printer you can go ahead an ask for the replacement of the printer coz it is an issue with the mechanical part of the printer..
Aug 28, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Major problems when trying to print, Jamming alot & grinding noise
If the paper is an accordion type jam, you should replace the 4 small rollers, the upper feed roller, the upper feed guide, and the lower rollers. all of these are listed on hp's part surfer website.
RF5-0425-040cn, RF5-0434-000cn, RF5-0432-000cn, and RF5-0438-000cn respectively. Basically, get a new exit output assembly part number RG5-0456-180cn.
Does this help?
Jul 09, 2008 | HP LaserJet 4 plus Printer
Printer is not working.
There are several things in the front that could be making that noise.The transfer roller,paper guide/top ublique roller and front obligue roller which is on the left side front. It is hard to say. I guess the printer is printing OK. If not what is the printer doing? Do you get any paper jams? Printing light? Can you rub the print off the paper? Any labels stuck? Please answer questions so I can help you. My guess is a roller problem. Which one is hard to say since I can't hear the printer myself.
Jan 13, 2008 | HP LaserJet 4L Printer
HP Designjet T1100 Photo Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
