Question about Apple iPod shuffle MP3 Player
My i pod is not been detected by any pc...no charging lights..it get very hot when connected to usb ...last time before dis problem it showed red light when it was connected to my bed speakers...nd den it stop working..
    Scholar:
  • 151 Answers
If you are trying to charge it, then leave it connected to your computer all night or day, then if that still does not work, you may need a new usb connector for the ipod
Posted on Jul 20, 2009
How long should i charge the headset and how to turn it on
The headset contains a lithium ion rechargeable battery, which should be charged before using the headset for the first time.
System requirements for battery charge using USB
Personal Computer with pre-installed with any of the following operating systems and USB port:
Operating Systems (when using Windows)
Windows® 7
Home Basic / Home Premium / Professional / Ultimate
Windows Vista® (Service Pack 2 or later)
Home Basic / Home Premium / Business / Ultimate
Windows® XP (Service Pack 3 or later)
Home Edition / Professional / Media Center Edition 2004 / Media Center Edition 2005
(when using Macintosh)
Mac OS X (version.10.3 or later)
Charging the headset
  1. Open the cover of the micro-USB port.
Insert the tip of your fingernail in the groove, and open the cover.
  1. Connect the supplied micro-USB cable to the headset, and then connect the other end to a computer.
Make sure that you connect the plug of the micro-USB cable in the direction as shown in the illustration below.
Charging starts when the headset and the computer are connected.
Make sure that the indicator (red) lights up. Charging is completed in about 6 hours* and the indicator (red) goes off automatically.
*Time required to charge the empty battery to its full capacity
Notes
  • If the headset is not used for a long time, the indicator (red) may not light up when you connect the micro-USB cable to charge the headset. In this case, do not disconnect the micro-USB cable from the headset and wait until the indicator (red) lights up.
  • When you close the cover of the micro-USB port after charging the battery, push the catch at the edge (the round part) of the cover into the port compartment.
  1. Catch
Tips
  • If the micro-USB cable is connected to a computer while the headset is turned on, the headset will be turned off automatically.
  • To charge the headset from an AC outlet, use USB Charging AC Power Adaptor* (sold separately). For details, refer to the manuals supplied with the USB Charging AC Power Adaptor.
  • The headset cannot be turned on while charging the battery.
*Refer to the Reference Guide on the recommended adapter.
Caution
If the headset detects a problem while charging, the indicator (red) may turn off, although charging is not complete.
Check for the following causes:
  • Ambient temperature exceeds the range of 5 °C - 35 °C (41 °F - 95 °F).
  • There is a problem with the battery.
    In this case, charge again within the above-mentioned temperature range. If the problem persists, consult your nearest Sony dealer.
Notes
  • If the headset is not used for a long time, the battery may be quickly depleted, however, after a few recharges, the battery life will improve.
  • Even if you do not intend to use the headset for a long time, charge the battery to its full capacity once every 6 months to maintain its performance.
  • If the headset is not used for a long time, it may take longer to charge the battery.
  • If the life of the built-in rechargeable battery drops to half the normal length, the battery should be replaced. Consult your nearest Sony dealer for replacement of the rechargeable battery.
  • Avoid exposure to temperature extremes, direct sunlight, moisture, sand, dust or mechanical shock. Never leave the headset in a car parked in the sun.
  • If the computer enters into hibernation mode while connected to the headset, charging will not be completed properly. Check the setting of the computer before charging. The indicator (red) will go off automatically even if the computer enters into hibernation mode. Charge the headset again in this case.
  • Use the supplied micro-USB cable only, and connect directly to a computer. Charging will not be completed properly by an indirect connection, such as via a USB hub.
Usage hours
Status Approx. usage hours Communication time (including music playback time) (up to) 30 hours Standby time (up to) 200 hours The communication time will be about 15 hours when it is charged for 2 hours.
Time stated above may vary, depending on ambient temperature or conditions of use.
Checking the remaining battery
If you press the POWER button while the headset is turned on, the indicator (red) flashes. You can check the remaining battery by the number of times the indicator (red) flashes. The indicator (red) flashes immediately after the headset is turned on to indicate the remaining battery power.
Indicator (red) Status 3 times Full 2 times Mid 1 time Low (needs to charge) Note
  • You cannot check the remaining battery during pairing operation.
When the battery is almost empty The indicator turns red. When the battery becomes empty, the headset sounds a beep and turns off automatically.
Mar 26, 2016 | Jabra Bt2045 Bluetooth Headset
Trancend pod not detecting
Go to Settings->USB
Under USB, you can see two options like, USB and MTV. Select USB.
Now Try again, it will work.
Cheers...!
Mar 15, 2010 | Transcend T.sonic 850 Digital Media Player
Do you have to have a router to connect your ipod to internet
No you do not require a router to connect your I pod to the internet.
If you wish to load the songs on the I Pod, you can first look for songs on the internet and save them to your computer.
Then you can connect the I POD to the compuet via the USB cable which you would have received with the I pod.
Please connect the usb cable one end on the I pod and the other to the
the computer. The moment you connect the I POD to the computer, the system will detect the IPOD player. You can then save the copy of songs you have downladed on your I POD player.
You can select the sond saved on your compuet by doing a CTRL+C key and then go to MY COMPUTER> and under the drives section it will show your I POD PLAYER. CLICK ON THE PHILIPS PLAYER TO GO INSIDE SO THAT YOU CAN DO A CTRL+V and copy the songs on the I POD player.
That should do the trick and you shoudl be able to listen to your favourite songs on the move.
Please rate me if you are happy with the support provided.
Sep 14, 2009 | Apple iPod touch
PC not detecting mp3player and also not able chage
First, make sure the hold switch is not engaged. Then:
Disconnect the Go Gear from computer. Press the reset pinhole until the player turns off. Hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard. If this pop-up does not appear, reset the player again WHILE connected to the computer. Open the Philips Device Manager, and go to Repair Tab. Reset the player one more time while connected to computer. Follow the repair instructions.
-Tha Mp3 Doctor
Dec 04, 2008 | Philips GoGear SA3125/37 MP3 Player
My phone will not show it charging and will not turn on, red light flashing
i cant charge my phone using a charger
when i put the head phones in the same port, my phone does not pick up the signal
BUT when i connect my phone to the pc using a usb cable, it charges fine and i can transfer data
WHAT IS WRONG WITH MY PHONE????
Apr 19, 2008 | Cell Phones
Sansa cant be detected by computer
i had the same problem with mine and my computer didn't detected it so try plugging it in and out a few time it might work.but if that doesn't work go on settings and change the usb setting
Apr 06, 2008 | SanDisk Sansa e260 MP3 Player
SONY NETWORK WALKMAN NW-E005F
i have a sony nw e305 , same problem no detection and no charging even after it shows tht the battery is charging.. and the walman shows charge error at times...
Mar 30, 2008 | Sony Network Walkman NW-A1200 MP3 Player
Charge
Charging the Player
The player needs to be charged before it can be used and every time
the battery gets low. It takes approximately 2.5 hours to charge the
Player. Once fully charged, the Player lasts approximately 8 hours.
To charge the Player:
Remove the USB cover on the Player.
Connect the Player to the PC using the Flash Plug.
The Player will begin charging. The battery indicator should begin
to flash, alternating red and green.
Once the battery is fully charged, the indicator light will stay red.
Note: If this is the first time the Player is connected, wait until
Windows detects the Player and follow the prompts to install it.
Mar 15, 2008 | Disney Tink Digital Mix Stick MP3 Player...
Apple mini i-pod
Try another usb port, but not in a non ac powered usb extension hub, as I Pod's need to be used in powered usb. Older pc's tend to have trouble powering the usb ports enough for the I Pod to be recognised. It may also be a voltage problem, disconnect any other usb peripherals connected and try again.
Jan 29, 2007 | Apple Mini IPod
Apple iPod shuffle MP3 Player Logo
133 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
