How to adjust dvd when movie is to high on TV screen
When a dvd movie is playing the screen keeps rolling. Is there any way that I can fix that by adjusting anything on or in the system itself..
rolling tv screens is an indication of a vertical hold problem
if there is a tab in the onscreen menu , use it to remove the sensitivity of the signal input from the dvd unit
if there is no such adjustment available then the problem may be the first signs of a tv problem so talk with a repair shop
Feb 19, 2017 | Televison & Video
Can i adjust my tv from widescreen to full screen when i watch a dvd and if so how?
The DVD movie picture are not adjustable by the tv.Used ur DVD player remote pointed at the DVD player push the button that said Zoom on ur DVD player remote.Now,pick the Zoom in u want like X1,2,3... so on.
Nov 26, 2010 | Vizio VP422 42 in. Plasma TV
I have a Pioneer DV-525 DVD player, and recently upgraded from a 4:3 TV to a widescreen TV. However, under the Setup menu, it won't let me change the setting to 16:9. The options are grayed out, and I...
The DVD movie has to be a "widescreen" version...
Check the cover of your DVD movies ... there may be one or more widescreen DVD's in your collection...
That should work.
What widescreen TV did you get? Brand / model.
If it is Samsung ... on the remote, press the "p.size" button (and wait) ... continue pressing and waiting after each press to see if the Samsung will adjust ... You may get a distorted pic ... like very short and very wide people.
What TV Brand / model??
Sep 14, 2009 | Pioneer DV-525
My dvd player doesn't fill the screen on my Sharp
There are settings on most DVD players as well as TV's that allow you to adjust the type of display you want. Make sure both the DVD and TV are set to the same display type (usually either 16:9 for your type of TV). If that still does not fill the screen you will have to use the Zoom function on either your DVD or TV. This will cut off part of your movie, but should allow you to fill the screen. Most DVD movies will also allow you to choose widescreen or normal viewing from their menu. Again, you will lose a small part of either side of the movie, but at least you will fill your screen.
Jul 07, 2009 | Sharp Aquos LC37D44U 37 in. LCD HDTV
Cannot get the visual from the videos
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jun 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Viewing mode will only go from zoom to wide!!!! please help
Hi!
Found some relevant info on how to adjust your video settings... You might want to give it a try!
Thanks! =)
4.12 PC Input Picture Adjustment
The Picture Adjust menu operates in the same
way for the PC Input as for the DTV / TV input in
section 4.2 for Backlight, Contrast, Brightness and
Color Temperature.
4.12.1 Auto Adjust
When the MENU button is pressed, the On Screen
Display (OSD) appears on the PICTURE ADJUST
page. Press the button to highlight the Auto
Adjust selection.
Press the button for the LCD HDTV to adjust to
the PC signal timing automatically.
4.12.2 H-SIZE
Press the button to highlight the H-Size selection.
Press the button to start adjusting the horizontal size of the picture. Use the or button to adjust
the horizontal size.
4.12.3 Horizontal Shift
Press the button to highlight the Horizontal Shift selection.
Press the button to start adjusting the horizontal position of the picture. Use the or button to
adjust the horizontal position.
4.12.4 Vertical Shift
Press the button to highlight the Vertical Shift selection.
Press the button to start adjusting the vertical position of the picture. Use the or button to adjust
the vertical position.
4.12.5 Fine Tune
Press the button to highlight the Fine Tune selection.
Press the button to start tuning the to the PC signal. Use the or button to adjust the tuning
4.14.1 Understanding Viewing Features
Your LCD HDTV features four viewing modes and Picture-In-Picture (PIP)/Picture-by-Picture (POP) mode.
You can switch viewing modes using the remote control.
4.14.2 Viewing Modes
Normal Mode
The original 4:3 aspect ratio (1.33:1 source) is preserved, so black bars are
added to the left and right of the display image. Standard TV broadcasts are
displayed with a 4:3 Aspect Ratio. Movies in 4:3 Aspect Ratio may be referred
to as pan-and-scan or full frame. These movies were originally filmed in 16:9
(widescreen), and then modified to fit a traditional TV screen (4:3).
Wide Mode
When watching a standard broadcast or full-frame movie in this mode,
the display image is stretched proportionately to fill the TV screen.
When watching a widescreen (1.78:1 source) program or movie, the
display image fills the TV screen. If you are watching a widescreen
(1.85:1 or 2.35:1 source) program or movie, there will still be black
bars at the top and bottom.
Zoom Mode
When watching a widescreen (1.78:1, 1.85:1, or 2.35:1 source)
program or movie, the display image is zoomed proportionally to fill the
width of the screen. The top and bottom are cut off to remove most of
the source material’s black bars. This mode is good for programs or
movies with sub-titles.
Panoramic Mode
When watching a standard broadcast or full frame movie in this mode,
the 4:3 Aspect Ratio (1.33:1 source) display image is stretched
horizontally on the left and right sides to fill the TV screen. The center
of the image is not stretched.
Note: Viewing modes are saved based on input. For example, you lasted watched a DVD in widescreen
mode and then watched TV in standard mode. When you switch back to DVD input, the viewing mode
will return to widescreen.
Jan 04, 2009 | Televison & Video
Sharp Aquos LC-32D43U
To adjust screen size, choose the View Mode feature on the top right of the remote control. Zoom size is full screen for watching DVD movies, but sometimes there is still a thin black band due to the formatting of the dvd (unless you buy full screen versions) S. Stretch view mode is best for TV Movies.(usually fills whole screen) Occasionally there are TV movies which just don't respond to being stretched to fill the screen, it's just the way the signal is coming through . 1080i/p detects the resolution of the signal and displays the same number of pixels on the screen, but a 720p signal input will be viewed in full screen.
Jan 25, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How do I set the DVD picture to Full Screen as opposed to Wide Screen?
That is the way the DVD makers intended it to be. The TV cannot be adjusted to change that if it is a widescreen or "letterbox" movie.
Dec 12, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
