I had in washing machine,while cleaning the surf holder i pushed it in and by that time I'm unable to pull that holder out.
3 Suggested Answers
  • 4399 Answers
SOURCE: LG Washing Machine WT-R852 Unable to
Thanks for choosing FixYa and welcome. I want you to unplug the machine for 20 minutes Deborah. This will reset the washer. Write me back once you have did this please. Thanks.
Posted on Jun 19, 2011
  • 9472 Answers
SOURCE: Remove washing machine filter for cleaning: How do I remove the filter on my Bosch class iXX front load washing machine for cleaning? We can turn it 1/3 anticlockwise but it won't pull out.
Something must be jamming the filter. You will need to just keep working it. If you cannot get it to open, you will need to replace the whole assembly.
Posted on Nov 03, 2012
How to remove drawer from Samsung EcoBubble washing machine for cleaning
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
Jan 18, 2016 | Samsung Washing Machines
Kenmore washing machine model 970 c44102 00
Refer the control panel diagram at this site.
SEARS CANADA Washer Control panel Parts Model 970 C40042 00
Explode the diagram part and use the magnify cursor to see the parts of the dispenser. You need to pull the drawer out by lifting up slightly and then releasing its front edge from under the latch bar. Put it back in same way by inserting at a slight angle and then pushing in and straight. If you want you can take the top cover out (with proper screw driver) and pull the whole dispenser out. But I think you should be able to simply pull the drawer out and lean it.
Aug 31, 2014 | Kenmore Washing Machines
My whirlpool LHW0050PQ4 washer door is locked and unable to open, wash cycle is finished. Unplugged overnight and return next day, still locked. Any suggestions?
reset it
push sound for 10 secs
open top
spline screws top back
an reach down to the door latch
bottom of latch t is a small loop for your finger to pull/push it down
you can get to it same way from the bottom front cover
unplug unit
3 spline screws on bottom front washer cover
reach up an pull the loop on latch
good time to clean out the trap since your (t)here.
May 13, 2014 | Whirlpool Washing Machines
Water leaking out of detergent dispenser
As you said in the question you just need to check the following things.
*Pull out the tray fully and lift it upwards to remove the detergent holder.
*Clean the dispenser housing and drawer with water if you find any traces of detergent in it.
*Reassemble the tray and push it back to its position.(flush with top).
After checking this you are washing machine will be fine.Thanks for your question.
Jun 20, 2011 | Washing Machines
HI. I have a bosch wfo2466 washing machine and need to replace the motor brushes. does the end cap need to come off to do this or is there an easier way? I have successfully removed the motor from the...
You do not need to remove the end cap.Pull off the brush leads, and ease out the terminal ends of brushes with a pair of taper nose pliers..pull the old brushes out, take note of which way the shamfored end of the brushes are facing in the holder.
Push new brushes into holder and compress the springs as you are pushing them down, locate terminal ends into slots of brush holder.
This should help you with your problem.
Good luck.
Nov 27, 2009 | Bosch Classixx WFO 2466 Front Load Washer
Remove lint holder on ge front loader dryer
I have the exact same problem. I am amazed at had been the engineering is for such a simple process. The user guide just says to clean the lint filter. Even when doing so, there is still an excessive build up of lint beyond reach. There are no instructions that mention how to clean this part. It is obvious that GE did not test this part of the machine.
Jan 30, 2009 | Zanussi ZWF1440 Front Load Washer
How to release new carbon brushes in their holder
All carbon brushes have an electric wire attatched to them, that needs to be gently praised off (make sure the machine is unplugged from electrical outlet), then using a flat headed screw driver, push in the clip that is holding the brush in place and at the same time gently pull the carbon brush up.
To replace the brush, simply push it back into its slot (but gently and carefully because it can snap) until you hear a click then replace the electric wire.
If you have left the rubber band on the brush when you inserted it back into it's holder, simply cut the band at the top and very gently pull it up until it is removed.
Oct 31, 2008 | Hoover Washing Machines
Whirlpool AWM8143 help please! F11 coming up on display..
it's a communication error between the ccu and the mcu (motor ctl unit). i've seen lots of problems with the mcu.
Feb 10, 2008 | Whirlpool AWM8143 Front Load Washer
DCP-130C Clean Unable
- pull out the AC plug
- put back the AC plug while holding down the "menu" button and keep holding it (15 sec)
- now you are entering the MAINTENANCE mode and "error 46" pops up in the display
- select 8 by using the arrow buttons ,push OK and select 0 and push OK
- 00:00 00:01 OK (the display is showing this message)
- now push the MONO button 25 times until you see PURGE: xxxxx
- Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
- the purge counter indicates now: purge: 00000
- switch off the printer ,switch it on
- ready to print
Jan 27, 2008 | Brother DCP 130C All-In-One InkJet Printer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
