Question about Kitchen Ranges
My Beaumark stove oven won't come on. I get a F14 error. Can you please tell me what this means
heavyice
  • 374 Answers
SOURCE: My Beaumark Stove is from
there is a lock for each hinge
lay the door down with hinges facing up.take a towel pull long piece
of hinge toward you(BE CAREFUL) take other piece up and lock them together do the same to the other hinge it should then go on easy next time lock before taking off .These are the instruction on how to remove and replace the door, be sure you locate the removal pins to being able to put it back
This [link] http://tinyurl.com/kogjg3 should help you out.[link] http://tinyurl.com/mzgjtq is added to the hold the hinge in place on the self clean doors. The screw and bracket have to be removed to remove the door and hinges. The metal clip bracket has to be reinstalled once the door is put back on. To reinstall the [link] http://tinyurl.com/mszglp just do the opposite, start the hinge blade in the receiver, lift slightly on the door and with your knees push the door and hinges back into place. One thing most people forget about these hinges is that there is a clip that must be moved to hold the upper (A) and lower (B) parts of the hinge together. Once the door is put back on, the clip must be put back in the rest position. To reinstall the door, put the door at a 80degree angle to the range front, push in the larger upper hinge parts first and then lower in the smaller hinge parts, push the clips forward into the rest position and close the door.
On this [link] http://tinyurl.com/lg76wg one common problem is the hinge will sometimes "pop" forward against the range instead of staying still while you reinstall the door onto the hinges. If this happens, use a screw driver at the marked spot to help hold the [Link] http://tinyurl.com/kren2c so you can start the door onto the hinge, them remove the screwdriver to finish installing the door.
I hope it helped.
Posted on Jun 11, 2009
protek480
  • 1723 Answers
SOURCE: I have a frigidaire gas oven and stove and am
F2 Oven temperature too hot Check and replace oven temperature sensor (RTD). F3 Open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Posted on Sep 21, 2009
Testimonial: "WOW! thanks good to know just a simple fix."
blueextc3221
  • 15935 Answers
SOURCE: There is an F14 error code when I plug the range into the outlet.
F14 is a memory corruption on the Clock Module.
Replacing the module is your only fix.
It appears your Clock has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
SOURCE: error code "43"?????
Thanks Marty for the info on the sail switch. We experience the same error code 43 problem. Seemed like the sail switch was stuck in the back position and didn't come forward when the fan started. So I bent a metal coat hanger and used it to pull the switch foward to "unstick" it. I tested the oven turning it on and off a few times and made sure that the switch moves forward with the blower fan starting when the oven was on, and moved back when the oven was turned off. Should be obvious, but make sure the blower is not running and the oven is turned off before you stick the wire hanger back there. A pretty quick and easy thing to try before calling the repairman.
Posted on Dec 31, 2011
  • 15 Answers
SOURCE: amana gas oven/stove model 836BD811 heats up then
From their corporate web site:
If you should experience a problem not covered in TROUBLESHOOTING, please visit our website at www.amana.com for additional information. If you still need assistance, call us at 1-800-843-0304.
You as well could look online for a .pdf file of the original owners manual (unless you have one handy); and then contact a local appliance repair company and inquire by phone prior to the expense of the minimal trip charge fee.
Posted on Oct 09, 2013
How to address F14 code? Convection oven does not start.
Hey friend, thanks for your post!
I see that your Electrolux wall oven is displaying an "F14" error code. "F14" stands for display tail missing, which means you could have an issue within your main control board or keypad. I would perform a reset on your appliance which can be done by flipping your household circuit breaker off for roughly ten minutes. If that does not correct the issue I would suggest seeking a professional to come out properly diagnose and repair your appliance. I hope this is helpful. -Matt
Aug 31, 2014 | Electrolux ICON Designer E30EW75GSS 30"...
F14 Error
First please get the full model number of the range. Kenmore products are made by other manufacturers and the error codes will depend on the manufacturer.
Most likely, you have a Frigidaire range (for example a 970. model). Then the F14 code could indicate a problem with the P12 ribbon cable connector tail, a bad EOC (control unit), or touchpad. First try disconnecting and reconnecting that cable. Next the EOC should be replaced. Finally the touchpad should be replaced.
If this is a brand new range, contact Sears to get a repair person to fix the range. If you bought it used, see the above possible solutions.
I hope this helps.
Dec 24, 2013 | Kenmore 30" Electric Double Oven...
I'm getting error code AM71 UI75 EEKGO-097 on my kitchenaid stove. The oven is not turning off unless I unplug. Please help.
I'm not sure exactly what that error code means, but being a technician I can tell you the control board and the oven sensor need to be replaced. The control board simply because it tells the oven what to do and when to do it, the sensor because its a rule of thumb because the two work hand in hand and because its a cheap part and with the situation has more than likely taken damage of some sort.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | KitchenAid Stove / Oven / Range Infinite...
Washer won't unlock flashes f14.....Kenmore Elite HE4t
F14 for Kenmore (Whirlpool) machines means EEPROM Error.
The Central Control Unit (CCU) receives it's data from an EEPROM on board the CCU, if there is an error reading this data, it will cause this error.
A power glitch may cause this error. Try unplugging the Unit for two minutes to see if that fixes the error. Check CCU. So its likely you'll need a new CCU board.
Check your owners manual, some models have up to a 5 year parts warranty on that CCU.
Jul 21, 2011 | Kenmore HE4t 3.8 Cu. Ft. King Size...
I have a frigidaire gas oven and stove and am getting an F2 and F3 error code on the display. Can anyone please tell me wht that means?
Sep 21, 2009 | Kitchen Ranges
F14 error message
First change the fuse. Then if it still isn't functioning properly, you may have to replace the lamp, in which case you should contact a specialist. Details can be found in the Instructions Manual.
Go here:
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
and enter EB270 and click the Go button.
Then download the PDF file of the manual in English (EN)
Hope this helps :)
Chris (ziraffa)
ps Someone else on Fixya claims to have fixed the F14 problem by changing the PCB Board, whatever that is.. but there was no further rating or feedback given. That's all I have.. Good Luck!
Jan 11, 2009 | Gaggenau EB270 Electric Single Oven
GE JES1290,
Not sure about an F14 error, but an F4 error is a shorted (or even just greasy) temperature sensor (thermistor). That could cause trouble with the convection and fan, etc. like you describe.
It looks like the thermistor on this model comes as part of the heater or one of the covers, etc.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find a very good exploded view of it at:
http://genet.geappliances.com/IPCNet/Dispatcher?REQUEST=IPCNETGETPDF&file=00000000/00058700/00058754.p01.pdf
You can find parts here: http://www.geappliances.com/shop/prts/
Nov 11, 2007 | GE JES1290 Convection/Microwave Oven
Kitchen Ranges Logo
53 people viewed this question
Top Kitchen Ranges Experts
Oloyede Monsuru
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
