Question about RCA Televison & Video
Mt RCA L26WD26D screen freezes and the colors change and become lines of colors instead of a picture. After 15-30 minutes it goes back to working normally. What is up with it?
3 Suggested Answers
  • 1030 Answers
SOURCE: rca p56927 colors out of line
This is a convergence oroblem. First question is do you have the convergence option in under setup in the customer main menu?... if you dont you may have the very common fl231 fuse problem; i have wrote a article on this under the tips and tricks section. this is a very simple inexpesive repair. If you do have the "convergence option" then you may have to replace one of three cuircit boards
Posted on Feb 01, 2009
  • 68 Answers
SOURCE: a red blue and green line jus appeared across the
conversions are out....rca ... check for bad connections on circuit board around fryback xformer. check fuse by flyback xformer...fuse is shaped like a little plastic rectangle>>fuses should measure a SHORT when GOOD! Flyback Transformer is large in size and sends highvoltage to 3 picture tubes via a SPLITTER . easy to locate
Posted on May 19, 2010
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
I own a Samsung un55es7500. TV powers up but after a minute or so the screen goes white with colored line across screen also I don't have sound.
freeze the IC on the T-con board when the problem shows,if disapear or you note any change on the picture that`s the board you have to replace.
Dec 29, 2014 | Samsung Televison & Video
HI i have an RCA HD52W59 and the picture looks 3D, I can use the manual convergence but when tv is shut off and turned back on it goes back to the 3D look and the auto convergence does not work - the...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
You can see some more examples and find a fix using this link on Fixya
Jun 02, 2011 | RCA HD52W59 HDTV Projection Television
My 52
Dec 26, 2009 | RCA P52926 52" Rear Projection Television
the LCD panel has failed but i know of no one that has a replacement panel for that model get the genaric number off the panel on a white sticker and do a search .maybe some one will have a good pullout
Dec 22, 2009 | RCA L26WD26D 26 in. LCD TV
sorry dear...just got disconnected
Feb 29, 2008 | RCA L26WD26D 26 in. LCD TV
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
