My cord has frayed at the plug insertion and no longer works. Is it replaceable and can I get new cord. The serial number for the Dyson canister vac is 733-US-B27415
I note your question was submitted in January, so hopefully you've been able to replace the brushbar assembly at this point.
If you haven't yet installed the new brushbar, you may find the video below useful in showing how to remove the old brushbar and fit the new one before reassembling the Motorhead.
I hope this helps. If you'd like any further assistance, please call us on 1-866-693-9766, or email at [email protected]
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner
can still suffer the problems of wear and tear that are prone to any
vacuum cleaner--for example, a frayed power cord. If the power cord of
your Dyson vacuum cleaner has become frayed, change it immediately to
avoid a dangerous electrical mishap. You will need a replacement cord
from an electronics service center, along with a few common household
tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum
cleaner's power plug from the wall outlet. Press the button on the top
front of the plastic collection cover. Lift the cover off the front of
the vacuum cleaner and place it aside.
2 Trace the power cord to where it
enters the back bottom of the vacuum cleaner. Remove the screws from
the panel surrounding the power cord with a Phillips screwdriver. Remove
the panel. Aim the beam of a flashlight inside the compartment so that
you can see where the wires at the end of the power cord wrap around two
screws on the motor assembly. Loosen these screws with a Phillips
jeweler's screwdriver.
3 Pull the power cord out of the
compartment and dispose of it properly. Strip a 1/2 inch of insulation
from the ends of the two wires of the replacement power cord. Run the
wires into the compartment along the path of the original power
cord--pushing the wires into the grooves inside the compartment.
4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
5 Wrap the exposed end of each
wire of the power cord around the loosened screws. Tighten the screws.
Replace the panel and reattach the screws. Stand the vacuum cleaner
right side up. Place the bottom of the plastic collection cover into the
bottom front slot on the vacuum cleaner. Push the cover back on the
front of the vacuum cleaner.
After checking with Dyson, it appears it can be fixed but depending on the age, it might be more cost effective to just buy a new one. There are not a lot to the dyson vaccums to repair. Plugging the vac into double the voltage would have fried the motor and that will need to be replaced. There is not reset or surge protector. With shipping and replacement of the motor, we would recommend a new vac. Good luck and sorry!
I have made a video showing how to replace the motor on a Dyson DC08. If you follow the instructions you should be able to do it. If you find the video helpful please give me a thumbs up or a comment.
If you find you need parts for this procedure I would recommend Vacuumspot or Nelson Vacuums
Dont forget to let me know how you go!.
put some vac freshner in the canister put the vac out side if its fine plug in and switch on leave runing for around 10 minutes that should solve the odour
