Question about Sewing Machines
My machine keeps sewing backwards!! The backstitch button does not appear to be stuck. help??????
SOURCE: The backstitch level (reverse button)
I emailed Singer and they provided me the following information. I did contact the service center in NJ (which is the closest one to me) and they do have the part for $2.95 plus $5.00 shipping. You can mail a check or pay over the phone with a credit card.
" Thank you for contacting the Singer Sewing Company.
One of the following Singer Service Centers may be able to help you. All offer mail order service. If you give them a call, they can provide pricing, shipping costs and product availability.
Syracuse, New York - 1-800-321-7397 (toll free)
Union, New Jersey - 1-866-281-1220 (toll free)
Paramount, California - 562-531-6352
Bellevue, Washington - 425-462-1274 or 1-866-462-1274 (toll free)
Cordially,
Singer Consumer Affairs "
Posted on Nov 05, 2008
SOURCE: Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to AApilot@comcast.net
Posted on Feb 14, 2009
  • 52 Answers
SOURCE: Viking sewing machine model 6430 will only sew backwards
Th cam stack gears have gummed up on you you can try getting the back cover off along with the side and soaking the machine down with wd-40 and running it while forcing the reverse button in and out if it breaks free try and soak up as much of the wd-40 as you can and then oil anything that moves. I know this may be discouraging but viking no longer supports this machine and you might be better off taking it to an older viking dealer for help.
Posted on Jul 14, 2009
SOURCE: sewing machine sewing backwards??? help
reverse cam might be gunked up with old grease
Posted on Dec 10, 2009
  • 539 Answers
SOURCE: Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Jimmy
Posted on Apr 02, 2012
Does my Brother SQ9185 sew backwards other than the push button backstitch?
Use the reverse button. That's what it is for. Sew forward and then push the button and sew in reverse.
Machine Darning Jeans Shirt
If you have a darning foot, you can use it (drop the feed dogs) and then you manually move the fabric around while stitching.
Learn How To Mend Clothes with Machine Darning
Oct 01, 2016 | Brother Sewing Machines
Why does upper thread snap when backstitching?
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
Nov 07, 2015 | Singer Advance 7422 Electronic Sewing...
Why is the fabric feeder pushing the fabric toward me instead of awayfrom me?
It is sewing in reverse. Shut down, restart the machine. If this doesn't help, press the backstitch button, and see if it stuck. Try changing the stitch length dial.
If this is an electronic machine, it may need to be serviced. This happened to a embroidery machine I had, when I tried to sew straight stitching. It needed to be service as it was an electronic issue.
Oct 27, 2014 | Sewing Machines
I have an Elna Elnita air electronic and cannot figure out how to backstitch. I have always owned Elna Su air electronics but this little machine I can't figure out the backstitch
Unless there is a specific button to do reverse stitching, you could try pressing the foot peddle 'backwards' .. in other words, press with your heel rather than your toe. Some foot peddles are configured this way.
Apr 09, 2014 | Elna Sewing Machines
Pfaff 1221 sewing machine stuck in reverse
if you can take the pfaff back and tell them what its doing and have them fix it or get another sewing machine..
Sep 06, 2013 | PfaFF Sewing Machines
Did this help?
Jimmy
Dec 13, 2011 | Singer 4423 Sewing Machine
Hello. I hope u can help me. I cannot get my stitching tight? If I pull the thread it comes right out. Thanks Jodie
You need to backstitch over the beginning and end of your stitching, Jodie. When you start out, manually turn the wheel to put the needle into the fabric. Push the foot pedal to stitch forward a little. Now, reverse over those stitches to nearly where you started stitching. Use the foot pedal to go forward again, stitch to where you want to end. Reverse again, just a 1/4 inch or so. Then take the fabric out and cut your stitching.
This backstitching keeps your thread from pulling straight out. You should always use it with straight stitches and general zigzag stitches. Don't use it with decorative or embroidery stitches, though, as it mars the appearance of them. But if you're doing any type of topstitching that uses straight stitches, backstitch in the area that will be in the seam allowance, ever so slightly, or your top stitching will pull out, too.
Hope that helps!
May 19, 2011 | Kenmore 16622 Mechanical Sewing Machine
I have a Shark sewing machine.......Model 384. I sent it off to be repaired because it wouldn't make nice buttonholes. Well, now it sews backwards instead of taking the material the way it is supposed...
Call Euro-Pro at 1-800-798-7395 and they will help you. Also, reread your owners manual for some tips, like maybe one of you levers is stuck. Good luck
Sep 11, 2010 | Euro-Pro Sewing Machines
Two problems:
Jan 16, 2009 | Husqvarna Viking 1
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
