Question about Panasonic Microwave Ovens
Lamp burnt out; can I replace it? everything else still works ( carosel, clock etc.)
    President:
  • Panasonic Master
  • 1,922 Answers
There are usually access panels to replace lamp, it may be inside oven or on outside case or you may need to remove cover to access lamp,be careful especially if you need to remove cover,even after its unplugged
Posted on Jul 27, 2009
Clock,lights and turntable work but does not heat
Open the microvave discharge the capcitors.If you don't know then stop here and call pro .
Open it First check physically the nothing is burnt.I everything seems okay then, check the resistance of the magnetron and also the fuse.PLEASE DON'T TRY IF YOU DON'T KNOW HOW TO DISCHAGRE THE CAPACITORS.
Thanks
Please rate my work
Sep 17, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have an amana convection/microwave model acm1580as that needs a lamp replaces. I bought replacement lamp and after practically tearing appliance apart I located burnt out lamp. Now I don,t know how to...
Hi, since you have located the burnt lamp, all you need to do is to unscrew the burnt lamp and replace the new one by screwing it in.....
You only need to unscrew to remove the lamp and if you cannot remove by unscrewing because it is stuck in, then you need the assistance of an electrical tech to help remove with his pliers....
Mar 26, 2011 | Amana ACM1580 Convection Microwave Oven
When I was unscrewing a burnt out hood lamp on
I would not use the lamps. Sounds like there is a shortage in the wiring for the lamps. They lamps should run together, and if one of the sockets have a short or burned wire it will not let it complete the circuit. This could be a fire hazard, so I would replace the whole microwave. It would be more trouble to tear it apart and find the exact problem than it's worth.
Jan 04, 2010 | Maytag MMV4205 Microwave Oven
Goldstar Microwave - it will come on, spin the carosel, but will not heat food and the clock works.
usually when this happens, it is because of the voltage regulator for heating unit, which basically works like a "radiation distribution unit", which is where the term " nuking your food " comes from. these things just "go out" at random and there are really only 2 options you have.
#1 spend close, if not more, than what you paid for the microwave, to have it repaired BY THE MANUFACTURER.
#2 go buy another microwave.
my advice? take option #2, because it is just easier.
Oct 03, 2009 | Microwave Ovens
Lights fan and carosel do not work
tricky one. common denominator to all parts not working could be open neutral track at back of the circuit board, or possibly a relay not switching correctly.Need testing equiptment for that.
Sep 13, 2009 | Microwave Ovens
GE JVM1440WH01 Will not heat, everything else works. This unit is 6 years old and just stopped heating. The carosel turns, fans work, the timer counts down and lights come on when you start cooking or open...
It could be a number of things, Burnt connections between the magnetron, Capacitor, Diode and transformer, Heater connections loose or burnt, Transformer, Capacitor Diode or Magnetron US. You need to strip it and find out if you are getting about 2000volts to the Mag, Are you getting approx 5volts across the heater terminals?? NOTE that the 2000 Volts can remain in the cap indefinitely and the voltage is LETHAL. IT WILL KILL YOU if you don`t take precautions. Ian
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Over the range Frigidaire Microwave not heating. Model FMT148
This is a sure sign that the MAGNATRON needs replaced (this is what heats up the food) if every thing else works but food not cooking! 99% of time it is the magnatron!
Please rate answer!
THANK YOU!
Jan 12, 2009 | Microwave Ovens
Work light and night light do not work on Sharp Carosel R-1481
> Work light and night light do not work on Sharp...
Thanks for giving us the model number.
We regularly repair these R1481 control units for customers nationwide by mail for $39.95 postpaid in about a week with a one-year guarantee.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your full model number) for more information & help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Nov 22, 2008 | Sharp R-510HW Microwave Oven
GE microwave oven
Does the turntable rotate? If everything but this works (except no heat), you probably have a bad door switch. Here's a discussion of what's involved in replacing it: http://www.fixya.com/support/t267796-kenmore_microwave_hood_combination_over
If the turntable does rotate, I'd suspect a more significant failure, such as the transformer, capacitor, or magnetron. If it's any of these, it's time to replace the unit.
Dec 10, 2007 | GE JVM1650 1000 Watts Microwave Oven
Microwave Ovens Logo
59 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
