Question about Drills
P208b no torque
Dropped it. now no torque. can't even get drill bit out.
    Top Expert:
  • 12,962 Answers
You broke it.
Posted on Dec 17, 2016
  • Rodger Derden
    Rodger Derden Dec 17, 2016
    helpful but didn't like the answer
  • richie46 Dec 17, 2016
    Maybe the drop dislocated a power wire inside if no torque.
I need to know how to take the Chuck off of a Ryobi P208B cord less drill
reveres thread , look for slot on shaft just below chuck , hold with wrench , may need a big pipe wrench too break loose
Feb 11, 2018 | Ryobi Drills
Drill bit falls out , cannot use reverse to extract srews or bolts
are you installing the bit correctly. is the chuck defective... is the a name for the product. does it have a keyless chuck... are you inept ???
Oct 24, 2013 | Dewalt 18 Volt Compact Drill Kit
Drilling wood on a craftsman 10" drill press
There are several possibilities. I am assuming that by "hang up" you mean that the motor still runs, but the arbor, chuck, and bit all stall. I also assume that you are running the bit up and down to clear out the wood shavings from the bit out of the hole, you are using the correct amount of downward force, and that the bit is sharp. I would first check to see that there is proper tension on the drive belt. You can add a belt spray designed to increase friction for better running. I would also gear down the drill press even more to increase torque (I know you say you are running at the correct speed, but try a reduced speed). Another method is to use an auger bit or a forstner bit without pilot holes. If you are using a spade bit, you might try no pilot hole, and drill at a faster speed. I have a junk 10" drill press and have no trouble drilling 1" holes in oak.
Sep 14, 2017 | Craftsman Drills
What speed would i need to set my cordless drill at to put hole in wall
Your drill will drill a hole at any speed, the drill bit needs to be sharp to drill the mateirial.The type of wall material is important.Drywall is soft but a masonry bit should be used.A masonry bit has a flat bar accross the point and slower speeds are best.Wood walls / studs you need wood bits that are sharper and medium to high speeds are used.Concrete or Block walls again require Masonry bits.If very hard concrete as in foundation walls or filled block the use of a Hammer drill will work much faster.Good Luck
Jul 29, 2011 | Drills
I got one of these drivers to replace my older driver. It clearly has more than enough torque, which is good in some cases but for some routine things around the house it is too much. Even on the lowest...
Most models have two selections, one for the clutch (which in effect regulates the torque applied) and the other is the gear selection ( usually a setting of 1, 2 & 3, with 1 being for driving screws and 3 for drilling purposes). In addition to those selections, the trigger controls the overall speed of the motor. These are all the control you have over the drill, granted the Dewalt tool is a bit torquey, but it is meant to be a construction tool.
Nov 23, 2010 | Dewalt 18 Volt Compact Drill Kit
Cordless drill question
1/2"
A 24 position clutch controls torque output. 2 speed range gear box for high torque applications. Auxiliary handle with metal depth stop rod. Has an overmold grip handle for added comfort. A Mag Tray holds screws, small bits and hardware, etc. on foot of drill for easy access. 1/2 Ft.' heavy duty keyless chuck for quick and easy bit changes. Removable 2 position level for convenience and accuracy
Apr 19, 2010 | Ryobi 18v Variable Speed Impact Driver...
I have just bought a 12v panisonic drill, is the
The racheting sound is the result of the torque setting indicated on the dial before the chuck. Set the dial to the drill bit icon, or all the way past the highest number, and that locks out the torque control, and it will not ratchet
Sep 03, 2009 | Panasonic EY6409GQKW 12 - Volt, 1/2"...
How is a driver different from a drill? What
Hello, W/D here.
A very good question......A drill holds a bit and rotates it at a given speed. This speed can be variable, allowing the speed of the drill bit to be better matched to the material being drilled. The output from the drill motor goes directly to the chuck, and the power is directly applied to the drill bit. Some drills can generate a tremendous amount of direct torque, due to the nature of their gearing. Most of the better drills have planetary gears in them.
A driver rotates like a drill, but is designed to apply torque to a driving bit, and cause a fastener to be placed by the driver. The main difference between a drill and a driver is that a driver has an adjustable clutch, allowing the amount of torque being applied to a fitting to be preset. A good example of this would be for driving wood screws. You would dial in the torque setting that you want the driver to quit driving the screw. You don't want to drive the screw to China, you want to drive it flush. A maximum torque setting "locks" the clutch, and the fitting will be driven as far as it can go (This is about as close to being called a drill as a driver will ever get). A clutch setting midway might be just right for driving the same fitting into oak, and a setting at less than that might be just right for pine. The torque clutch effectively sets a kick out torque for the driver. When the torque applied matches the torque set on the driver, the clutch "slips", and no further driving action can occur.
Most modern battery powered drills incorporate a torque clutch between the motor and the chuck so that the tool can be operated as a drill (with the torque setting at "max") or as a driver (with the torque setting at less than max) some electric tools are configured as both, but usually they are different. For the money, a good battery powered drill/driver with a clutch offers more versatility, in my opinion.
Best regards, --W/D--
Aug 19, 2009 | Dewalt Home Fencing
Clutch slipping
Try Rotating the bit holder head while holding torque adjuster or visa versa and turn the torque off in increments,test and adjust as desired.
Please rate Thanks
Mar 28, 2009 | Drills
Makita 18volt 6347 cordless drill
then you need transmision assy. item 14 in breakdown
see toolpartsdirect.com for further info on your drill
Mar 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
67 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
