Question about Pioneer Audio Players & Recorders
I have a pioneer receiver and my fuses had blown they say 125 v 6.3 A I went to radio shack to get them replaced and they sold me some that said 125 v 7 A and I put them in and they blew
    Top Expert:
  • Pioneer Master
  • 12,962 Answers
The new fuses that you got have a higher rating than before - and they also blew. Tells you that you have a nasty short somewhere. I would check the power supply and/or output circuits.
Posted on Dec 17, 2016
Teac AG-V7700 keeps bowing fuses
I hate to say it but it sounds like one of the audio chips that drives the speakers shorted out! The high powered outputs (more than 7 watts) need both speaker wires to be ungrounded. You will need to find someone to replace the defective chip or else get a new unit.
Nov 25, 2013 | Teac Audio Players & Recorders
The fuse is blown. Where can I get one. Circuit board says 5A 125 volt, but the fuse says 6.25A 250 volt.
Replace the fuse...not what is written on the circut board....Radio Shack or any electrical repair outlet will have fuses.
Feb 11, 2011 | Royal 1280MX Shredder
Will the power light still come on if the fuse is blown?
To prove if the power light comes on with a blown fuse, just take the fuse out and turn it on.
If the light comes on your fuse could be blown. Replace it with the same rating. Let the guys at Radio Shack help out on that.
Fuse type: Radio shack 270-1062 or Equivalent.
Mar 13, 2009 | Harman Kardon HK695 Computer Speakers
No response from company on Oster 12 bottle wine refrigerator
just replace the 5amp fuse on circuit board with a 6.3amp. tada!
use an exacto knife to remove the shrink wrap on both ends of old fuse. heat ends with a soldering iron and pull away old fuse. solder new 20mm in line fuse holder from radio shack to both poles insert 6.3amp fuse and done. at least mine works again! $6.00 total cost!
Dec 15, 2008 | Oster 12-Bottle Wine Cellar - Black
Pioneer radios is out
If you are refeing to the actual car fuses, you may have put too large of a fuse in and blown the radio's fuse. on most radios, there is a fuse that sits in the back of the radio. just pull out the radio and see if that is the problem
Nov 16, 2008 | Pioneer DEH-1700 CD Player
Engine noise from Pioneer radio only
Radio shack sold some ground loop isolators for the amplifiers who got this problem.Good luck.
May 08, 2008 | Clarion DXZ745MP CD Player
Pioneer rear projection tv
You might want to check the power supply/deflection board for bad solder connections. i found on the one i was working on. the standby and main power relays was broken loose from the board also check for any other solder joints that look cold jointed. i have been a tv technician for 13 years.
I hope that will fix your problems...
Keith Mitchell...
May 07, 2008 | Pioneer SD-P62A3-K 62" Rear Projection...
6.3a slow-blow 125v fuse
Hi, If the fuse physically fits into your unit then it will work. However- - - WARNING! Although 6.3 amps on a 250v fuse will allow the current to flow it will not afford you the circuit protection you require for a 125v circuit. If the circuit develops a fault then there is a danger that you burn out the circuit before the fuse. As you have already blown one fuse I would suggest tracking down the fault before you do any thing else.
The Scrivener.
Oct 12, 2017 | Pioneer VSX-D458 Receiver
No alot of sets have fuses that are white to begin with. Check it for continuity to see if its blown. If so radio shack should have a replacement.
Jan 20, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
Top Pioneer Audio Players & Recorders Experts
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
