I bought a wizard tv box it's all connected but I don't know what to do now
How to operate a LG smart tv
hi linda.
Press the Smart button on the included remote to access the Smart Home menu. From there, the LG Smart TV will take you through a setup wizard. Follow the onscreen prompts to connect to your home's Wi-Fi and your cable box. Once connected, you'll be able to access online videos, apps and more.
How to Set Up Your LG Smart TV: Geek Squad - Best Buy
How to operate LG smart tv Google Search
Nov 07, 2017 | LG Televison & Video
My android mx box as frozen wont show nuthing only start up mbox how do i get past it
Unplug from mains ...then reconnect...go into settings and check if the Ethernet or wifi is connected....sometimes restarting the router puts things right...without that you can't proceed....if you have not already done so download kodi version 14 as this seems to be quite stable.once downloaded go into API installer and direct to your internal sd to locate the Kodi apk file.once installed you can then set up your ad dons.a quick simple way is to use a community build from you are someone who bought from droidsticks you can use the droid stick wizard providing you still have the codes.get back to me if you are still stuck.
Apr 13, 2015 | FocalPrice MX Google Android 4.2 Dual-Core...
Have connected headset through cable box works very well for t.v. Not at all using DVD player.any suggestions?
Just a thought but how is your DVD connected to the TV?
If the DVD player is connected to the TV and the headphones to the cable box, then the audio will be going direct to the TV and no chance for the headphones to pick it up.
If however the DVD player is connected to the cable box and then to the TV, I think I would expect it to work and cannot think of a reason why not.
Hope this is helpful, if so would you please register that with Fixya
Dec 03, 2014 | Unisar Extra Headset For the Tv Listener...
I have a Daewoo DTQ-13Z5SC trying to run sega genesis on it, how do I get the av to work? don't have manual since I bought tv second hand at a thrift store
If the game box have AV out on it, you can connect it to tVs AV in by using an AV connector wire.This is the pircure of the AV cable that should connected in between TV and game box. You must select the input to TV as AV.3_4_2012_1_36_06_pm.jpg
Mar 04, 2012 | Daewoo DTQ-13Z5SC 13" TV
It has shrunk to about 6 inches all the way around the screen so the total picture sizr is 36 inches instead of the 42 inches otherwise clear picture little fuzzy when turning on but becomes a clear
Don't know what wires your using to connect to tv. It does matter, sometimes the connections go bad, either at the tv or cable box. Have you tryed to stretch picture in settings?
Feb 10, 2012 | Toshiba 42H82 42" Rear Projection...
I bought a freeview box, My tv has only one scart socket. how do i connect my dvd player to combine with this?
You need a video switch box, that has two video and audio inputs and a video and audio output that connects to the video and audio connections on the scart cable.
Then you can switch between the DVD player or the freeview box.
These devices are available on the Internet, use Google to search for these devices.
Dec 17, 2011 | Televison & Video
Hi, I bought this tv at thrift shop last week. No instruction manual available. I got cable from Time Warner. Got the cable signal and got tv working. 3 days later no cable. I don't know how to...
If using a cable box then you want to set the TV to channel 3 or 4 as the cable box will output to one of those. If no cable box then its possible the TV's tuner is bad or your cable company only transmits in digital form requiring a cable box since this TV only has an analog tuner
Jul 19, 2011 | GE 13GP341 13" TV
I just bought a new dynex tv and the setup wizard wont let me select cable/satellite box and when i go to the input menu it doesnt help at all
If your using a cbl box or satellite receiver then you don't need the setup wizard. Just put your INPUT or SOURCE on the appropriate setting. Always use a/v or component input for connections.Your done!
Nov 26, 2010 | Televison & Video
New laptop computer internet hook up
make sure everything (hardware/software) are in good working condition i.e properly pre-installed, then click on start, and interet connections, the wizard will ask you on how you intend to connect to the internet, just make sure you choose the correct options and off you go. you'll be on. good luck.
May 24, 2008 | Internet Compaq Evo N600C Laptop
The HDMI cable plugs into the TV and other sources. Make sure you have the correct HDMI cable for your set. Each cable handles both audio and video. Turn it over if it does not fit in. It only fits one way.
You need one cable for each source and your TV has to have at least one jack for each source or you need to buy a switch box, if it has only one and you have several. You then must select the correct source on your TV for the input. Your satellite box (DVD or VHS) each must have a HDMI jack to use this cable on each.
Let me know how you make out.
Dec 15, 2007 | LG 32LX3DC 32 in. LCD HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
