Question about Sylvania sdvd7046 black - 7 Portable Dvd Player
I just purchased SDVD7046 at 20 the sound is so soft i cannot hear. That is as high as it goes. Can i plug in one of my boston speakers to hear it where the ear plug goes?
I have boston ba 735 speakers i am using a new pc with windows 7 a presonus firemobile setup. I can get no sound out of the boston speakers. They are lit up when connected. I am able to record sound via...
click start control panel hardware and sound manage audio devices playback then select speakers you will se a list configure test disable set as default show disabled show diconnected.right click on speakers make sure they are enabled also select the recording tab you will see microphone midi right click on microphone and midi make sure ticks are in boxes show disabled devices and show disconnected devices
hope this helps
Jun 27, 2011 | Boston Acoustics BA735 Computer Speakers
No sound
Hello endow1, hi, try this test, unplug you Logitech audio in plug and touch the input, you should hear a humming sound, Adjust the volume settings to high to hear it. If you cannot hear the humming sound, then there are problems you need to check. Place you speakers near your ear and adjust the volume Up and Down, you may hear a soft hum that should go up and down. Absence of the hum means that the speaker has loose connection from amplifier to speaker driver, or loss of power, check to see if there is pilot light.
Aug 19, 2010 | Logitech X-140 Speaker
Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Feb 03, 2010 | Boston Acoustics BA790 Computer Speakers
My speaker set up boston acoustics ba7500 will'nt
The Guys at Boston Acoustics helped me get my speakers to work. The Boston BA7500 speakers are coaxial digital speakers so you need a digital output on your sound card. Analog will NOT work. My new HP Pavilion has a Realtek sound card with a digitial RCA plug output. I had to go to Amazon and get a male RCA to 1/8" Stereo Mini Female adapter plug. I just pluged it in and configured my sound card to 16 bit 48 khz output to the RCA output and everything works great. The speakers sound better then ever, great for 10 year old speakers! They sound better then anything I have seen avalable today. The guys at Boston were the only guys that helped with getting this to work! Thanks again to them and Amazon has every type of adapter plug you may need. Good luck.
Rick
Oct 08, 2009 | Boston Acoustics BA7500 Computer Speakers
No sound from rear speakers Boston Acoustics BA 7800
check whether the wire is connected properly on both the ends
Aug 08, 2009 | Boston Acoustics (BA7800) Computer...
I have my speakers plugged in but no sound coming out of the speakers
Make sure the speakers are on.
Make sure u plugged the corn in the right slot.
Make sure the sound is not Muted and that the Volume is set a high output lvl.
Aug 07, 2009 | Boston Acoustics BA265 Computer Speakers
Install Boston Acoustic speakers BA7800 to a new Imac?
Partial Solution anyway - I just got a Mac Pro (2.66 Nehalem )and couldn't find the manual from my old Gateway 700XL. This is what I did: Plug the green wire into the analog output, and the pink wire (if you really need an external mic, but you shouldn't since our new computers both have a built-in mic) into the analog input. Just ignore the black wire. You won't have the 2 surround speakers, but I'm still looking for a fix for that. I got tired of the crappy speakers in my new Apple Cinema display (the ONLY crappy thing about my new system). As you know, the sound from the BA7800 is great, even with just the two front speakers and sub-woofer. I'll keep you posted if/when I figure out how to set up the surround speakers! Likewise, if you hear something, please post here and I'll keep checking back.
Apr 10, 2009 | Boston Acoustics (BA7800) Computer...
Will my boston accoustics ba735 speakers work with a dell laptop?
We also have a Gateway Computer purchased in 2001 with the Boston Digitanl BA735 speakers. We ran into a similar problem when we upgraded from Windows ME to Windows XP, with no sound after the upgrade. After consulting with computer stores and "Geek Squad", it was finally determined that Windows XP set the speakers for analog not digital. Once that was reset, our sound returned. Hope this works for you.
Mollys Mom
Jan 02, 2009 | Boston Acoustics BA735 Computer Speakers
Boston BA745 speakers
check where its plug in the back check your volume make sure its not on mute
Mar 03, 2008 | Boston Acoustics BA745 Computer Speakers
Sylvania sdvd7046 black - 7 Portable Dvd Player Logo
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
