Question about LG enV VX9900 Cellular Phone
Having the sampe problem!
Keyboard and side keys have locked up. It seemed to happen after inserting a 2GB memory chip in the compupter. Any solutions yet?
Sd card memory doesn't recognised
On the actual card, make sure that the "locked-switch" is in the middle. The "lock-switch" is the sliding tab on the side of the micro SD card. The dial should be in the exact middle, or as close to the middle as possible, or the card will read something along the lines of "This data card in encrypted," when inserting the chip into the computer.
Nov 21, 2014 | SanDisk 2GB microSD Memory Card
My computer won't read my memory card
Hello :
Look for a tiny switch on the side of the SD card . This switch indicates[ Lock or Unlock ] . You need to unlock it .
ed57898.jpg please rate!
good luck .
Apr 11, 2010 | SanDisk 2GB microSD Memory Card
Does the new macbook 13 inch white comes with 1 speaker or 2, it seems like the sound comes out only from the right side?? i am not too sure if the speaker is built only on the right side by default and...
I'm thinkin' 2. This page <http://www.ifixit.com/Teardown/MacBook-Unibody-Model-A1342/1239/3> talks about it having "two small tweeters beneath the keyboard, one below the caps lock key, and the other below the return key."
Good luck.
K.
Dec 31, 2009 | Apple MacBook 13"White /2.0Ghz Intel Core2...
I have a lap top Dell Precision M20 and replaced the old ram from the slot below the keyboard with 512 MB by a new with 1GB. It worked fine! Since I bought two times 1GB, I inserted also the second in the...
these different ram slots have different bus speed so they really don't work if you are using them both at once.
Please check your laptop's documentation about the speeds of these ram slots.
Dec 27, 2009 | Dell Precision M20 Notebook
Lexar 2gb sd
its having problem with its chip...claim forwarranty....
Reply if satisfied
Jul 06, 2009 | SanDisk 2GB microSD Memory Card
Computer compaq nc 6000 power off during working
If you feel the power adapter working fine with the diff unit its not an issue with the adapter,
Now, if the unit is not powering on.just perform this:
Take out the batter, adapter and make the unit stand alone and press and hold the Power button with out any power to the unit(Without battery , adapter) by doing that we can take the static charge which might be causing the issue,
If that does not fix the issue, try reseating the RM if you are comfortable, here is the steps:
Primary memory board removal Before you begin: Remove the battery and keyboard.
  1. Push both arms outward simultaneously to release the primary memory board to the spring tension position.
    Caution! When handling a memory board, use care to prevent touching the memory chips on the board. Touching the memory chips could damage or destroy the memory.
  2. Grasp the primary memory board by the edges and pull gently to remove it.
  3. Place the primary memory board in a static dissipative bag.
Primary memory board replacement
  1. Remove the primary memory board from the static dissipative bag.
  2. Locate the alignment slot and align it to the empty board receptacle.
  3. Grasp the primary memory board by the edges and push gently to replace it.
  4. Press the primary memory board down to latch the arms.
Steps to remove Keyboard:
eyboard removal Before you begin: Remove the battery.
  1. Loosen the captive P1 Phillips-head screw that secures the memory/Mini PCI cover to the bottom of the notebook.
  2. Use your finger or a flat-bladed tool to lift the outside edge of the memory/Mini PCI cover and remove it.
  3. Remove the two T8-9 mm screws that secure the keyboard to the base enclosure.
  4. Turn the notebook right side up and open the display panel fully.
  5. Slide the four plastic locking tabs toward the bottom edge of the keyboard to unlock the keyboard from the LED switch cover.
  6. Use a flat-bladed tool or your finger to lift the top edge of the keyboard and then place it upside down on the top cover.
  7. Using minimal force, lift the locking bar to unlock the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the ZIF connector and ribbon cable.
  8. Remove the keyboard ribbon cable from the ZIF connector and remove the keyboard.
Keyboard replacement
  1. After ensuring that the locking bar on the keyboard ZIF connector is unlocked, place the keyboard right side up on the top cover.
  2. Insert the keyboard ribbon cable into the keyboard ZIF connector on the system board.
    Important! Use care to prevent damaging the keyboard ribbon cable.
  3. Push the locking bar down to lock the keyboard ZIF connector on the system board.
  4. Toe the tabs on the bottom edge of the keyboard into the top cover.
  5. Press the keyboard flat and slide the four plastic locking tabs toward the rear of the notebook to lock the keyboard to the LED switch cover.
  6. Close the display panel and turn the notebook upside down.
  7. Replace the two T8-9 mm screws that secure the keyboard to the base enclosure.
  8. Toe the memory/Mini PCI cover into the enclosure.
  9. Tighten the captive P1 Phillips-head screw.
Jul 06, 2009 | HP Compaq nc6000 Notebook
I have 2 x 2gb ram, and can't find 2nd slot for one of them
if you only have 1 slot, on the underside of the laptop.
it,s most likely, if there are any more slots, they,ll be under the Keyboard.
This will possibly be, where the 512 mb is now, although some laptops do have on-board memory chips from 256-512mb. ( try under the Keyboard )
Mike @ compurepair.
Jan 21, 2009 | HP Compaq nx6310 Notebook
Shift Keys not working properly on ACER notebook
The 8042 keyboard controller has been integrated into one chip with other I/O functions so I doubt you can replace it as a single IC and I'm afraid that is what has failed. It is an extremely rare failure but I guess it has to happen some time. The keyboard is kind of a polled matrix so it only takes the failure of a single line to bollix things up.
I think what you are talking about here is a motherboard exchange or repair.
Dec 13, 2008 | Acer NSK8458AN Keyboard
LG enV VX9900 Cellular Phone Logo
37 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
