Question about Epson Office Equipment & Supplies
Epson I have code 1489 which is the wiper blade is not insstalled correctly. I took it out to clean it, put it back in, and now I can't get back into the service mode to release it so I can adjust it.
SOURCE: took screws out of blades now won't move
there is something to do with the balancing of the blades
it would of been better to send them in to be sharpend...they charge 10 bucks for this service in australia
best send the blades in
Posted on Aug 25, 2008
SOURCE: Chevy Venture 2003 needs new wiper blades
Yes if they are for the front Window that is the correct size. 24" for both sides
Posted on Dec 22, 2008
  • 21 Answers
SOURCE: Back Wiper wouldn't stay close to window
Sounds like you have a bent wiper arm. Maybe somebody in a parking lot pulled on it. You can try rebending it towards the window by removing the arm and slightly bending it. A little bend should do. I don't know why Dodge didn't make these spring loaded like the fronts.
Good luck and keep us posted.
Posted on Jan 22, 2009
  • 61 Answers
SOURCE: I took them apart to clean and now I can't get
take time, don't rush
Posted on Jan 05, 2010
  • 913 Answers
take the arm off and turn it round unitil it is at the position you want it to start from
Posted on Jun 12, 2010
Wiper blade is squeaky how do I fix it
1) Lift blade and clean with washer fluid on rag.
2) lift blade clean with Fantastic or similar on edge with rag.
3) Bend wiper arm slightly to put pressure on window from blade.
4) Change blade.
Mar 09, 2015 | BMW X3 Series Cars & Trucks
Replacing Wiper Blades or Not
Do not replace your wiper blades until you have tried this, get some warm soapy water, soft all purpose cloth. Hose down your front and rear windscreen (if fitted with wiper blades) with normal water, clean the windscreen as you would when washing the vehicle. Get your cloth and dip it into warm soapy water, if your wiper arm stays upright put it in that position other wise lift it up and put a piece of towel or similar under it. Now with the soapy cloth give the wiper blade edge a good scrub, up and down, hold the blade itself with one hand on one end, it may slide out, you will notice the cloth getting black, you are cleaning off all the dirt that is stuck on the wiper blade, simple as that. It is usually that dirt which causes your wiper blades not to clean properly, you will eventually need to replace it but give it a go, you will be surprised.
on Feb 20, 2011 | Chevrolet Chevy Cars & Trucks
I need to learn how to put the windshield wiper linkage back on
Remove the wiper arms completely. Turn on the wiper motor and then turn it off again, allowing it to park automatically.
Now put the wiper arms back so that the blades just touch the bottom edge of the windscreen, or wherever the correct position is. Tighten the nuts
Have fun!
Sep 27, 2014 | 1994 Dodge Grand Caravan
1996 crown vic- drivers side wiper arm loose, blade will not lay flat when cleaning
Sometimes you need to bend the arm to put more pressure on the glass.
Mar 29, 2014 | 1996 Ford Crown Victoria
i`m not sure what you mean by it not working properly i assume that you mean it goes back and forth like the passenger side, but it doesn`t clean the window and you put the blade on the arm correctly then the wiper may be damaged and you will have to replace the wiper blade.check and compare the installation of the driver`s side to the passenger side wiper and correct the installation of the blade
Mar 08, 2011 | 1999 Buick Century
Epson 9600 splatering black ink on images mostly on the right side
I have not worked on such a large machine, but it sounds like the ink waste station likely need cleaning. All smaller inkjet printers have silicone wiper blades that clean excess ink off the print head surface, if the blades are heavily saturated in junked up ink they may not be cleaning the print head appropriately. I have cleaned many wiper sleds with warm water and Q-tips, but always on home or SOHO machines. If this is not something you feel comfortable doing, call a professional technician, I'm sure that machine is worth and simple service call.
Mar 23, 2010 | Epson Stylus Pro 9600 InkJet Printer
I have 2 problems. First the front end of my 2005 Grand Caravan makes a thumping noise. I thought it may be the struts or stabilizer bushings, I took it to a dealer and they said that it is niether and...
As for the front noise. Sounds like the ball joints. They wear a groove in the cup, where they sit. When they go over the lip, they make a thump sound. As for the rear wiper arm. If the arm has been taking off, folks strip the knurl teeth out of the arm. If the motor is working back & forth right, & wiper arm is tight. Oil the hinge pin on the wiper arm. They get alot of dirt on the back window. If all else fails replace wiper arm.
Jan 19, 2010 | 2005 Dodge Caravan
Print heads won't come clean
To really clean the epson 7600, alternately print a nozzle check and then run a cleaning. Do this 8 times in a row. If that does not fix the problem, it could be that you need to replace the cleaning assembly. You could also try just cleaning off the wiper blade in the cleaning assembly. You need to remove the left side cover to get at the wiper.
Here is a link for the service manual SP76-9600_service manual.pdf I'm only including this for the instructions on removing the side panel, and for recognition of the wiper blade.
You can do your own cleaning assembly replacement if you have any sort of experience in that sort of thing, But if you don't, I would recommend leaving that to a tech. (But it is pricey.)
May 01, 2009 | Epson Stylus Pro 7600 InkJet Printer
Replace rear windshield wiper
I took it to a mechanis, who is a friend of mine. Toyota made that rear windshield wiper custom. So he took off the stopper and the screw in lock and I bought a 13" blade and we put the attachment on that came wih the wiper and slid it on to the arm.
Feb 11, 2009 | 1997 Toyota 4Runner
2004 ram 1500... after a heavy snow fall, now the wiper blades are approx 2 inches above where the stop point should be. when i turn on the blades, they go down before going up.
take them off of the shafts a nut holds them under a plastic cover. turn your key on and turn your wipers on with the wipers removed. then turn wipers off with switch. turn off key an put wipers back on in the correct park position.
Dec 28, 2008 | Dodge Ram 1500 Cars & Trucks
49 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
