Question about Rinnai Heating & Cooling
I have a Rinnai heating system the filter light is blinking red it is beeping every few min. Guy from company said it may be partially frozen dump warm water over it I cleaned screen/ vent is clean
SOURCE: my rinnai 556fa propane heater
I had the identical trouble with my Rinnai 431F just now & read the unanswered posts.
I checked my intake & exhaust & found them connected & intact then went out to check the exterior vent assembly. The "bell" or dome was almost entirely clogged with ice.
I suspect the 60 - 76 lights flashing means insufficient combustion air.
Anyway, I took a hair dryer to it & in 10 minutes it was working as well as ever.
This won't help you October posters but if anyone else has this problem in the future I would start with the outside vent assembly. Get a good look right up inside because I would have missed this ice if I didn't get up close with a flashlight.
Here's a good source for manuals too...
http://www.houseneeds.com/products_rinnai.asp
I'm going back to bed.
M.
Posted on Dec 22, 2008
  • 70 Answers
SOURCE: short cycling..continually..minimal heat
Is this furnace standing pilot or electronic? if standing pilot turn power off then take t-stat off wall and connect the wires labeled r and c together and see if that keeps furnace working. If electronic check flame sensor you can check flame sensor buy cleaning with steel wool. if that doesn't work then try t-sat.
Posted on Jan 22, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: rinnai 431wt filter light won't go out
If you have changed the filter, and the light stays on then you need to let the system stay down for 24 hours without running. Also go ahead and check the vent cap on the outside of the unit. The light will go awaa by itself if you need to use the system
Posted on Feb 08, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: My rinnai 556f wont run. I turn it on and the on
Press the up arrow, down arrow and economy button all at the same time and hold them down for three seconds. A bunch of lights will light up under the numbers. Write them down and look in your operation manual for a diagnostic chart. I suspect a dirty filter has burnt out a overheat safety switch. I may have one if you need one. chandler@chandlerrepair.com.
Posted on Mar 03, 2010
  • 120 Answers
SOURCE: Rinnai Convector 417, has been flashing the filter
Bit concerned on giving advice on this one other than take it to GOOD servicemen and get it checked out properly. Cleaninbg the filters is Ok, the large one slides out to the top, the smaller one unclips, push in the two tags (closest to the centre of the heater) and it sort of hinges off from the other side of the filter. Give these a good clean. It might just smell because you have disturbed smaller dust particles that are being burnt. Mums know best, if you are worried, get it looked at and don't use it!
Posted on Jul 21, 2010
Luxpro PSD111 thermostat reading 78 when set to cool at 72. Snowflake blinking and not cooling. Please advise. Thank you.
Usually blinking means you are in a time delay. Obviously not for three hours but... Turn fan to on position and verify your indoor fan is working. If so check outdoor unit and see if it's running. If no indoor fan turn breaker off, and inside the tstat put the red and green wires together and turn breaker back on. If indoor fan runs you have a bad tstat. Good luck!!
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Mar 22, 2017 | Heating & Cooling
Our red filter light is on and we have cleaned everything and now it makes 5 beeps every few minutes constantly
Check the air switch and tubing, if everything is clean, the switch is defective, the tubing is plugged or disconnected/broken.
Feb 10, 2015 | Rinnai Energy Saver Direct Vent Wall...
Error code 12
Three main causes.
Short circuit on the low voltage side of the wiring (12V) This will show as an immeadiate error code 12 befoe the thing even tries to light.
Faulty earth on the low voltage side shows same as above.
A faulty gas regulator or partial blockage of gas supply that allows the unit to fire, but will not maintain sufficient gas supply to keep it alight. This will happen after it has lit, maybe erratically with the occasional error code 11 if you try and re-light immeadiately.
May 13, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heater shuts off and lights blink
go to rinnai's website and look up the manual for the diagnostic codes. rinnai.us, look under literature/manuals. type in "556". It will tell you how to retreive the error codes.
Oct 17, 2009 | Rinnai EnergySaver 556 Air Conditioner
Does not heat to 375 degree. cooked but soggy fries. green ready light goes on and off. tried preheating 20 minutes. not much better.
you can fry fries at 325 degrees.pre heat for 25 min. rinse fries with water first, fry for 11-14 min. should be golden and crunchy. Deep fry guy :) Fresh potato recipe after fries are fried sprinkle w/seasoned salt &little red pepper
Sep 07, 2009 | Rival CF275 Deep Fryer
Ice maker not producing any ice.
Pour about 1/2 cup of water into icemaker . Squeeze the black fill tub which is above the icemaker cup . If ice apears to be in it , this indicates that the weter valve is not completely closing , letting a drip ocasionally go thru and freezing inside the tube , ( water valve bad ) . that will be a different solution . If the icemaker dumps the cubes after freezing . and black tube is not frozen , replace the water inlet valve . If the icemaker does not dump the ice after frozen , replace the icemaker ( only 1 screw holds the icemaker in , located on rear portion on right , faceing down . Also check the icemaker rake , which should be about the 2:30 position . To thaw out the black tube (which runs thru the top of the refrig ) a 1/4 push on connector will be needed . Remove the icemaker and use a hairdryer aimed up into the hole . Cut the tubing to the fill tub behind the fridge about 9 inches from where it enters the top of the fridge . This will let warm air inside the top fill line to help thaw . Ocassionally blow thru the 9 inch tube until you can blow thru it . May take a day or 2 , depending how frozen the line is . Once air will go thru , install the push on connector to couple the cut lines back togather .
The blinking red light on the right side , is the receiver for the electric eye for cutting off the icemaker when the door bin is full , This blinking is normal . 2 blinks ...pause...2 blinks..etc .
Do not replace the filter if water flow is good thru the dispensor .
Aug 16, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
Rinnai Energysaver 1004F on indicator light is red (usally green)
If its not producing heat, yep! If it is, it indicates that there is an error code stored in memory.
Feb 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
No spark to ignite
vacuumed out area behind filter--it works fine now.
Dec 18, 2008 | Rinnai EnergySaver 556 Air Conditioner
Heating & Cooling Logo
433 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
vance jones
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
