Question about Ovens
Both top small oven and main oven are not reaching temperature above 150
    New Friend:
  • 52 Answers
Chq your fuses sounds like your onlly running on 110 volts
Posted on Dec 17, 2016
My oven is loosing temperature
To me it sounds like the heating element is starting to go, I would suggest that you replace that and see how it go there after.
Feb 10, 2012 | Ovens
Main Oven does not reach required temperature
check gas pressure and burner if ok bad temp sensor
May 19, 2017 | Electrolux EOD5330 Ultrafan Electric...
Hi i have turbochef speed oven in subway and on display show F6 ec Temp . what is problem
F6 faults occured when temperature reached to 150 degree faharanite in the electrical compartment.
1. Clean the dust in the electrical compartment.
2. There is an temperature sensor on the controle board which gets dirty and throw wrong values.Clean it and then try.
3. Check the exaust fan in the top rear location is working properly.
4.Check for proper air ventillation.
Apr 15, 2011 | TurboChef TORNADO Electric Oven
Bosch built in double oven: had new element fitted to main fan oven, but now oven keeps on getting hotter does not stop heating up when right temp reached.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Mar 27, 2011 | Bosch Ovens
The oven does'nt seem to be able to heat up above 150, the fan is working, the bottem half of the oven does'nt seem to heating up. Is this fixable or do i need a new oven?
If the part that is not heating is only the bottom element, and the top element is heating regularly, then you may need to replace the lower element.
Before replacement the element can be tested removing it from the cavity and reading Ohms at the element terminals, with a multimeter set at Rx1. Disconnect power before removing the element.
If both baking and broiling element do not heath above a certain temperature instead, then the part to be replaced is the temperature probe, still located inside the oven cavity.
Mar 04, 2010 | Whirlpool RBS275PD Electric Single Oven
I have a Competence 52081 double oven. Ity has
Thermostat may need adjusting OR air may be entering the oven causing the problem
Sep 01, 2009 | Ovens
Oven not achieving correct temperature, 50 degrees too low
Thermostat is not working properly and needs replacement.
Apr 14, 2017 | Ovens
Neff U1452 tripping electrics
sounds like you have a faulty new element. sometimes depending how long you supplier has had the element they get damp and when they get hot they go down to earth. if i was you i would take it back and get another one and try that. hope this helps you .
regards dan
Mar 19, 2009 | Neff U1452 Double circotherm plus Electric...
Ovens Logo
24 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
Are you an Oven Expert? Answer questions, earn points and help others
