Question about Whirlpool Ovens
Whirlpool built-in oven GBS307PD: After self-clean, temperature adjust button which Increases the temperature now decreases the temperature. Decrease button works fine. Otherwise, oven works great.
Have a Whirlpool Gold built in oven GBS307PD. After a self-clean, the temperature adjust button to Increase the temperature now decreases the temperature. The button to Decrease the temperature works as normal,therefore I have two buttons that decrease the temp and no way to increase the temp. Everything else on the oven works as normal.
Whirlpool self-cleaning oven: RBD275PDB14 . . . I DO NOT want it to self-clean. Is there any way to DISABLE the self-cleaning feature?
Just don't use it. The finish in the oven is made to work with the self-cleaning operation; it naturally facilitates burn-off at high temperatures. It is normally impractical to remove and replace the finish, besides, it's harmless as far as I know. If you are worried about someone accidentally activating self-clean, you could tape a coin over the self-clean button. (If you have a curious child in mind, the coin may actually draw attention to the button and invite its operation - you know better than I who or what you are dealing with.)
There is no good way to disable the self-cleaning function without replacing the controller with a custom-built and programmed unit. The button is in a matrix with other buttons, so attempts to disconnect it would disable other buttons and generate a controller error that would prevent the range from operating.
Jul 08, 2017 | Whirlpool Ovens
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
Why doesn't oven work after using the self- cleaning mode?
Check for incoming power; you may need to change the heater element.
Sep 11, 2015 | Whirlpool GBS307PD Electric Single Oven
How to turn on electric frigidaire oven; fgf337gud?
Good Morning Friend,
I understand you want to know how to turn on the oven on your Frigidaire range, model# FGF337GUD. First, make sure you have set the clock. You will do this by pressing the "Clock Set" button and then press and hold down the up or down arrows, until the correct time shows. After you have set the clock, you are ready to turn your oven on.
To set the temperature for your oven, you will press the "Bake" button and three dashes will appear. Press the up and down arrows to change the temperature. Note: The temperature will begin at a default temperature of 350 degrees. Once you have released the up or down arrow, your oven will begin heating to the selected temperature. When your oven reaches the desired temperature, it will beep once.
To cancel the baking function, you will press the "Clear/Off" button.
If you wish to change the temperature after baking has begun, you will press the bake button again, and then change the temperature by pressing the up or down arrows to either increase or decrease the temperature.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your air conditioner status has changed successfully. Hope this is helpful.
-Best Regards-
Jun 13, 2014 | Frigidaire 30" Self-Cleaning Freestanding...
Can not raise temperature above 350
500 degrees farenheit is 260 degrees celcius (metric)
any chance the display is set for metric ?
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
My kenmore W&R locked to start the cleaning process and never turned on, but now won't open. It's been 4 hours.
Verify that the Whirlpool oven is connected to its power source. The oven may sometimes lock down if experiencing a power surge or similar electrical problems. Additionally, check that a fuse hasn't been blown in your home's fuse box. Some older homes may not have the proper wiring to support a high-powered appliance such as a Whirlpool oven. If you are not sure if your wiring is sufficient, consult a local electrician.
  • Check to see if the Whirlpool oven's Control Lock has been turned on, a safety mechanism designed to lock the oven and disable its keypad and display controls. A padlock symbol will be displayed in the corner of the Whirlpool oven's front display panel if it is locked. The oven will not unlock itself on its own even if it is disconnected from its power source. To disable, press and hold the "3" button on the keypad for five seconds until the padlock icon disappears.
  • See if the Whirlpool oven is engaged in its self-cleaning cycle. During the self-cleaning process, the stove will lock its front door and will flash "OVEN LOCKED" on its front display. This is to prevent users from accidentally opening the oven and burning themselves during the high-heat segment in the cleaning process. If you must open the oven, first stop the process by pressing and holding the "OFF/CANCEL" button on the stove's control panel. If the oven remains locked, wait for the internal temperatures to decrease. The locking mechanism is temperature controlled and will not unlock until internal temperatures have cooled.
  • Contact Whirlpool's service department if your Whirlpool oven remains locked and you cannot troubleshoot it or open it. All Whirlpool self-cleaning ovens are covered for five years after the original purchase date. Call the warranty team for assistance by dialing toll-free (800) 253-1301 in the United States, or (800) 807-6777 in Canada. Be prepared to give the oven's model number and purchase date
  • Dec 11, 2011 | Kenmore 33464 / 33465 / 33469 Gas Single...
    Whirlpool Built In Oven - Accubake - RB5275PD06 After self cleaning last week, the control panel is not functioning properly. For example, when we press the temp button, it won't go above 350. When...
    Good Evening!
    This is a common problem that Ledgestone Technologies and can solve. The touchpad on your oven has failed and will need to be replaced. Read more about the failure and solution below. Message us if you have any questions!
    Whirlpool Oven Wont Increase Temperature Stuck at 350
    May 27, 2017 | Whirlpool Ovens
    Icant change the time on my stoves HAP0050 ELECTRIC OVEN,any ideas Thanks
    In most cases. Simply press the appropriate button for the feature you want to access, and then use the "+" and "-" buttons to increase and decrease the number values. For example, to set the clock, press the "Clock" button, followed by the "Time/Temp" button; use the "+" and "-" buttons to set the clock to the desired time. When you are finished, press the "Start" button to save your setting. Use the same process to set the oven temperature and timer.
    Read more: Whirlpool Stove Instructions '
    Mar 19, 2011 | Ovens
    Oven cooks at 400 plus degrees when set at 350 degrees
    If your problem is temperature do this;
    Press "options" Then press "6". Then press "3" to increase or "6" to decrease temp.
    Then press "start" to end the calibration.
    If you recently used self-cleaning you could have a thermal overload fuse problem.
    Feb 23, 2009 | Whirlpool SB160PEE Gas Single Oven
    Ovens Logo
    42 people viewed this question
    Top Whirlpool Ovens Experts
    Dan Webster
    Dan Webster
    Sal De
    Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
